MPEG /video revelation
Started by Rune Allnor January 27, 2004
Hi all.
I have just spent a few days making some small MPEG movies that
illustrate certain wave propagation phenomena. First of all,
while I have made movies for my own use for the last 7 or 8 years,
being able to actually make MPEG movies from time-domain simulated
data has opened up a whole new world to me. All of a sudden I can
send a small (< 10 MB) movie to just about anyone, and have them
play the thing on standard software on a standard PC without
obese requirements to either SW or HW. Even more, they can actually
see for themselves all these more or less obscure waves I talk so
much about. Which means that all of a sudden I find that people
think that what I have to say makes some sort of sense. Which is
a very nice experience.
Now, this revelation has opened some questions to me. First, the MPEG
generator I got hold of, works via matlab. The generator takes a matlab
movie as input and spits out an MPEG file. While it works, it is first
of all slow, and second, it relies on this ridicilously obese matlab
movie format as intermediate stage between raw data and MPEG movie.
Going via matlab movie does impose some limits that I suspect might
prevent me form making some movies I would find useful, if I could
produce them.
The "obvious" idea hit me that it might be an idea to try and
write my own MPEG encoder that I can tailor to the type of data
I'm modeling and want to visualize. I am a bit dubious, though,
as I suspect it may not be as easy or as straight-forward to implement
such a thing as I want to believe in my current euphoric state.
Any comments, suggestions or warnings are welcome.
Rune
allnor@tele.ntnu.no (Rune Allnor) writes:
> The "obvious" idea hit me that it might be an idea to try and > write my own MPEG encoder that I can tailor to the type of data > I'm modeling and want to visualize. I am a bit dubious, though, > as I suspect it may not be as easy or as straight-forward to implement > such a thing as I want to believe in my current euphoric state.
Don't do it! There used to exist a MPEG encoder/decoder pair that took single frames of .ppm images (I think) and compressed them into MPEG. I think I took this from mpeg.org or some related site. For the application I had, I needed it to read in .jpg files and compress them... it was easy enough to modify the code. The other possibility is to use AVI files instead. Matlab's AVIFILE command gives examples of how to do this... but it may not do what you're after. ciao, Peter K. -- Peter J. Kootsookos "I will ignore all ideas for new works [..], the invention of which has reached its limits and for whose improvement I see no further hope." - Julius Frontinus, c. AD 84
p.kootsookos@remove.ieee.org (Peter J. Kootsookos) wrote in message news:<s681xplkfs3.fsf@mango.itee.uq.edu.au>...
> allnor@tele.ntnu.no (Rune Allnor) writes: > > > The "obvious" idea hit me that it might be an idea to try and > > write my own MPEG encoder that I can tailor to the type of data > > I'm modeling and want to visualize. I am a bit dubious, though, > > as I suspect it may not be as easy or as straight-forward to implement > > such a thing as I want to believe in my current euphoric state. > > Don't do it! > > There used to exist a MPEG encoder/decoder pair that took single > frames of .ppm images (I think) and compressed them into MPEG. > > I think I took this from mpeg.org or some related site. > > For the application I had, I needed it to read in .jpg files and > compress them... it was easy enough to modify the code. > > The other possibility is to use AVI files instead. Matlab's AVIFILE > command gives examples of how to do this... but it may not do what > you're after.
Do you mean an avi -> MPEG converter? That could work. Matlab allows, to the best of my knowledge, to make the avi file on a frame by frame basis. That way one only needs to deal with one frame at the time in RAM. It's not perfect but way better than dealing with matlab movies. Do you have a lonk to such a converter? Rune
Aloha,
Rune Allnor schrieb:
> The "obvious" idea hit me that it might be an idea to try and > write my own MPEG encoder that I can tailor to the type of data > I'm modeling and want to visualize. I am a bit dubious, though, > as I suspect it may not be as easy or as straight-forward to implement > such a thing as I want to believe in my current euphoric state. > Any comments, suggestions or warnings are welcome.
Don't even think about writing it yourself. Except you have the time to do it... For an own Matlab visualization project i used the mpeg-encode (afair U.C.Berkeley) that is linked on the mpeg.org web-page. That encoder reads a broad range of input picture formats and is pretty fast. From Matlab i plotted my data and printed every single frame to a postscript file (which saves a lot of space). To get the raster image mpeg_encode needs as input it is possible to define an input filter to transcode (and in this case render the .ps via ghostscript) the single frames. A large part of the project was to fine-tune the parameters of the mpeg_encoder to get a reasonable bitrate and picture quality. Wishing a happy day LOBI
