On May 6, 6:23�am, Randy Yates <ya...@ieee.org> wrote:> Hi Dave,Hi Randy> I've watched, with some amusement, all the responses and I don't > think anyone has really hit the mark.Yes, I get that feeling too. The comment like "Devil is in the details." does not actually add very much to the discussion.> Let me take a swing at it. > FM discrimination using the formula you show above, or by using > "standard" differentiation of the phase, involves differentiation. > Differentiation is an inherently noisy process.Yes, that is true. That certainly sounds a logical explanation of why the system might fail. As a matter of interest, today I was looking at the service manual on an older Kenwood transceiver, the TS-950S. That uses DSP for demodulating SSB and CW, but not AM or FM. They use a diode detector for AM demodulation in that old rig. At least the more modern transceivers I've look at use the DSP for AM. I would imagine AM demodulation is very easy. In fact, there's a video on u-tube of where someone used a Stanford Research Devices RF lock-in amplifier as an AM radio. I used to be surrounded by lock-in amplifiers and RF components at a previous place of employment. Shame I never beat him to making a very expensive AM radio.> One technique which does NOT use differentiation would be a > least-squares estimator of the "instantaneous" frequency. You > do this by finding the phase (arctan) of the I/Q samples, then > fitting the phase values to a line: y = m*x + b. "m" is then > your frequency.Yes, that sounds logical.> I'm pretty sure this is going to perform better, but you have to be > careful, e.g., you need to carefully evaluate how much of a slice of > time serves for "instantaneous," and to be well-oversampled so that > you get quite a few samples over that slice.Yes. Thanks Randy. You have given me something to think about.> -- > Randy Yates � � � � � � � � � � �% "So now it's getting late, > Digital Signal Labs � � � � � � �% � �and those who hesitate > mailto://ya...@ieee.org � � � � �% � �got no one..."http://www.digitalsignallabs.com% 'Waterfall', *Face The Music*, ELO
Is it difficult to do FM demodulation digitally?
Started by ●May 5, 2011
Reply by ●May 7, 20112011-05-07
On May 6, 6:04�pm, Clay <c...@claysturner.com> wrote:> On May 6, 12:51�pm, Clay <c...@claysturner.com> wrote: > > > > > On May 5, 7:44�pm, David Kirkby <drkir...@gmail.com> wrote: > > > > On May 5, 8:10�pm, Clay <c...@claysturner.com> wrote: > > > > > David, I was working with narrowband FM - i.e., the spectral occupancy > > > > was 30kHz. If you are looking at commercial braodcast FM - you are > > > > then looking at a much higher spectral occupancy. For example the > > > > typical broadcast channel is 200kHz wide so you will need to sample at > > > > least 400kHz. The channel is wider than the deviation which in the US > > > > is +-75kHz with mono stations being allowed to go an extra 10%. But > > > > you can see your samping rate needs to be pretty high. > > > > I'm looking only at narrow band FM for amateur radio use, where > > > typically the channel spacing is 12.5 KHz, so onereally needs to keep > > > the modulation under that. I'm not interested in commercial FM > > > transmissions. Hence I would have thought that using a 24-bit sound > > > card able to sample at 192 KHz would have �been suitable. > > > > > You can cheat and narrow the channel down with filtering before > > > > demodulating, but then you lose your quieting and then end up with a > > > > not so high hi-fi. > > > > > Perhaps the DSP that was already in the receiver was was maxed out > > > > with its other tasks. And that is why they added another one. > > > > > IHTH, > > > > Clay > > > > Perhaps that's the reason, but the fact I know the FlexRadio has FM > > > demodulation issues makes me wonder if demodulating even narrow band > > > FM is more difficult than I thought it would be. > > > > Dave > > > Hello Dave, > > > When I demodulated narrowband FM, I did (as Vladimir suggests) and > > made my analytic signal in software. Yes this does burn some cycles, > > but then you can achieve nearly perfect 90 degree phase difference and > > matching amplitudes across the band of interest. THe IdQ-QDi approach > > can actually work pretty well if you do the right approximations. > > > Clay- Hide quoted text - > > > - Show quoted text - > > Dave, > > See > > http://www.claysturner.com/dsp/instantaneousfrequency.pdf > > for one example of a simplified form of the cross correlation > approach. It uses low order differentiators so it won't try to magnify > the noise too much. > > IHTH, > ClayCheers Clay, I think I understand the problems a bit better now, and possibly have some approaches to trial that may work, which are less suseptable to noise than my initial idea. I must admit though, I'm beginning to doubt if this will be as good as a cheap FM demodulator IC. I'm going to pour over the manual of some of the very expensive (over $10,000) DSP based transceivers - e.g. http://www.icomuk.co.uk/categoryRender.asp?categoryID=3785&productID=730&tID=647 and see if that, does the demodulation of FM in hardware or software. Dave
On May 6, 4:27�pm, Mark <makol...@yahoo.com> wrote:> On May 6, 11:00�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > > Mark wrote: > > > I've always wanted to see how a good threshold extended demod would > > > work for narrow band voice FM. > > > The ultimate threshold extended demodulator makes the efficient input > > bandwidth equal to the bandwidth of the demodulated signal. Hence the > > gain is input BW/output BW. > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > conventional "communications narrow band voice FM" �uses +/- 5 kHz > deviation with an RF BW of about 13 kHz and a demodulated BW of about > 3 kHz so some worth while "extension" might be possible. > > It would be interesting to see how it works in practice. > > I thought it would be interesting to combine a very narrow band > threshold extended demod that was as narrow as possible to optimize > recovered SNR at the expense of some distortion with a conventional > demod that would automatically switch in whenever �the signal was > above threshold. > > Of course the world has passed analog FM by... > > MarkThis is a common misconception - if you study the actual performance of 'modern' radio - that is, Satellite or HD radio, the audio bandwidth is about 15 kHz and the SNR is about 70dB - just like conventional/ current 'analog' FM. TomC
Reply by ●May 8, 20112011-05-08
On 05/07/2011 09:53 PM, tomcee wrote:> On May 6, 4:27 pm, Mark<makol...@yahoo.com> wrote: >> On May 6, 11:00 am, Vladimir Vassilevsky<nos...@nowhere.com> wrote: >> >>> Mark wrote: >>>> I've always wanted to see how a good threshold extended demod would >>>> work for narrow band voice FM. >> >>> The ultimate threshold extended demodulator makes the efficient input >>> bandwidth equal to the bandwidth of the demodulated signal. Hence the >>> gain is input BW/output BW. >> >>> Vladimir Vassilevsky >>> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com >> >> conventional "communications narrow band voice FM" uses +/- 5 kHz >> deviation with an RF BW of about 13 kHz and a demodulated BW of about >> 3 kHz so some worth while "extension" might be possible. >> >> It would be interesting to see how it works in practice. >> >> I thought it would be interesting to combine a very narrow band >> threshold extended demod that was as narrow as possible to optimize >> recovered SNR at the expense of some distortion with a conventional >> demod that would automatically switch in whenever the signal was >> above threshold. >> >> Of course the world has passed analog FM by... >> >> Mark > > This is a common misconception - if you study the actual performance > of 'modern' radio - that is, Satellite or HD radio, the audio > bandwidth is > about 15 kHz and the SNR is about 70dB - just like conventional/ > current > 'analog' FM.That's because 70 dB SNR is pretty darned good! If you can get an honest 70 dB in audio, that's as good as the best audiophile records (e.g., Mobile Fidelity Sound Labs' half-speed masters) ever got. -- Randy Yates % "So now it's getting late, Digital Signal Labs % and those who hesitate mailto://yates@ieee.org % got no one..." http://www.digitalsignallabs.com % 'Waterfall', *Face The Music*, ELO
Reply by ●May 11, 20112011-05-11
"tomcee" <tomcees_pc@yahoo.com> wrote in message news:2af521ac-96a7-490c-9ef6-0e57a89b5c75@a18g2000yqj.googlegroups.com...>This is a common misconception - if you study the actual performance >of 'modern' radio - that is, Satellite or HD radio, the audio >bandwidth is >about 15 kHz and the SNR is about 70dB - just like conventional/ >current >'analog' FM.Yes, although this is now a constraint driven more by the cost of bandwidth rather than the technical abilities of the receiving circuitry, as was once the case -- and of course the fact that the human ear's performance hasn't improved in the past umpteen millennia either. Sirius satellite radio was, in its early years, going to be called "CD Radio." While that arguably was changed because it wasn't thought to be very marketable, it seems to me that they fact that they would have needed 3-4x as much bandwidth per music station to put them within striking distance of true CD quality might have influenced it as well. And of course the "HD" in "HD radio" officially stands for nothing whatsoever. :-( ---Joel
Reply by ●May 17, 20112011-05-17
On May 7, 4:47�pm, David Kirkby <drkir...@gmail.com> wrote:> On May 6, 6:23�am, Randy Yates <ya...@ieee.org> wrote: > > > > I've watched, with some amusement, all the responses and I don't > > think anyone has really hit the mark. > > Yes, I get that feeling too. > > > FM discrimination using the formula you show above, or by using > > "standard" differentiation of the phase, involves differentiation. > > Differentiation is an inherently noisy process.isn't that what the pre-emphasis and de-emphasis (they do for FM broadcast) for? BTW, David, that derivative formula you started with V = (I*dQ/dt - Q*dI/dt)/(I^2 + Q^2) still has to be implemented in discrete time. if you define dt as the sample period (essentially just a scaling issue), you might get V[n] = (I[n]*(Q[n]-Q[n-1]) - Q[n]*(I[n]-I[n-1]))/(I[n]^2 + Q[n]^2) = (Q[n]*I[n-1] - I[n]*Q[n-1])/(I[n]^2 + Q[n]^2) this would be thought to be the phase difference between adjacent samples of the analytic signal: I[n] + j*Q[n] where Q[n] is the Hilbert transform of I[n]. but i think a more straight-forward approach is to directly compute the phase difference between adjacent samples: V[n] = arg{ (I[n] + j*Q[n])/(I[n-1] + j*Q[n-1]) } or V[n] = arg{ (I[n] + j*Q[n]) * conj(I[n-1] + j*Q[n-1]) } when you do that, you get a slightly different result: V[n] = arctan((Q[n]I[n-1] - I[n]Q[n-1])/(I[n]I[n-1] + Q[n]Q[n-1])) to use arctan(Im/Re) instead of arg{ Re + j*Im }, we are assuming the abs value of the phase difference between adjacent samples is less than pi/2. if it's *much* less, the arctan function is pretty linear (arctan(x) ~= x) and the two formulae can be directly compared (and there is a small difference in the denominator). if you *do* implement an arctan() function, a short power series with odd-powered terms will do quite well for angles less than pi/4. but the latter formula gets you the exact phase difference between samples (which, if you get enough of these phase difference samples, you can construct a filter that will better approximate the continuous- time derivative, but at a slightly delayed time) and does not approximate the derivative with the finite difference of the most recent two samples. this filter can be teamed up with the de-emphasis filter necessary in FM demodulation. r b-j
