Hi, Although, this stuff is considered 'elementary' knowledge for an electrical engineer I still have tonnes of confusion. Can someone take time to explain this to me? I understand quadrature sampling (books by simon haykin & Richard Lyons do a great job) but I fail to see the practical aspect of this. At the receiver, X(t)cos(wt) --> inphase component X(t)sin(wt) --> quadrature component How is X(t) generated at the transmitter from its inphase and quadrature components? I assume X(t) is generated using the following equation, X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt) Suppose, I use BPSK modulation, then what will X_inphase(t) and X_quadrature(t) be? Thanks
Quadrature Modulation
Started by ●May 10, 2011
Reply by ●May 10, 20112011-05-10
On May 10, 10:46=A0am, "johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> wrote:> Hi, > Although, this stuff is considered 'elementary' knowledge for an electric=al> engineer I still have tonnes of confusion. Can someone take time to expla=in> this to me? > > I understand quadrature sampling (books by simon haykin & Richard Lyons d=o> a great job) but I fail to see the practical aspect of this. > > At the receiver, > X(t)cos(wt) --> inphase component > X(t)sin(wt) --> quadrature component > > How is X(t) generated at the transmitter from its inphase and quadrature > components?The emitted signal X(t) is generated by modulating the message x(t). Maybe there is an I/Q representation of the signal at some intermediate stage, but there needs not be. Rune
On May 10, 4:46=A0am, "johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> wrote:> Hi, > Although, this stuff is considered 'elementary' knowledge for an electric=al> engineer I still have tonnes of confusion. Can someone take time to expla=in> this to me? > > I understand quadrature sampling (books by simon haykin & Richard Lyons d=o> a great job) but I fail to see the practical aspect of this. >The practical aspect is that you can steer (modulate) the carrier either up or down in frequency with quadrature modulation. On the flip side, with quadrature demodulation, when you mix the carrier to baseband, you can tell whether the demodulated signal that folded to baseband was on the + side f the carrier or on the - side of the carrier. This is HUGE.> At the receiver, > X(t)cos(wt) --> inphase component > X(t)sin(wt) --> quadrature component > > How is X(t) generated at the transmitter from its inphase and quadrature > components? I assume X(t) is generated using the following equation, > > X(t) =3D X_inphase(t)cos(wt) - X_quadrature(t)sin(wt) > > Suppose, I use BPSK modulation, then what will X_inphase(t) and > X_quadrature(t) be? > > ThanksFor BPSK you can use just X_inphase(t) and zero out the Q component, however if you do it that way you will get an amplitude suckout during the phase transition. If you do not want the amplitude suckout then you have to also move the Q(t) componant from 0 to a value of 1 and then back to 0 during that phase transition. You could also build a BPSK modulator by starting both values at 0.707 and figure out the values for I and Q by rotating I and Q halfway around the unit circle.
On May 10, 4:46 am, "johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> wrote: ...> How is X(t) generated at the transmitter from its inphase and quadrature > components? I assume X(t) is generated using the following equation,As far as I know, quadrature modulation is amplitude modulation of quadrature carriers. Obviously, the two carriers being at constant phase offset implies that they are at the same frequency. While there are several ways to accomplish this, it is easy to think of the process as two separate modulators, one operating on sin(w_c*t) and the other as cos(w_c*t), and the results being summed before reaching the antenna. (They could also feed separate antennas; the receiver would see the same signal. ... Jerry -- Engineering is the art of making what you want from things you can get.
On 05/10/2011 01:46 AM, johnlovestohate wrote:> Hi, > Although, this stuff is considered 'elementary' knowledge for an electrical > engineer I still have tonnes of confusion. Can someone take time to explain > this to me? > > > I understand quadrature sampling (books by simon haykin& Richard Lyons do > a great job) but I fail to see the practical aspect of this. > > At the receiver, > X(t)cos(wt) --> inphase component > X(t)sin(wt) --> quadrature component > > How is X(t) generated at the transmitter from its inphase and quadrature > components? I assume X(t) is generated using the following equation, > > X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt)It can be done that way. Quadrature modulation isn't the only way to generate a signal -- just one of many. When you design transmitters you start with a lot of possible different schemes, and settle on the one that makes the most sense.> Suppose, I use BPSK modulation, then what will X_inphase(t) and > X_quadrature(t) be?For a BPSK signal, X_quadtrature(t) will be zero, and X_inphase(t) will be +1 or -1 (or +a, -a, a = some constant). By the time things get to the receiver, the signal will have been phase shifted, the frequency will probably be off, etc., so you'll need quadrature demodulation to capture the whole signal, then you'll need a BPSK demodulator to recover the data. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On Tue, 10 May 2011 03:46:31 -0500, "johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> wrote:>Hi, >Although, this stuff is considered 'elementary' knowledge for an electrical >engineer I still have tonnes of confusion. Can someone take time to explain >this to me? > > >I understand quadrature sampling (books by simon haykin & Richard Lyons do >a great job) but I fail to see the practical aspect of this. > >At the receiver, >X(t)cos(wt) --> inphase component >X(t)sin(wt) --> quadrature component > >How is X(t) generated at the transmitter from its inphase and quadrature >components? I assume X(t) is generated using the following equation, > >X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt)That's correct. Take the real part of the complex product of the mixing oscillator cos(wt) + j * sin(wt) and the signal X_inphase(t) + j * X_quadrature(t) to get X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt)> >Suppose, I use BPSK modulation, then what will X_inphase(t) and >X_quadrature(t) be? > >ThanksBPSK is real-valued, but the mixing oscillator may still be treated as complex depending on the architecture of the transmitting radio. It would be equivalent to do any of the following where BPSK(t) is the signal: X_inphase(t) = BPSK(t) X_quadrature(t) = 0 or X_inphase(t) = 0 X_quadrature(t) = BPSK(t) or X_inphase(t) = (1/sqrt(2)) * BPSK(t) X_quadrature(t) = (1/sqrt(2)) * BPSK(t) Basically, you can rotate the original real-valued vector to any fixed angle in the complex plane and transmit it as in-phase and quadrature components. Just setting the in-phase or quadrature to zero and using the other for BPSK(t) is easy, but in many implementations using the 1/sqrt(2) trick and transmitting equally in both will result in either the most output power or the cleanest output signal. Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
http://en.wikipedia.org/wiki/QPSK#Quadrature_phase-shift_keying_.28QPSK.29 The above website should help.
>On Tue, 10 May 2011 03:46:31 -0500, "johnlovestohate" ><aliatolemiss@n_o_s_p_a_m.gmail.com> wrote: > >>Hi, >>Although, this stuff is considered 'elementary' knowledge for anelectrical>>engineer I still have tonnes of confusion. Can someone take time toexplain>>this to me? >> >> >>I understand quadrature sampling (books by simon haykin & Richard Lyonsdo>>a great job) but I fail to see the practical aspect of this. >> >>At the receiver, >>X(t)cos(wt) --> inphase component >>X(t)sin(wt) --> quadrature component >> >>How is X(t) generated at the transmitter from its inphase and quadrature >>components? I assume X(t) is generated using the following equation, >> >>X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt) > >That's correct. > >Take the real part of the complex product of the mixing oscillator > >cos(wt) + j * sin(wt) > >and the signal > >X_inphase(t) + j * X_quadrature(t) > >to get > >X(t) = X_inphase(t)cos(wt) - X_quadrature(t)sin(wt) > >> >>Suppose, I use BPSK modulation, then what will X_inphase(t) and >>X_quadrature(t) be? >> >>Thanks > >BPSK is real-valued, but the mixing oscillator may still be treated as >complex depending on the architecture of the transmitting radio. It >would be equivalent to do any of the following where BPSK(t) is the >signal: > >X_inphase(t) = BPSK(t) >X_quadrature(t) = 0 > >or > >X_inphase(t) = 0 >X_quadrature(t) = BPSK(t) > >or > >X_inphase(t) = (1/sqrt(2)) * BPSK(t) >X_quadrature(t) = (1/sqrt(2)) * BPSK(t) > >Basically, you can rotate the original real-valued vector to any fixed >angle in the complex plane and transmit it as in-phase and quadrature >components. Just setting the in-phase or quadrature to zero and >using the other for BPSK(t) is easy, but in many implementations using >the 1/sqrt(2) trick and transmitting equally in both will result in >either the most output power or the cleanest output signal. > > > > >Eric Jacobsen >http://www.ericjacobsen.org >http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php >Thanks everybody. I get it now.
Reply by ●May 11, 20112011-05-11
On May 10, 12:40=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote many cogent comments to which I would like to add a bit. Suppose that we have a complex-valued signal Z(t). Wait a minute, you say, there is no such thing. So, we actually have two real-valued signals X(t) and Y(t) on two separate wires (or I and Q branches if you will), and we think of them as comprising the complex-valued signal Z(t) =3D X(t) + jY(t) where j =3D sqrt{-1}. We can modulate this signal onto a high-frequency (complex) carrier signal exp(j2 pi f_c t) to create a complex carrier signal Z(t)exp(j 2 pi f_c t). Note that 4 real multiplications are needed to compute the product Z(t)exp(j 2 pi f_c t). For the record, Re{Z(t)exp(j 2 pi f_c t)} =3D X(t)cos(2 pi f_c t) - Y(t)sin(2 pi f_c t) and Im{Z(t)exp(j 2 pi f_c t)} =3D X(t)sin(2 pi f_c t) + Y(t)cos(2 pi f_c t) If we transmit both the real and imaginary parts of Z(t)exp(j 2 pi f_c t) where, of course, we need two channels to send them, then we can recover Z(t) easily. At the receiver, multiply the incoming signal by exp(- j 2 pi f_c t), and voila`, we have Z(t) plus noise, that is, we have recovered X(t) and Y(t). The instantaneous power in Z(t)exp(j 2 pi f_c t) is (proportional to) |Z(t)exp(j 2 pi f_c t)|^2 =3D |Z(t)|^2 =3D |X(t)|^2 + |Y(t)|^2. Wait a minute! We have two real signals on two separate channels, and the instantaneous power is [X(t)cos(2 pi f_c t) - Y(t)sin(2 pi f_c t)]^2 + [X(t)sin(2 pi f_c t) + Y(t)cos(2 pi f_c t)]^2 isn't it? Well, multiplying it all out and cancelling the cross-terms, we see that |X(t)|^2 + |Y(t)|^2 is indeed correct. But, nobody except God and DoD can afford two channels, and so the rest of us just transmit Re{Z(t)exp(j 2 pi f_c t)} =3D X(t)cos(2 pi f_c t) - Y(t)sin(2 pi f_c t) on one channel and forget about Im{Z(t)exp(j 2 pi f_c t)}. We can still recover Z(t) from this by multiplying by 2.exp(- j 2 pi f_c t) where the 2 is there because we have, in effect, only half the signal available, and we want to restore the signal levels. Note that now we have a real-complex multiplication that requires two multipliers, and the multiplier outputs go to the inphase and quadrature branches of the receiver. Now we have Re{Z(t)exp(j 2 pi f_c t)}.2.exp(- j 2 pi f_c t) =3D X(t).2cos^2(2 pi f_c t) - Y(t)2sin(2 pi f_c t)cos(2 pi f_c t) - j[X(t)2cos(2 pi f_c t)sin(2 pi f_c t) - Y(t)2sin^2(2 pi f_c t)] =3D X(t)[1 + cos(2 pi 2f_c t)] - Y(t)sin(2 pi 2f_c t) + j{Y(t)[1 - sin(2 pi 2f_c t)] - X(t)sin(2 pi 2f_c t)} The double-frequency terms are eliminated by low-pass filters in the I and Q branches leaving X(t) + jY(t) as the output. Instantaneous power of the transmitted signal is a bit messier. |X(t)cos(2 pi f_c t) - Y(t)sin(2 pi f_c t)|^2 =3D 0.5{|X(t)|^2[1 + cos(2 pi 2f_c t)] + |Y(t)|^2[1 - cos(2 pi 2f_c t)]} - X(t)Y(t)sin(2 pi 2f_c t) and even to argue that the energy is proportional to the integral of 0.5{|X(t)|^2 + |Y(t)|^2} requires the assumption that f_c is high enough compared to the highest frequency in X(t) and Y(t) that the baseband signals can be assumed to be constant over each period of the double-frequency sinusoid, and so |X(t)|^2.cos(2 pi 2f_c t) integrates to 0 over each 1/2f_c second period. --Dilip Sarwate
