On 30.05.2011 16:12, david447 wrote:> So I tried to shift my output with 32 bits (with 48 bits in all stages). > Obiouvsly, the results are : > 0000000000001000 > 0000000000001001 > 0000000000000001 > > And zero before and after. > > According to what I said previously, with the highest value at the output, > I have many zeros in the MSBs, so when I truncate like here, I have > nothing... >There might be a bug in your VHDL code, since, as was mentioned before, the output should be much greater when a full-scale impulse is applied to the CIC input. Can you post the code on some file sharing engine? -- Alexander
CIC pruning theory
Started by ●May 25, 2011
Reply by ●June 1, 20112011-06-01
Reply by ●June 3, 20112011-06-03
>On 30.05.2011 16:12, david447 wrote: > >> So I tried to shift my output with 32 bits (with 48 bits in allstages).>> Obiouvsly, the results are : >> 0000000000001000 >> 0000000000001001 >> 0000000000000001 >> >> And zero before and after. >> >> According to what I said previously, with the highest value at theoutput,>> I have many zeros in the MSBs, so when I truncate like here, I have >> nothing... >> >There might be a bug in your VHDL code, since, as was mentioned before, >the output should be much greater when a full-scale impulse is applied >to the CIC input. Can you post the code on some file sharing engine? > > >-- > >Alexander >Hello, CIC parameters : Stages : 6; Decimation : 40; Delay : 1; Bin = 16; Bout = 48 (= Bmax) Some part of my VHDL code : http://www.4shared.com/document/14tgWFXY/cic.html Thank you for your help! David.
I am sorry, I forgot to add this information : I5 signal uses all of the 48 bits. C0, C1 and C2 too. But, from C3, all of the 48 bits are not used. Indeed : C3 : bits 44 to 47 never used (equal to zero); C4 : bits 37 to 47; C5 : bits 36 to 47. So I was thinking that I have to prunne the MSB of my comb signals, instead of the LSB. What do you think about that ? Thank you, David.
Hello David, Sorry for misleading you. Your pulse response might be OK because with the decimation ratio of 40 the filter suppresses much of the pulse spectrum contents. That's why so many MSBs are constant in the pulse response. If you sum the pulse response samples you'll get a number that is roughly 40 times lower than the maximum value in 48-bit signed format.> I am sorry, I forgot to add this information : > > I5 signal uses all of the 48 bits. > C0, C1 and C2 too. > But, from C3, all of the 48 bits are not used. > Indeed : > C3 : bits 44 to 47 never used (equal to zero); > C4 : bits 37 to 47; > C5 : bits 36 to 47.> So I was thinking that I have to prunne the MSB of my comb signals, instead > of the LSB. > What do you think about that ?You can't do that. Apply a step function or a full-scale low frequency sinewave instead of a unity length pulse and you'll see all the bits changing at the filter output. PS: Your code looks a bit strange. Firstly, it contains description of 5 stages instead of 6. The value that you latch in the decimation process is also strange. And, finally, why do you convert the output of the last comb to the unsigned? -- Alexander
Reply by ●June 6, 20112011-06-06
>Hello David, >Sorry for misleading you. Your pulse response might be OK because with >the decimation ratio of 40 the filter suppresses much of the pulse >spectrum contents. That's why so many MSBs are constant in the pulse >response. If you sum the pulse response samples you'll get a number that >is roughly 40 times lower than the maximum value in 48-bit signed format. > >> I am sorry, I forgot to add this information : >> >> I5 signal uses all of the 48 bits. >> C0, C1 and C2 too. >> But, from C3, all of the 48 bits are not used. >> Indeed : >> C3 : bits 44 to 47 never used (equal to zero); >> C4 : bits 37 to 47; >> C5 : bits 36 to 47. > > >> So I was thinking that I have to prunne the MSB of my comb signals,instead>> of the LSB. >> What do you think about that ? > >You can't do that. Apply a step function or a full-scale low frequency >sinewave instead of a unity length pulse and you'll see all the bits >changing at the filter output. > > >PS: Your code looks a bit strange. Firstly, it contains description of 5 >stages instead of 6. The value that you latch in the decimation process >is also strange. And, finally, why do you convert the output of the last >comb to the unsigned? > >-- >Hello, Thank you for your response. I have modified my VHDL code like this : http://www.4shared.com/document/qA5bIIAF/cic.html? I changed the first integrator part as follows : I0 = I0 + data_in (instead of I0 = data_in) Than, I suppressed the C0 signal, and I grab the last integrator signal directly (in the Comb process) : CD0 = I5 et C1 = I5 - CD0 Then, you were right, I made a mistake so I add a comb part : C6 = C5 - CD5 Now, I have this result (always in 48 bits) : 000000000000001111010100010100110101011101001010 000000001000101000010101011000101101001100010010 000000011010100111100111111000100010100110010100 000000001100101011110011001100000001011001110100 000000000000101001110101000110100001010110100010 000000000000000000000000000000101111111111111010 So now, I can try to prune the output to 16 bits, but I'm afraid that I'll loss a lot of information.
So, I improved my code, and I add the pruning theory : The problem is the same : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000110 0000000100000100 0000001101001100 0000000110100110 0000000000010110 0000000000000000 1111111111111111 0000000000000000 1111111111111111 0000000000000000 0000000000000000 1111111111111111 0000000000000000 1111111111111111 0000000000000000 etc. So I think that I just have to discard 32 bits at the output...and fortget the pruning theory. Here is my complete code : http://www.4shared.com/document/N0OJI3sV/cic2.html
> So, I improved my code, and I add the pruning theory : > The problem is the same : > > 0000000000000000 > 0000000000000000 > 0000000000000000 > 0000000000000000 > 0000000000000000 > 0000000000000000 > 0000000000000110 > 0000000100000100 > 0000001101001100 > 0000000110100110 > 0000000000010110 > 0000000000000000 > 1111111111111111 > 0000000000000000 > 1111111111111111 > 0000000000000000 > 0000000000000000 > 1111111111111111 > 0000000000000000 > 1111111111111111 > 0000000000000000 > etc. >As i wrote in one of the previous posts, it is most likely happens due to additional noise introduced by pruning LSBs in integrator stages (i'm not absolutely sure, since i have never gone so deep into pruning theory). This noise causes least significant bits to change even when actual pulse response duration ends because of accumulation of errors in integrators. Assuming properly chosen lengths of individual stages the peak-to-peak noise shall not exceed minimum value representable in the desired output data format - that's the ultimate goal of pruning. But as the noise is bipolar and truncation is used in both integrator and comb stages the negative values of noise are converted to a minimum negative value (all ones in signed fixed-point format). If you use true rounding to nearest instead of truncation at the output of the last comb stage then you are likely to get what you want to see. Sorry if i was unclear in my description - english is not my mother tongue and my language skills are not so good for writing such long passages :( As for the loss of information... yes you are going to lose something (though not much, because your input data are 16-bit wide) due to reduction of the output wordlenth, no matter if you simply truncate the output or use pruning in the intermediate stages of the filter. But if further processing stages in your system can work with 16-bit data only the loss of precision in the CIC filter output shouldn't bother you that much. -- Alexander
