Dear DSP experts, I would like to know how to calculate the actual range of the frequency bins in the frequency axis. It must have to something to do with the sampling frequency Fs, So I think the top of the top frequency bin must be the half of the Fs, correct? However I don't know the rest of frequency axis, how do you determine the actual Hz where the bands are divided? Thank you for your input.
Frequency bin in wavelets transform
Started by ●June 16, 2011
Reply by ●June 16, 20112011-06-16
I believe some wavelet transforms have octave spaced frequency bands. If that is not the case then it should be possible to view your transform as a filter bank instead. Then plot the frequency responses of the impulse responses and determine the bandwidths by visual inspection. Btw. you don't necessarily need to know the sampling frequency, maybe for your problem a normalized frequency axis is sufficient. Cheers
