"Brian Reinhold" <breinhold@comcast.net> wrote in message news:ziaOb.84961$xy6.144535@attbi_s02...> [...] method snipped. > And compare which is largest.That looks good to me -- providing you remembered to filter out the out-of-band components first.> If 'total0' is greater than 'total1' then tone 0 was present. I thinkthat> is what you described below. It's just in my computations I find that the > magnitude of the 'totalx' values are consistently larger with one wave > versus the other, and I beleive this is due to the fact that one tone has > only 1 and 1/12 of a period while the other has 1 and 3/4 of a period. ButI> am not sure.I'm going to guess that your signal has a DC offset or a 60hz hum that you haven't removed.
Who made the comment about modems and FSK signals?
Started by ●January 15, 2004
Reply by ●January 19, 20042004-01-19
Reply by ●January 20, 20042004-01-20
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:o10Pb.8158$U77.601294@news20.bellglobal.com...> > "Brian Reinhold" <breinhold@comcast.net> wrote in message > news:ziaOb.84961$xy6.144535@attbi_s02... > > [...] method snipped. > > And compare which is largest. > > That looks good to me -- providing you remembered to filter out the > out-of-band components first. > > > If 'total0' is greater than 'total1' then tone 0 was present. I think > that > > is what you described below. It's just in my computations I find thatthe> > magnitude of the 'totalx' values are consistently larger with one wave > > versus the other, and I beleive this is due to the fact that one tonehas> > only 1 and 1/12 of a period while the other has 1 and 3/4 of a period.But> I > > am not sure. > > I'm going to guess that your signal has a DC offset or a 60hz hum that you > haven't removed.Well, I have not filtered the incoming signal, but I do remove the mean over the samples which I compute the matched filter. However, I think I am running a case of a clean signal. At least the noise that does exist has 32 times smaller amplitude. I also normalize that above 'sum of products' with the 'sum of products of the matched filter with itself'. The normalization value computed with the two tones are different, but it doesn't help enough. When I graphically look at this value of 'total' as it is being computed for a dot pattern (alternating tones of equal baud length), for short bauds the pattern looks like a sine wave with lots of small scale wiggles on it, and the wiggles are quite large in amplitude. As the baud length becomes longer (so each tone includes more and more periods) the sinusoidal shape approaches a triangular shape and the wiggles become much smaller in amplitude and relative scale ( of course the bauds are longer so the relative scale is expected to shrink). These wiggles are probably the source of the problems I am having with the detection algorithm. They maybe an unavoidable feature of having only about one period of signal to work with. Brian> >
"Brian Reinhold" <breinhold@comcast.net> wrote in message news:GZ7Pb.105643$8H.182368@attbi_s03...> When I graphically look at this value of 'total' as it is being computedfor> a dot pattern (alternating tones of equal baud length), for short baudsthe> pattern looks like a sine wave with lots of small scale wiggles on it, and > the wiggles are quite large in amplitude. As the baud length becomeslonger> (so each tone includes more and more periods) the sinusoidal shape > approaches a triangular shape and the wiggles become much smaller in > amplitude and relative scale ( of course the bauds are longer so the > relative scale is expected to shrink). > These wiggles are probably the source of the problems I am having with the > detection algorithm. They maybe an unavoidable feature of having onlyabout> one period of signal to work with.Oh, I see. That sounds right to me, too. A baud-length snippet of signal that isn't aligned to the signal boundaries can look pretty wierd when the baud length is so small. If you're not doing any clock recovery, then I would recommend a detection algorithm with a narrower bandwidth. You could try TIs algorithm, or you could pass your total1-total0 through a low-pass to filter out the ripples. You can make the system more robust if you recover the clock, and only look for symbols at the appropriate symbol instants.
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:R7bPb.5109$rW5.277264@news20.bellglobal.com...> > "Brian Reinhold" <breinhold@comcast.net> wrote in message > news:GZ7Pb.105643$8H.182368@attbi_s03... > > When I graphically look at this value of 'total' as it is being computed > for > > a dot pattern (alternating tones of equal baud length), for short bauds > the > > pattern looks like a sine wave with lots of small scale wiggles on it,and> > the wiggles are quite large in amplitude. As the baud length becomes > longer > > (so each tone includes more and more periods) the sinusoidal shape > > approaches a triangular shape and the wiggles become much smaller in > > amplitude and relative scale ( of course the bauds are longer so the > > relative scale is expected to shrink). > > These wiggles are probably the source of the problems I am having withthe> > detection algorithm. They maybe an unavoidable feature of having only > about > > one period of signal to work with. > > Oh, I see. That sounds right to me, too. A baud-length snippet of signal > that isn't aligned to the signal boundaries can look pretty wierd when the > baud length is so small. If you're not doing any clock recovery, then I > would recommend a detection algorithm with a narrower bandwidth. Youcould> try TIs algorithm, or you could pass your total1-total0 through a low-pass > to filter out the ripples. > > You can make the system more robust if you recover the clock, and onlylook> for symbols at the appropriate symbol instants.I hear a lot about 'clock recovery' but I am not sure how one would do that. The timing is supposed to be x baud but there should also be a certain tolerance to error (there may be a 5% difference between the sender's and receiver's clocks). So I do not try to 'predict' the length of the next baud pulse based upon what I have received. I look for transitions and estimate the number of baud pulses based on the time between transitions and the expected length of a baud pulse. I do know that no more than 7 zero or one bits can appear sequentially in the message, so that kind of puts an upper bound on the tolerance. Right know I am doing a simple computation to see how the wiggles and overall signal should appear. Brian> >
