On Mon, 25 Jul 2011 10:31:20 -0500, Vladimir Vassilevsky wrote:> Tim wrote: > > >> Any thing you do would, perforce, be Kalman _based_ > > Yes. The problem can be stated as minimization of the error vector. As > such, it is the application for RLS.Actually, if the noise (negligible or not) is known, as well as the frequency, then a Kalman filter for the offset, inphase and quadrature components ought to be pretty easy. Then you're just a half step away from the phase. If you expect the phase to drift you should be able to accommodate that, too. I haven't pondered an H-infinity filter for a time-varying system (which is the model you'd be building your Kalman filter around) but it'd be worth a look to get more robustness. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Fast measurement of amplitude and phase
Started by ●July 23, 2011
Reply by ●July 26, 20112011-07-26
