Hi, I am considering usage of the Mean-Shift algorithm to classify local maxima in gray scale image ( result of Hough Transform for lines ). For mean calculation I use the center of mass formula ( having Luma as the mass ). The mean shift procedure: 1. Define a radius, e.g. 6 2. For each 12x12 box in the image a. Calculate the center of mass b. Shift the 12x12 box center to the resulting center of mass c. Goto step 2 3. Repeat step 2 until the shift is small enough, or, until a certain amount of iterations has elapsed. The problem with the above flow is that in most of the cases the algorithm ~locks up~ traversing a group of pixels until �max iterations� is reached, this, result in invalid convergence of the algorithm. I have also tried to increase the radius ( to a certain extent ) when the shift is too small and to reduce it when the shift is too big, this, improved the result, but, still, most of the iterations ended locked up traversing a fixed group of pixels ( repeating the same pixels ). My aim is to have each pixel in the image converging to one maxima in the image. Have I got the mean shift procedure correctly? Is there any known improvement to avoid the closed loop pixel traversing? Any help will be appreciated. Nadav Rubinstein http://www.sophin.com
Mean Shift procedure for finding local maxima in a Gray Scale image
Started by ●July 28, 2011
Reply by ●July 28, 20112011-07-28
Nadav wrote:> Hi, > > I am considering usage of the Mean-Shift algorithm to classify local[..description of a problem skipped..]> Any help will be appreciated.Does your appreciation imply some real money, or it is purely imaginary? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
