Hi, I've a few fundamental question. I was going through the LTE specs. It said the fundamental symbol duration was .67us 1. If 30.72Mhz is the sampling rate (15khz subcarrier spacing*2048 sub carriers) , how does LTE support bandwidths greater than 15.36, the spec specifies bandwidths upto 20Mhz. Even if I assume only 100 RBs are used, it still leaves me with a bandwidth of 18 Mhz. Doesn't this violate nyquist sampling theorem ? 2.How would one define sampling rate in case of a system that uses OFDM as the modulation scheme ? Is merely carrier spacing * number of carriers or is it the reciprocal of (symbol duration divided by number of carriers). How can i express or derive this mathematically ?
A fundamental question on LTE/OFDM sampling rates
Started by ●September 2, 2011
Reply by ●September 2, 20112011-09-02
Hi, it's complex-valued samples, the Nyquist bandwidth equals your sampling rate. In other words, there is no 1/2 factor, as in real-valued sampling. Your IFFT output "controls" a bandwidth of 30.72 MHz, if you use 2048k at 30.72Msps. Of that, a bandwidth of 18 MHz is used, 2 M are guard bands. You can sample your OFDM signal at any rate you like. For example, if I use a 2049-size FFT, I'll get one extra sample over the body length. BTW I dug out some old piece of code that's supposed to generate an OFDM signal with raised-cosine windowing, maybe it's useful. http://www.dsprelated.com/blogimages/MarkusNentwig/comp.dsp/generateGenericOFDM.m Once you delete away the first and last lines, there isn't any toolbox magic etc, just basic vector manipulation.
>> Of that, a bandwidth of 18 MHz is used, 2 M are guard bands... and in an implementation we need the remaining 10.72 MHz for the low-pass filter that reconstructs a continuous-time waveform (anti-aliasing filter).
Reply by ●January 10, 20132013-01-10
please i'd like to ask u about choice of band with when we use 1.4 ; 3; 5; 10; 15 ;20. I'd like to now the advantages an disadvantages of bandwidth choice. thank you
On Thu, 10 Jan 2013 03:38:50 -0800 (PST), mensimedmehdi@gmail.com wrote:>please i'd like to ask u about choice of band with when we use 1.4 ; 3; 5; 10; 15 ;20. I'd like to now the advantages an disadvantages of bandwidth choice. >thank youWider bandwidth has higher throughput potential, but results in decreased range for the same transmit power and occupies more spectrum (so fewer channels are available). Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
