"spasmous" <spasmous@yahoo.com> wrote in message news:2f066762.0401111218.78f9e69e@posting.google.com...> robert bristow-johnson <rbj@surfglobal.net> wrote in messagenews:<BC26579A.7998%rbj@surfglobal.net>...> > >> > > >> maybe use a Kaiser window? > > > > > > OK. Any reason? > > > > > > I just read somewhere that Hamming is supposed to give the smallest > > > side lobes, so I was thinking of using that. > > > > Hamming is easier to calculate (so it might be okay). Kaiser is muchmore> > optimizes and has a control parameter to trade off main lobe width with > > stopband attenuation. you will probably need MATLAB or some good C math > > library to compute the Kaiser window. > > I don't think additional control parameters are very helpful are they? > It's just one more variable to have to optimise - so far I have window > width as a variable, now I have to select a windowing function, then a > parameter for the windowing function. Much better to have less > variables, no? Hamming at least has some optimal property (minimises > lobes) rather than just being an arbitrary choice out of all possible > functions/parameters. > > I'd be interested in comments (nice ones, please)! :>Not every design has the same goal--you may want minimal side lobes, but someone else may want wider main lobe, etc.. The nice thing about the Kaiser is that you can make it look like many of the other windows out there just by changing the single parameter. Then you don't have to search between the myriad of other windows out there to get what you're looking for--just pick Kaiser and tune it to your needs. To many, this simplifies things. However, if there is a simpler window out there that already meets your requirements, by all means use it and be happy! Regarding "Much better to have less variables, no?" that depends on if your goal is simplicity or fine control/optimization. For many people, it is the latter. Nice enough for you? -Jon
Suggestion for tapered sinc
Started by ●January 10, 2004
Reply by ●January 12, 20042004-01-12
