I try to implement the matlab code on BER for QPSK in OFDM over rayleigh channel (with n taps). However the result is a straight line. There must be something wrong in my code but I cannot figure it out what is wrong. Could you please help me to check it. I have to hand the work soon. Please please please help. Thank you very much. [QUOTE]clear; clc; N=64; % FFT size Nsd = 48; % Number of data subcarriers 48 Nsp = 4 ; % Number of pilot subcarriers 4 ofdmBW = 20 * 10^6 ; % OFDM bandwidth %Derived Parameters deltaF = ofdmBW/N; %=20 MHz/64 = 0.3125 MHz Tfft = 1/deltaF; % IFFT/FFT period = 3.2us Tgi = Tfft/4;%Guard interval duration - duration of cyclic prefix Tsignal = Tgi+Tfft; %duration of QPSK-OFDM symbol Ncp = N*Tgi/Tfft; %Number of symbols allocated to cyclic prefix Nst = Nsd + Nsp; %Number of total used subcarriers nBitsPerSym=2*Nst; %For QPSK the number of Bits per Symbol is double of num of subcarriers %Simulation parameters nSym=2; %Number of OFDM Symbols to transmit (I try to work out in small number first) EbN0dB = 0:2:45; % bit to noise ratio EsN0dB = EbN0dB + 10*log10(Nst/N) + 10*log10(N/(Ncp+N)); % converting to symbol to noise ratio simulatedBER = zeros(1,length(EsN0dB)); theoreticalBER = zeros(1,length(EsN0dB)); for i=1:length(EsN0dB), %----------------------------------------------- %Transmitter %----------------------------------------------- re=rand(1,(nBitsPerSym/2)*nSym)>0.5; im=rand(1,(nBitsPerSym/2)*nSym)>0.5; % ----------Modulation--------- %Constellation Mapper ip = (2*re-1) + j*(2*im-1); % s1 = (1/sqrt(2))*ip; % normalization of energy to 1 %serial to parallel conversion s=reshape(s1,nBitsPerSym/2,nSym).'; % Assigning modulated symbols to subcarriers from [-26 to -1, +1 to +26] X_Freq = [zeros(nSym,6) s(:,[1:Nst/2]) zeros(nSym,1) s(:,[Nst/2+1:Nst]) zeros(nSym,5)] ; %IFFT block x_Time = (N/sqrt(Nst))*ifft(fftshift(X_Freq.')).'; %Adding Cyclic Prefix ofdm_signal=[x_Time(:,N-Ncp+1:N) x_Time]; [rows cols]=size(ofdm_signal); %----------------------------------------------- %Channel Modeling %----------------------------------------------- nTap = 10; ht = 1/sqrt(2)*1/sqrt(nTap)*(randn(nSym,nTap) + j*randn(nSym,nTap)); % computing and storing the frequency response of the channel, for use at recevier hF = fftshift(fft(ht,64,2)); % convolution of each symbol with the random channel for jj = 1:nSym xht(jj,:) = conv(ht(jj,:),ofdm_signal(jj,:)); end xt1 = xht; % Concatenating multiple symbols to form a long vector xt = reshape(xt1.',1,nSym*(80+nTap-1)); % Gaussian noise of unit variance, 0 mean nt = 1/sqrt(2)*[randn(1,nSym*(80+nTap-1)) + j*randn(1,nSym*(80+nTap-1))]; % Adding noise, the term sqrt(80/64) is to account for the wasted energy due to cyclic prefix %yt = sqrt(80/64)*xt + 10^(-EsN0dB(i)/20)*nt; yt = sqrt(80/64)*xt + 10^(-EsN0dB(i)/20)*nt; %----------------------------------------------- %Receiver %----------------------------------------------- %Serial to Parallel conversion r_Parallel=reshape(yt.',89,nSym).'; %Removing cyclic prefix r_Parallel=r_Parallel(:,Ncp+1:(N+Ncp)); %FFT Block r_Time = (sqrt(Nst)/N)*fftshift(fft(r_Parallel.')).'; % equalization by the known channel frequency response yF = r_Time./hF; %Extracting the data carriers from the FFT output R_Freq = yF(:,[6+[1:Nst/2] 7+[Nst/2+1:Nst] ]); %---------------------------------------------------------------------- %--------- QPSK demodulation ------------% y_re = real(R_Freq); % real y_im = imag(R_Freq); % imaginary ipHat(find(y_re < 0 & y_im < 0)) = -1 + -1*j; % iphat= input^ hat ipHat(find(y_re >= 0 & y_im > 0)) = 1 + 1*j; ipHat(find(y_re < 0 & y_im >= 0)) = -1 + 1*j; ipHat(find(y_re >= 0 & y_im < 0)) = 1 - 1*j; %---------------------------------------------% numErrors = size(find([ip- ipHat]),2); % couting the number of errors simulatedBER(i)=numErrors/(nSym*nBitsPerSym); theorySer_QPSK(i) = erfc(sqrt(0.5*(10.^(EsN0dB(i)/10)))) - (1/4)*(erfc(sqrt(0.5*(10.^(EsN0dB(i)/10))))).^2; end semilogy(EsN0dB,simulatedBER,'r-o','LineWidth',2); hold on; semilogy(EsN0dB,theorySer_QPSK,'k*','LineWidth',2); [/QUOTE] Please check it for me and let me know which part is wrong here. Thank you so much in advance. Here is the result graph.
Please help: BER for QPSK in OFDM over Rayleigh matlab code doesn't work.
Started by ●September 19, 2011
Reply by ●September 19, 20112011-09-19
I had only a quick look but I noticed>> nSym=2Hint: How many bit errors do I need to observe to get a reliable bit error rate? At a target BER x, how many bits do I need to simulate in average?
Reply by ●September 20, 20112011-09-20
>I had only a quick look but I noticed >>> nSym=2 > >Hint: How many bit errors do I need to observe to get a reliable biterror>rate? At a target BER x, how many bits do I need to simulate in average? >Thank you so much for your response. When I try to simulate it, I always set nSym to be very small to save time on running. However when it seems to be ok, I will change nSym to be big number e.g. 10^4, 10^5 and see if it produces accurate result. However in this case, if I change nSym to be 10^5, the result will be the same which is straight line. I am guessing the BER is very small at high Es/No. I cannot really figure it out which part of the simulation is wrong. I have done simulation of BER for BPSK in OFDM and it works using the same code. But when I change to QPSK, the result is just go wrong. I am very beginner in wireless communication so please please help me. Please check for me and figure out which part is wrong.Thank you very much.
Reply by ●September 21, 20112011-09-21
mackenfy wrote:> can someone please help me. I need to fix this very soon. pleaseeHow much are you willing to pay for getting this job done? VLV
> > >mackenfy wrote: > >> can someone please help me. I need to fix this very soon. pleasee > >How much are you willing to pay for getting this job done? > >VLV >Just delete me from this website then! I am not student. I just want to learn. and what a racist to insult people like this. You are clever on this topic doesn't mean people who don't have knowledge on the topic you are keen on, is stupid. Because it shows that you are more stupid. Just delete me, delete all my posts PLEASE!
Reply by ●September 23, 20112011-09-23
>> >> >>mackenfy wrote: >> >>> can someone please help me. I need to fix this very soon. pleasee >> >>How much are you willing to pay for getting this job done? >> >>VLV >> > >Just delete me from this website then! I am not student. I just want to >learn. and what a racist to insult people like this. You are clever onthis>topic doesn't mean people who don't have knowledge on the topic you are >keen on, is stupid. Because it shows that you are more stupid. Justdelete>me, delete all my posts PLEASE! >Hi Had a glance at your channel Model. Assuming rest you have done is fine, your Channel Model is incorrect. Channel Modelling is not as simple as what you have done. In order to check you BER curve, use Matlab inbuilt channel model. If you get nice bell curve, it means your rest of the chain is fine and will also prove your model is incorrect. You can read some of the books on fading channel modelling for details on how to model a Rayleigh/Ricing faded channel. Regards Hozefa
>>> >>> >>>mackenfy wrote: >>> >>>> can someone please help me. I need to fix this very soon. pleasee >>> >>>How much are you willing to pay for getting this job done? >>> >>>VLV >>> >> >>Just delete me from this website then! I am not student. I just want to >>learn. and what a racist to insult people like this. You are clever on >this >>topic doesn't mean people who don't have knowledge on the topic you are >>keen on, is stupid. Because it shows that you are more stupid. Just >delete >>me, delete all my posts PLEASE! >> > >Hi > >Had a glance at your channel Model. Assuming rest you have done is fine, >your Channel Model is incorrect. Channel Modelling is not as simple aswhat>you have done. In order to check you BER curve, use Matlab inbuiltchannel>model. If you get nice bell curve, it means your rest of the chain isfine>and will also prove your model is incorrect. > >You can read some of the books on fading channel modelling for details on >how to model a Rayleigh/Ricing faded channel. > >Regards >Hozefa >Hi Also your impulse reponse is modelled wrongly. You are using the same to equalize at the receiver. There is too much to explain to tell you why it is wrong. Only a book on channel modeling will help you. If you have queries in understanding the book, you can post it step by step. I will try to help Regards Hozefa
Few tips: 1. Do not add any channel effect, just use the clean signal and if you can get all your bits at the receiver. 2. Start with BPSK (specially when you are learning). It makes life easier. 3. Then add some WGN noise. And run your receiver. 4. Add some ISI. It can be done in just one line of command. 5. Then go for higher order modulation. This might seem a long process but there is ano other alternative. Hope this helps. Chintan
Reply by ●April 4, 20142014-04-04
