On Fri, 25 Nov 2011 16:36:14 +0200, valtih1978 wrote:> Why understanding the difference between white spectrum and white noise > is a bad idea?Why is a raven like a writing desk? -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.
Unit pulse for White noise
Started by ●November 2, 2011
Reply by ●November 25, 20112011-11-25
On Fri, 25 Nov 2011 19:10:04 +0000 (UTC), Rob Gaddi <rgaddi@technologyhighland.invalid> wrote:>On Fri, 25 Nov 2011 16:36:14 +0200, valtih1978 wrote: > >> Why understanding the difference between white spectrum and white noise >> is a bad idea? > >Why is a raven like a writing desk?Because there is a B in both and an N in neither.>-- >Rob Gaddi, Highland Technology -- www.highlandtechnology.com >Email address domain is currently out of order. See above to fix.Eric Jacobsen Anchor Hill Communications www.anchorhill.com
Reply by ●November 26, 20112011-11-26
On Fri, 25 Nov 2011 16:36:14 +0200, valtih1978 wrote:> Why understanding the difference between white spectrum and white noise > is a bad idea?Who said it was? For that matter, who said that white noise doesn't have a white power spectral density? -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 25 Nov, 18:26, robert bristow-johnson <r...@audioimagination.com> wrote:> On 11/25/11 9:36 AM, valtih1978 wrote: > > > Why understanding the difference between white spectrum and white noise > > is a bad idea? > > can you tell us what the difference is? > > i can tell you that, from the point-of-view of audio, white noise sounds > line one thing and a dirac impulse sounds like another. > > so why are their spectrums *ostensibly* the same flat line? > > the answer is that the power spectrum of white noise does not (and can > not) have phase information. �the phase information is random (which > changes for each statistical "sample" of the noise), just as the white > noise is. �the Fourier spectrum of a dirac impulse *does* have > well-defined phase information which is zero-phase everywhere. > > but this skips over the subtleties of the different classes of the two > signals. �white noise (if you were to bandlimit it to some finite > bandwidth) is an infinite energy and finite power signal. �so how you > define its spectrum must necessarily be different than how you define > the spectrum of a finite energy signal which is what an impulse (if you > also limit the height and width of the nascent impulse). > > finite energy signals happen sorta once. �they go "blap" and then > they're done. �infinite energy, finite power signals go on and on and > on. �so they cannot be compared directly. > > in addition (as i parenthetically noted above) both white noise and > dirac impulses are mathematical idealizations of signals that are > physically nonexistent. �white noise, having infinite bandwidth, > actually has infinite power, not finite power. �dirac impulses have zero > width and infinite height, real mathematicians refuse to recognize the > dirac delta function as a "function" in the strict mathematical sense of > the word. > > so valtih, if you can understand those three different classes of what > is different (moving from the most immediate practical difference on to > the most esoteric fine points), then you might have some idea of what it > is that you are pondering.There is one more subtlety that one needs to be aware of: When dealing with stochastic signals, one does not deal wit the DFT of the signal itself, but the DFT of the *autocorrelation* of the signal. From a mathematical point of view, this is taken care of by the distinction between energy and power signals. The consequence is that phase information is *lost* when computing the power spectrun (which is a different thing than the DFT) of stochastic signals. Again: The phase is *not* 0, it is *lost*. Simplified, the power spectrum S_xx(w) is compted from the FT X(w) of the signal x(t) as ('simplified' because certain technical issues with the DFT has to be addressed during actual computations) S_xx(w) = |X(w)|^2 = X(w)*conj(X(w)) X(w) might well have a non-vanishing imaginary component but S_xx(x) is still real-valued. Rune
On Fri, 25 Nov 2011 19:10:04 +0000 (UTC), Rob Gaddi <rgaddi@technologyhighland.invalid> wrote:> On Fri, 25 Nov 2011 16:36:14 +0200, valtih1978 wrote: > >> Why understanding the difference between white spectrum and white noise >> is a bad idea? > > Why is a raven like a writing desk?They're both examples of poe conductors? Frank McKenney -- Fortunately, man was given a sense of humor to help compensate for nature's law of gravity. -- Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney aatt mindspring ddoott com
Reply by ●November 27, 20112011-11-27
As explained in discussion: White noise in frequency domain =/= noise spectrum The spectrum of white noise is obtained in two steps: 1. By Computing the auto-correlation of noise. <= this turns out to look like an impulse due to certain mathematical properties of noise. 2. By Computing FT of result of step 1. <= since the result of step 1 turns out to be like an impulse therefore its FT should be a constant 1. "They" whoever they are, do not use complex generators to generate a single pulse (impulse function), they use it to generate a sequence who's autocorrelation will be an impulse function.
