On Mon, 14 Nov 2011 17:42:53 +0200, Tauno Voipio <tauno.voipio@notused.fi.invalid> wrote: [Snipped by Lyons]> >Get a good book, e.g. > > Richard G. Lyons, Understanding Digital Signal Processing > >read and understand it, and return with follow-up questions >after that.Hello Tauno, if you send an E-mail to me telling me which Edition, and which Printing Number, of my book that you have, I'll send you the book's errata. See Ya', [-Rick-]
[FFT] Why is the performance so important?
Started by ●November 14, 2011
Reply by ●November 15, 20112011-11-15
Reply by ●November 16, 20112011-11-16
I'm an audio guy, but one possible application would be texture recognition in images. This requires a 2-D FFT, and scale that to any reasonably sized image, and you can see where having a *very* tight FFT would be critical. On Nov 14, 9:23�am, "Caspian" <matrose@n_o_s_p_a_m.me.com> wrote:> >Caspian wrote: > > >> Hello DSP pros, > > >> I'm currently working on an optimized version of FFT for ARM NEON. > (FHT, > >> to be exact.) > > >> I'm neither a DSP specialist nor mathematician, and it was very hard > for > >> me to understand the way FFT works. > > >> Now it's about 50% done, and I have my doubt about this : "What's the > use > >> of this? What does it bring when my FFT runs 20times faster than some > >> unnamed opensource ones on handhelds?" > > >If you don't know why performance is important than it's probably not > important. > >If you do this work because someone asked you to do it than you must ask > this > >person why it pays you to improve performance. > > >> I really don't see any point int this. Maybe because I know too little > >> about DSP. > > >Better performance could reduce power consumption. > > >bye > >Andreas > >-- > >Andreas H nnebeck | email: a...@gmx.de > >----- privat ---- | www �:http://www.huennebeck-online.de > >Fax/Anrufbeantworter: 0721/151-284301 > >GPG-Key:http://www.huennebeck-online.de/public_keys/andreas.asc > >PGP-Key:http://www.huennebeck-online.de/public_keys/pgp_andreas.asc > > Usually I'm the one in the company asking for the last bit of performance. > :) > I've been working mostly on graphics and image processing where the > performance increases were literally visible. > > But FFT..... I simply know too little about its field of application. > > Any idea where heavily FFT'ing large blocks would be necessary on > handhelds? > > cya > > PS : Deutsch kann ich auch, sogar besser als Englisch. Die sind aber beide > Fremdsprachen fuer mich. Vielen Dank.
On Mon, 14 Nov 2011 07:22:46 -0600, Caspian wrote:> I'm currently working on an optimized version of FFT for ARM NEON. (FHT, > to be exact.) > > I'm neither a DSP specialist nor mathematician, and it was very hard for > me to understand the way FFT works. > > Now it's about 50% done, and I have my doubt about this : "What's the > use of this? What does it bring when my FFT runs 20times faster than > some unnamed opensource ones on handhelds?" > > I really don't see any point int this. Maybe because I know too little > about DSP. > > Could someone enlighten me? It would be really great to be motivated > again.Many of the machines with ARM chips in them spend a lot of their time playing (or, sometimes, recording) music, or watching videos. Most of the popular audio codecs operate in the frequency domain (usually MDCT or CQMF or both), so decoding those bitstreams always finishes with a frequency->time domain transform. Most such transforms can be expressed as twiddles around FFT routines, so if you have a fast FFT you also have a fast MDCT or CQMF or whatever. Since the transform part of a decoder usually represents a good 30% or more of the work required for the decode, shaving a lump of that off will translate directly to extended battery life for the media-consuming device user. Go nuts! Cheers, -- Andrew
Reply by ●November 18, 20112011-11-18
