Viterbi Input, Branch Metrics, and the TI VCU
Started by Randy Yates November 29, 2011
What is the input to the (hard-output) Viterbi decoder, and how is a
branch metric computed?
Here are what I think are the correct answers:
Inputs:
The inputs are either hard bits (i.e., x_n \in {-1, +1}) or soft bits
(i.e., x_n \in [-1, +1]), depending on the Viterbi implementation.
Branch Metrics:
If the inputs are hard bits, then the 2^N branch metrics for a rate 1/
N code are the 2^N Hamming distances between the N demodulated bits
and the 2^N possible values for those N bits.
If the inputs are soft bits, then the 2^N branch metrics for a rate 1
/ N code are the 2^N Euclidean distances
   d_m = \sqrt{\sum_{n = 0}{N - 1} (x_n - xideal_m_n)^2}.
Nowhere here are logarithms used. The problem I'm having is that some
folks that I work with are calling the inputs LLRs, "Log-Likelihood
Ratios," and I see no mention of LLRs in conjunction with plain,
vanilla (i.e., non-soft-output) Viterbi decoders.
Another quandary I'm having is regarding the VCU (Viterbi/Complex
Unit) used in TI's Piccolo series of MCUs. It appears that this
hardware computes N branch metrics instead of 2^N, one for each bit.
Can anyone reconcile this with the (supposedly correct) answer above
that there are 2^N branch metrics?
Hints/suggestions/pointers/comments would be welcome.
--Randy
On 29 Nov, 14:29, Randy Yates <ya...@digitalsignallabs.com> wrote:
> Nowhere here are logarithms used. The problem I'm having is that some > folks that I work with are calling the inputs LLRs, "Log-Likelihood > Ratios," and I see no mention of LLRs in conjunction with plain, > vanilla (i.e., non-soft-output) Viterbi decoders.
Log-likelihood ratios usually occur in detection problems. The normal probability functions is expressed as N(u,s) ~ G(u,s) exp( F(u,s) ) where u is the mean and s is the variance or standard deviation, which is hard to anlyze analytically. Taking the logaritm of the distribution gives LN(u,s) ~ log( G(u,s) ) + F(u,s) which might be easier to analyze, particularly since G(u,s) oftend depend only on s. In detection problems one usually are interested in detecting differences in means, in which case the above simplifies to LN(u,s) ~ constant + F(u,s). If you now want to investigate if there is a difference of the means of two different samples (i.e. if the distance between them is non-vanishing), you can do that by analyzing the difference D(x1,x2) = F(u1,s) - F(u2,s). which is a tractable analytic problem, compared to working directly with the distribution fundtions. Or maybe that last one should be the ratio d(x1,x2) = F(u1,s)/F(u2,s) (I don't remember off the top of my head if LLR means 'log of a likelihood ratio' or 'ratio of log likelihoods'). Rune
On Tue, 29 Nov 2011 07:29:16 -0600, Randy Yates
<yates@digitalsignallabs.com> wrote:
>Viterbi Input, Branch Metrics, and the TI VCU > >What is the input to the (hard-output) Viterbi decoder, and how is a >branch metric computed? > >Here are what I think are the correct answers: > >Inputs: > >The inputs are either hard bits (i.e., x_n \in {-1, +1}) or soft bits >(i.e., x_n \in [-1, +1]), depending on the Viterbi implementation. > >Branch Metrics: > >If the inputs are hard bits, then the 2^N branch metrics for a rate 1/ >N code are the 2^N Hamming distances between the N demodulated bits >and the 2^N possible values for those N bits. > >If the inputs are soft bits, then the 2^N branch metrics for a rate 1 >/ N code are the 2^N Euclidean distances > > d_m = \sqrt{\sum_{n = 0}{N - 1} (x_n - xideal_m_n)^2}. > >Nowhere here are logarithms used. The problem I'm having is that some >folks that I work with are calling the inputs LLRs, "Log-Likelihood >Ratios," and I see no mention of LLRs in conjunction with plain, >vanilla (i.e., non-soft-output) Viterbi decoders. > >Another quandary I'm having is regarding the VCU (Viterbi/Complex >Unit) used in TI's Piccolo series of MCUs. It appears that this >hardware computes N branch metrics instead of 2^N, one for each bit. >Can anyone reconcile this with the (supposedly correct) answer above >that there are 2^N branch metrics? > >Hints/suggestions/pointers/comments would be welcome. > >--Randy
Google "Viterbi LLR" or something like that and you'll get a lot of references. Starting from scratch if one does the derivations of what's going mathematically it is frequently done where the inputs to a soft-decision decoder wind up being LLRs. Since that's a popular mathematical treatment (especially for things like Turbo Codes or other iterative decoders) the soft inputs are often called LLRs. But they don't have to be. Lots of people just call them "soft decision" inputs, which is arguably as common and not incorrect. It's another one of those cases where disparate terms and points of view are talking about the exact same thing. So I just use the "soft decision" and "LLR" terms regarding decoder inputs interchangeably, although if one wants to get picky LLRs are really a subset of "soft decision" techniques. And don't worry about implementing them differently, either. ;) Eric Jacobsen Anchor Hill Communications www.anchorhill.com
Randy Yates wrote:
> Viterbi Input, Branch Metrics, and the TI VCU > > What is the input to the (hard-output) Viterbi decoder, and how is a > branch metric computed?
Viterbi decoder is a (sub optimal) path search algorithm in a graph. What is the input and how the cost is computed depends on application.
Nope.
> Inputs: > > The inputs are either hard bits (i.e., x_n \in {-1, +1}) or soft bits > (i.e., x_n \in [-1, +1]), depending on the Viterbi implementation.
> Branch Metrics: > > If the inputs are hard bits, then the 2^N branch metrics for a rate 1/ > N code are the 2^N Hamming distances between the N demodulated bits > and the 2^N possible values for those N bits.
Wrong. In the binary case, there are 2^N branch metrics for the code with the memory of N. It has nothing to do with the rate of the code.
> If the inputs are soft bits, then the 2^N branch metrics for a rate 1 > / N code are the 2^N Euclidean distances > > d_m = \sqrt{\sum_{n = 0}{N - 1} (x_n - xideal_m_n)^2}.
Wrong. For AWGN and mininum BER, optimim metrics is distance squared.
LLRs are the technical trick to simplify the computation of conditional probabilities (used with the optimal decoding algorithms). You can add logariphms instead of multiplying raw probabilities.
> Another quandary I'm having is regarding the VCU (Viterbi/Complex > Unit) used in TI's Piccolo series of MCUs. It appears that this > hardware computes N branch metrics instead of 2^N, one for each bit.
Huh?
> Can anyone reconcile this with the (supposedly correct) answer above > that there are 2^N branch metrics?
Read the datasheet.
Get a clue how Viterbi algorithm works? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Nov 29, 8:29&#2013266080;am, Randy Yates <ya...@digitalsignallabs.com> wrote:
Randy: I thought at each stage, the trellis for a rate-(1/N) code has 2^{m} nodes where the code has constraint length m+1, with each node having 2 outgoing branches connecting to the next stage, and having two incoming branches from nodes at the previous stage. It is essentially a rolling out of what used to be studied once upon a time as the state transition diagram of a sequential machine. The nodes at each stage are labeled with the 2^n possible contents of the transmitter shift register. The two branches leaving a node are labeled as 0/X and 1/Y where X and Y are N-bit vectors -- the transmitted bits corresponding to input data bits 0 and 1 respectively when the transmitter shift register contents are the node label. The branch metrics for the branches are the Hamming distances between X and Z, and between Y and Z, where Z is the N-bit received vector corresponding to that particular *data* bit. The nice thing is that the Hamming distance is additive (just as the log likelihood is for soft decision decoding; the branch metrics are taken as the log likelihood of the soft-decision vector Z for parameters X and Y respectively.) In particular, there are only 2^{m+1} branches from the n-th stage to the (n+1)-th stage, and so, for, say, a rate 1/5 code of constraint length 3, there are not 32 branches to be labeled with the 32 possible 5-bit binary vectors. --Dilip Sarwate
On 11/29/2011 01:21 PM, dvsarwate wrote:
 > On Nov 29, 8:29 am, Randy Yates<ya...@digitalsignallabs.com>  wrote:
 >> Branch Metrics:
 > Randy:
Dilip,
Thank you for your gentle guidance. Your corrections on the number of
states and the trellis architecture are of course correct. I'm not
sure why I made such a gross error in this post. It's probably best to
just admit I made a mistake and move on.
However, I am still unclear regarding your explanation of the log
likelihood:
I certainly see that log(x * y) = v + w, and that if we actually had
metrics that were probabilities, working with their logs would allow
us to determine the optimal path through the trellis via addition.
What I don't understand is why the branch metrics are NECESSARILY log
likelihoods. To be fair, you said they are "taken" as the log
likelihod. Perhaps this is the very crux of the matter (for me).
In our case, the inputs are simply the values out of the (FSK)
demodulator - there is no log function applied to them - and the
metrics are simple Euclidean distance. So they aren't log likelihoods.
Has it been shown somewhere that such metrics are equivalent to log
likelihoods for the purposes of establishing the most likely path
through the trellis?
Further, our system engineers are calling the _inputs_ to the Viterbi
decoder "LLRs" - NOT the branch metrics. And LLRs are "log likelihood
RATIOS", not simply log likelihoods. So none of this makes sense to me.
I would appreciate any further insight you might have into this, and
hope you are willing to share it.
--Randy
