Hi all, I am trying to compute the FFT of signal using the integer FFT method. In this I am able to represent the twiddle factors in sum of powers of two, to do the multiplication operations using the shift and addition operations. Example how to multiply 0.7071 with 0.255 using shift and addition operators only by representing the data in binary form. But the thing is I am not able to get the proper results of multiplications, as I am getting in the fraction multiplication. Here I am getting some precision error. To compensate this error do I need to add the extra value. If yes how to do that one. If any one know about this, please help me. Eagerly waiting for your replay. Thanking you in advance.
Re: Integer FFT
Started by ●January 10, 2012
Reply by ●January 10, 20122012-01-10
On 1/10/2012 7:17 AM, Sangamanath Kalashetty wrote:> Hi all, > > I am trying to compute the FFT of signal using the integer FFT method. > In this I am able to represent the twiddle factors in sum of powers of > two, to do the multiplication operations using the shift and addition > operations. > Example how to multiply 0.7071 with 0.255 using shift and addition > operators only by representing the data in binary form. > > But the thing is I am not able to get the proper results of > multiplications, as I am getting in the fraction multiplication. Here > I am getting some precision error. > To compensate this error do I need to add the extra value. If yes how > to do that one. > > If any one know about this, please help me. > > Eagerly waiting for your replay. > Thanking you in advance.I don't usually respond to private emails that ought to have been posted to the group, but I did respond to yours. I hope you find the response helpful. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 1/10/12 7:17 AM, Sangamanath Kalashetty wrote:> Hi all, > > I am trying to compute the FFT of signal using the integer FFT method. > In this I am able to represent the twiddle factors in sum of powers of > two, to do the multiplication operations using the shift and addition > operations. > Example how to multiply 0.7071 with 0.255 using shift and addition > operators only by representing the data in binary form. >by "binary form", you mean as a 2's complement integer, right? one of your numbers is a coefficient (i'll bet it's the 0.7071) and the other is a signal (the 0.255). if W is the word width in bits, then to do this with scaled integers, you must first decide what the *range* of your coefficients and signals are. for the moment i will assume that both have range of -1 <= x < 1. then the integer version has range of -2^(W-1) <= X < 2^(W-1) . so what that means is that X = x * 2^(W-1) and x = X * 2^(1-W) make the same definition for the number y and it's scaled integer version, Y. then as what is x times y? x*y = X * 2^(1-W) * Y * 2^(1-W) = X*Y * 2^(2-2W) we know that x*y is also constrained to be between -1 and +1 and we want the product to also have a scaled integer version just like x and y have. that is what we want is: x*y * 2^(W-1) that is the answer we want. so you plug and chug and get: x*y * 2^(W-1) = X*Y * 2^(1-W) so you take your two integer values and multiply them together. make sure the product register or variable has enough bits (2W). if you're doing this in C, multiplying two longs together should be a long long and you will have to cast one of the values to long long first, before multiplying (that is a deficit in the C language, in my opinion). then after multiplying you have to arithmetic shift the result to the right by W-1 bits (which is the same as multiplying be 2^(1-W)) and take your result out of the lowest W bits. if you want to round to the nearest, you must first add something like 2^(W-2) to the result because shifting right always truncates. another method to deal with rounding is to add a random number that ranges from 0 to just under 2^(W-1) (we call that "dither") or to save the bits that you are dropping and add them in the next time (but i am not sure how you do that for an FFT). some of us call that "fraction saving" and it is a form of noise shaping or error shaping.> But the thing is I am not able to get the proper results of > multiplications, as I am getting in the fraction multiplication. Here > I am getting some precision error.need more bits.> To compensate this error do I need to add the extra value. If yes how > to do that one. > > If any one know about this, please help me.simple matter of scaling and integer arithmetic. the rounding makes it slightly more complicated, but not much. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●January 11, 20122012-01-11
On Jan 10, 12:17�pm, Sangamanath Kalashetty <pintu2...@gmail.com> wrote:> Hi all, > > I am trying to compute the FFT of signal using the integer FFT method. > In this I am able to represent the twiddle factors in sum of powers of > two, to do the multiplication operations using the shift and addition > operations. > Example how to multiply 0.7071 with 0.255 using shift and addition > operators only by representing the data in binary form. > > But the thing is I am not able to get the proper results of > multiplications, as I am getting in the fraction multiplication. Here > I am getting some precision error. > To compensate this error do I need to add the extra value. If yes how > to do that one. > > If any one know about this, please help me. > > Eagerly waiting for your replay. > Thanking you in advance.Think of it like this: 0.7071 X 10^4 X 0.255 X 10^3 = 0.7071 X 0.255 X 10^7 right? So whatever the result you have to divide by 10^7 or multiply by 10^-7 to get the correct answer 0.7071 X 10^4 X 0.255 X 10^3 = 7071 X 255 = 1803105 apply the 10^-7 factor leaves 0.1803105 All you have to do is repeat this using binary arithmetic and you are somewhere along the way to understanding what fixed point arithmetic is all about. A couple of golden rules: 1. You can multiply any two numbers which have different scaling factors applied (like the above example) 2. It is only meaningful to add numbers if they have the SAME scaling factor (try it) I'm afraid as others have said, you have to go through the basics of fixed point arithmetic before you can think about an application such as the FFT algorithm.
