To demodulate QPSK requires a carrier recovery circuit.Without a recovered and properly phased carrier it is not possible to demodulate the I and Q channels. In the analog world there are circuits like the squaring ckt or the Costas Loop which recovers the carrier. However--modern QPSK radios use DSP to demodulate a non-coherent received signal. By non-coherent I mean that the carrier frequency is not precisely known nor is its phase. Nevertheless, such a signal can be sampled via an ADC and sent to DSP for demodulation into separate I and Q data streams. i think polyphase filters are used--and I have a vague idea of how they work. Can anyone explain, in non-methematical terms, what is being done to the non-coherent QPSK signal so that it gets demodulated???
QPSK demodulation using dsp
Started by ●February 22, 2012
Reply by ●February 22, 20122012-02-22
I'd distinguish between two independent problems, on two different time scales: - carrier frequency offset: If the local oscillator frequencies of receiver and transmitter don't match, the difference frequency appears as periodic rotation of the complex baseband signal. Estimate the mismatch in terms of constant and linear term in time, generate a rotating unity phasor that spins in the opposite direction and multiply. - symbol timing: You need to sample at the correct time instant, when the trajectory is closest to the constellation points and the eye opening is widest. Now this can be done with a polyphase filter, which is able to delay (but not rotate) the baseband signal by a fraction of a sample. If the signal is oversampled high enough, say, 10 samples per symbol, you can probably manage without, as 1/10 of a sample duration near the optimum sampling instant may be close enough.
On Wed, 22 Feb 2012 14:23:12 -0600, "pgdragone" <philip.dragonetti@n_o_s_p_a_m.L-3com.com> wrote:>To demodulate QPSK requires a carrier recovery circuit.Without a recovered >and properly phased carrier it is not possible to demodulate the I and Q >channels. > >In the analog world there are circuits like the squaring ckt or the Costas >Loop which recovers the carrier. > >However--modern QPSK radios use DSP to demodulate a non-coherent received >signal. By non-coherent I mean that the carrier frequency is not precisely >known nor is its phase. Nevertheless, such a signal can be sampled via an >ADC and sent to DSP for demodulation into separate I and Q data streams. > >i think polyphase filters are used--and I have a vague idea of how they >work. > >Can anyone explain, in non-methematical terms, what is being done to the >non-coherent QPSK signal so that it gets demodulated???If the signal is differentially modulated then the demodulator uses the symbol-to-symbol phase difference rather than the absolute phase. In this case it is not required to lock phase or frequency, but some performance is lost as a result. Frequency uncertainty must be low enough for this to work, though. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
