Guys (Gals:), I've changed the domain of my website containing some article on DSP: http://www.strauss-acoustics.ch/ (previously www.philou.ch) contains : Pure javascript HTML5 canvas bilinear image interpolation Easy to read C Fast Fourier Transform (FFT) signal processing code FIR filter design experiment using the simplex method Z�lzer-Boltze (ZB) peak/notch parametric EQ in C An Objective Caml, object based computation pipeline pattern Regards.
three DSP article
Started by ●February 24, 2012
Reply by ●February 25, 20122012-02-25
On Fri, 24 Feb 2012 07:35:19 -0800 (PST), Philippe Strauss <friendship7net@gmail.com> wrote:>Guys (Gals:), > >I've changed the domain of my website containing some article on DSP: > >http://www.strauss-acoustics.ch/ > >(previously www.philou.ch) > >contains : > >Pure javascript HTML5 canvas bilinear image interpolation >Easy to read C Fast Fourier Transform (FFT) signal processing code >FIR filter design experiment using the simplex method >Z�lzer-Boltze (ZB) peak/notch parametric EQ in C >An Objective Caml, object based computation pipeline pattern > >Regards.Hello Philippe Strauss, Can you please tell me, is it possible to make your FFT C code run on a 16-bit, fixed-point, microcontroller chip? Thanks, [-Rick-]
On 25 f�v, 10:44, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:> On Fri, 24 Feb 2012 07:35:19 -0800 (PST), Philippe Strauss > > > > > > > > > > <friendship7...@gmail.com> wrote: > >Guys (Gals:), > > >I've changed the domain of my website containing some article on DSP: > > >http://www.strauss-acoustics.ch/ > > >(previouslywww.philou.ch) > > >contains : > > >Pure javascript HTML5 canvas bilinear image interpolation > >Easy to read C Fast Fourier Transform (FFT) signal processing code > >FIR filter design experiment using the simplex method > >Z�lzer-Boltze (ZB) peak/notch parametric EQ in C > >An Objective Caml, object based computation pipeline pattern > > >Regards. > > Hello Philippe Strauss, > � �Can you please tell me, is it possible to > make your FFT C code run on a 16-bit, fixed-point, > microcontroller chip? > > Thanks, > [-Rick-]Rick, No I haven't any fixed point or integer target in head when coding it, but given that it's a plain radix2 or 4 as found in references books on the topic, and relatively readable, maybe someone with such interest could add scaling between each butterfly loops relatively easily. Regards.
Reply by ●February 27, 20122012-02-27
On 2/25/12 5:41 AM, Philippe Strauss wrote:> On 25 f�v, 10:44, Rick Lyons<R.Lyons@_BOGUS_ieee.org> wrote: >> On Fri, 24 Feb 2012 07:35:19 -0800 (PST), Philippe Strauss >> >> >> >> >> >> >> >> >> >> <friendship7...@gmail.com> wrote: >>> Guys (Gals:), >> >>> I've changed the domain of my website containing some article on DSP: >> >>> http://www.strauss-acoustics.ch/ >> >>> (previouslywww.philou.ch) >> >>> contains : >> >>> Pure javascript HTML5 canvas bilinear image interpolation >>> Easy to read C Fast Fourier Transform (FFT) signal processing code >>> FIR filter design experiment using the simplex method >>> Z�lzer-Boltze (ZB) peak/notch parametric EQ in C >>> An Objective Caml, object based computation pipeline pattern >> >>> Regards. >> >> Hello Philippe Strauss, >> Can you please tell me, is it possible to >> make your FFT C code run on a 16-bit, fixed-point, >> microcontroller chip? >> >> Thanks, >> [-Rick-] > > Rick, > > No I haven't any fixed point or integer target in head when coding it, > but given that it's a plain radix2 or 4 as found in references books > on the topic, and relatively readable, maybe someone with such > interest could add scaling between each butterfly loops relatively > easily.you mean, between the FFT passes, right? for a simple radix2 tukey-cooley FFT, there are log2(N) passes (where N is the number of FFT points). this is called "block floating point". the whole idea is that your fixed point data goes into each pass scaled to have an additional *2* guard bits on the left (the signed integer data would have the 3 MSBs identical). this means that the magnitude of the numbers are no more than 1/4 full scale. (audio guys would say it has 12 dB of headroom.) so imagine your complex number as lying in a square of with each side of width 1/4 full scale. multiplying by the DFT twiddle factor will only rotate the complex number which *could* increase the real or imaginary part by a factor sqrt(2). then you add it to another complex number in the butterfly. so the worst-case growth of either the real or imaginary values coming outa the butterfly is 1/4 + sqrt(2) * 1/4 = 0.604 so you are not going to overflow. or if the butterfly is the other gender (decimation-in-time vs. decimation-in-frequency, i can't remember which is which), then the complex numbers are added before scaling with the twiddle factor. then the worst case growth is sqrt(2) * (1/4 + 1/4) = 0.707 so, in block floating point, you need to test each result to see if it has exceeded 1/4 full scale, and if it has, you set a bit that tells you for the next pass, you must divide the result of the butterfly by 2 (and increase the block exponent by 1 to keep the bookkeeper happy). i realize that looking at this doesn't seem to guarantee against overflow in the worst case because 0.604 and 0.707 both exceed 0.5, but i know that this is how the block-floating FFT was supposed to work for the Mot (now Freescale) DSP56xxx chips. if any result exceeded 1/4 in magnitude, a sticky bit was set that would tell you to change the scaling in the next pass. it appears to me that it would possibly fail in preventing overflow and saturation given some data that was set up to the worst case. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
