Hi all, I have a need to sample audio from my sound card and process it. However, the hardware I am processing it on works faster in complex domain than real domain. I know this may sound funny, but it is true. Read on... In essence, I need to convert a real stream sampled at N to a complex stream sampled at N/2. Not sure what the best way to do this is or if it can even be done. Here are the ways I have been told by others to accomplish this. Are these correct? 1. To keep the N samp rate.. i can have two sensors, both sampling at N but one sensore 90 degrees out of phase when sampling. I believe this is the best way to get complex data, but dont have the capabilities to do this in my system. 2. Sample at N and get a stream of reals. Perform the Hilbert Transform to get N/2 complex samples. Not sure of what a Hilbert transform does...I though it takes your signal and makes it 90 degrees out of phase.. this brings me to the third solution. 3. Sample reals at N. Perform Hilbert transform to shift wave by 90 degree.... Mix hilbert transform with reals to get a samp freq of N. Looks like this output = reals + j*Hilbert_XForm 4. Sample reals at N. Then, make every 4 samples the real part (position 1)... and the samples at positions 2 the complex part.. thus those are 90 degees of the sampling frequency N/4. Discard parts 3 and 4 of the N samples. This has me downsampling to N/4 which isnt a problem bth. N -> 1 90 180 270 1 N/4 -> 1 2 3 4 keep Q discard discard Any help appreciated it! Isaac
Real To Complex Stream Conversion
Started by ●October 1, 2004
Reply by ●October 1, 20042004-10-01
Hi Isaac. Isaac> Hi all, I have a need to sample audio from my sound card and Isaac> process it. However, the hardware I am processing it on works Isaac> faster in complex domain than real domain. I know this may Isaac> sound funny, but it is true. Read on... Isaac> In essence, I need to convert a real stream sampled at N to a Isaac> complex stream sampled at N/2. Not sure what the best way to Isaac> do this is or if it can even be done. Isaac> Here are the ways I have been told by others to accomplish Isaac> this. Are these correct? Isaac> 1. To keep the N samp rate.. i can have two sensors, both Isaac> sampling at N but one sensore 90 degrees out of phase when Isaac> sampling. I believe this is the best way to get complex data, Isaac> but dont have the capabilities to do this in my system. Isaac> 2. Sample at N and get a stream of reals. Perform the Hilbert Isaac> Transform to get N/2 complex samples. Not sure of what a Isaac> Hilbert transform does...I though it takes your signal and Isaac> makes it 90 degrees out of phase.. this brings me to the third Isaac> solution. Isaac> 3. Sample reals at N. Perform Hilbert transform to shift wave Isaac> by 90 degree.... Mix hilbert transform with reals to get a samp Isaac> freq of N. Looks like this output = reals + j*Hilbert_XForm Isaac> 4. Sample reals at N. Then, make every 4 samples the real Isaac> part (position 1)... and the samples at positions 2 the complex Isaac> part.. thus those are 90 degees of the sampling frequency N/4. Isaac> Discard parts 3 and 4 of the N samples. This has me Isaac> downsampling to N/4 which isnt a problem bth. N -> 1 90 180 Isaac> 270 1 N/4 -> 1 2 3 4 keep Q discard discard What you are looking for is the down-sampled analytical signal. The analytical signal relates to the Hilbert transform as you describe in 3. :-) That people tell you to perform the Hilbert Transform to get the so-called analytic signal is wrong, and maybe MATLAB is partly to blame for this since hilbert() calculates the analytic signal and not the Hilbert transform. Having calculated the analytic signal as x_a(n)=x_r(n)+j*H(x_r(n)) with H() being the Hilbert Transform and x_r(n) your original real input, you just need to downsample x_a(n) by a factor of 2, i.e. discard every other sample. For more details, have a look at S. L. Marple Jr., "Computing the discrete-time "Analytic" signal via FFT," IEEE Trans. Signal Processing, vol. 47, pp. 2600 - 2603, September 1999. -- /Mads (http://kom.aau.dk/~mgc)
"Isaac Gerg" <isaacgerg@psu.edu> wrote in message news:cjjjla$vhm$1@f04n12.cac.psu.edu...> Hi all, > I have a need to sample audio from my sound card and process it. > However, the hardware I am processing it on works faster in complex domain > than real domain. I know this may sound funny, but it is true. Read on... > > In essence, I need to convert a real stream sampled at N to a complex > stream sampled at N/2. Not sure what the best way to do this is or if it > can even be done. > > Here are the ways I have been told by others to accomplish this. Are > these correct? > > 1. To keep the N samp rate.. i can have two sensors, both sampling at N > but one sensore 90 degrees out of phase when sampling. I believe this is > the best way to get complex data, but dont have the capabilities to do > this in my system. > > 2. Sample at N and get a stream of reals. Perform the Hilbert Transform > to get N/2 complex samples. Not sure of what a Hilbert transform does...I > though it takes your signal and makes it 90 degrees out of phase.. this > brings me to the third solution. > > 3. Sample reals at N. Perform Hilbert transform to shift wave by 90 > degree.... Mix hilbert transform with reals to get a samp freq of N. Looks > like this output = reals + j*Hilbert_XForm > > 4. Sample reals at N. Then, make every 4 samples the real part (position > 1)... and the samples at positions 2 the complex part.. thus those are 90 > degees of the sampling frequency N/4. Discard parts 3 and 4 of the N > samples. This has me downsampling to N/4 which isnt a problem bth. > N -> 1 90 180 270 1 > N/4 -> 1 2 3 4 > keep Q discard discardI think you want to do quadrature sampling. As I recall, there's a neat trick regarding how to do this. It's described in Rick Lyon's book on DSP. What I remember is that the sampling in essence generates "I" samples on every other sample and "Q" samples on every other sample. Then maybe you consider these to be samples of the analytic signal (complex). Better read about it than listen further to me! Fred
So, you are saying that my number 3 is the correct means to proceed? Would you please comment on Fred Marshalls comment? Thanks for the help! Mads G. Christensen wrote:> Hi Isaac. > > Isaac> Hi all, I have a need to sample audio from my sound card and > Isaac> process it. However, the hardware I am processing it on works > Isaac> faster in complex domain than real domain. I know this may > Isaac> sound funny, but it is true. Read on... > > Isaac> In essence, I need to convert a real stream sampled at N to a > Isaac> complex stream sampled at N/2. Not sure what the best way to > Isaac> do this is or if it can even be done. > > Isaac> Here are the ways I have been told by others to accomplish > Isaac> this. Are these correct? > > Isaac> 1. To keep the N samp rate.. i can have two sensors, both > Isaac> sampling at N but one sensore 90 degrees out of phase when > Isaac> sampling. I believe this is the best way to get complex data, > Isaac> but dont have the capabilities to do this in my system. > > Isaac> 2. Sample at N and get a stream of reals. Perform the Hilbert > Isaac> Transform to get N/2 complex samples. Not sure of what a > Isaac> Hilbert transform does...I though it takes your signal and > Isaac> makes it 90 degrees out of phase.. this brings me to the third > Isaac> solution. > > Isaac> 3. Sample reals at N. Perform Hilbert transform to shift wave > Isaac> by 90 degree.... Mix hilbert transform with reals to get a samp > Isaac> freq of N. Looks like this output = reals + j*Hilbert_XForm > > Isaac> 4. Sample reals at N. Then, make every 4 samples the real > Isaac> part (position 1)... and the samples at positions 2 the complex > Isaac> part.. thus those are 90 degees of the sampling frequency N/4. > Isaac> Discard parts 3 and 4 of the N samples. This has me > Isaac> downsampling to N/4 which isnt a problem bth. N -> 1 90 180 > Isaac> 270 1 N/4 -> 1 2 3 4 keep Q discard discard > > What you are looking for is the down-sampled analytical signal. The > analytical signal relates to the Hilbert transform as you describe > in 3. :-) That people tell you to perform the Hilbert Transform to get > the so-called analytic signal is wrong, and maybe MATLAB is partly to > blame for this since hilbert() calculates the analytic signal and not > the Hilbert transform. Having calculated the analytic signal as > x_a(n)=x_r(n)+j*H(x_r(n)) with H() being the Hilbert Transform and > x_r(n) your original real input, you just need to downsample x_a(n) by > a factor of 2, i.e. discard every other sample. For more details, have > a look at > > S. L. Marple Jr., "Computing the discrete-time "Analytic" signal via > FFT," IEEE Trans. Signal Processing, vol. 47, pp. 2600 - 2603, > September 1999. >
Reply by ●October 2, 20042004-10-02
Hi Isaac. Isaac> So, you are saying that my number 3 is the correct means to Isaac> proceed? Would you please comment on Fred Marshalls comment? Yes, your number 3 is the way to do it. And you need to do downsampling by a factor of 2, i.e. drop every other sample. Usually, you would have to filter before the downsampling, but in this case, the spectrum is already half the bandwidth, so you don't need to in this case. Fred is probably saying the same thing I am, but using a different terminology. The I and Q terminology is often used in telecommunication, I think... -- /Mads (http://kom.auc.dk/~mgc)
Reply by ●October 5, 20042004-10-05
I don't think you need to change your sampling scheme at all. I think you just want to use the common trick of getting a N real FFT using a N/2 complex FFT. "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:2KydnZfpSfJAAsDcRVn-sw@centurytel.net...> > "Isaac Gerg" <isaacgerg@psu.edu> wrote in message > news:cjjjla$vhm$1@f04n12.cac.psu.edu... >> Hi all, >> I have a need to sample audio from my sound card and process it. >> However, the hardware I am processing it on works faster in complex >> domain than real domain. I know this may sound funny, but it is true. >> Read on... >> >> In essence, I need to convert a real stream sampled at N to a complex >> stream sampled at N/2. Not sure what the best way to do this is or if it >> can even be done. >> >> Here are the ways I have been told by others to accomplish this. Are >> these correct? >> >> 1. To keep the N samp rate.. i can have two sensors, both sampling at N >> but one sensore 90 degrees out of phase when sampling. I believe this is >> the best way to get complex data, but dont have the capabilities to do >> this in my system. >> >> 2. Sample at N and get a stream of reals. Perform the Hilbert Transform >> to get N/2 complex samples. Not sure of what a Hilbert transform >> does...I though it takes your signal and makes it 90 degrees out of >> phase.. this brings me to the third solution. >> >> 3. Sample reals at N. Perform Hilbert transform to shift wave by 90 >> degree.... Mix hilbert transform with reals to get a samp freq of N. >> Looks like this output = reals + j*Hilbert_XForm >> >> 4. Sample reals at N. Then, make every 4 samples the real part >> (position 1)... and the samples at positions 2 the complex part.. thus >> those are 90 degees of the sampling frequency N/4. Discard parts 3 and 4 >> of the N samples. This has me downsampling to N/4 which isnt a problem >> bth. >> N -> 1 90 180 270 1 >> N/4 -> 1 2 3 4 >> keep Q discard discard > > I think you want to do quadrature sampling. As I recall, there's a neat > trick regarding how to do this. It's described in Rick Lyon's book on > DSP. > > What I remember is that the sampling in essence generates "I" samples on > every other sample and "Q" samples on every other sample. Then maybe you > consider these to be samples of the analytic signal (complex). > > Better read about it than listen further to me! > > Fred >
Hi. Jerry> I don't think you need to change your sampling scheme at all. Jerry> I think you just want to use the common trick of getting a N Jerry> real FFT using a N/2 complex FFT. That depends on what he's trying to do. If he's just calculating the periodogram, then you are right. But I think he's trying to speed up some other processing by applying the down-sampled analytic signal. -- /Mads
Reply by ●October 7, 20042004-10-07
You are correct in your assumption. Mads G. Christensen wrote:> Hi. > > Jerry> I don't think you need to change your sampling scheme at all. > Jerry> I think you just want to use the common trick of getting a N > Jerry> real FFT using a N/2 complex FFT. > > That depends on what he's trying to do. If he's just calculating the > periodogram, then you are right. But I think he's trying to speed up > some other processing by applying the down-sampled analytic signal. >
Your assumption is correct. Mads G. Christensen wrote:> Hi. > > Jerry> I don't think you need to change your sampling scheme at all. > Jerry> I think you just want to use the common trick of getting a N > Jerry> real FFT using a N/2 complex FFT. > > That depends on what he's trying to do. If he's just calculating the > periodogram, then you are right. But I think he's trying to speed up > some other processing by applying the down-sampled analytic signal. >
