Hello everybody I am using DSK c6711 and I'm trying to program the flash memory. I started with the examples of TI. I am using flash.exe from : C:\ti\examples\dsk6711\board_util\flash\Host\Debug>flash post.hex and it gives me following message: TMS320C6211/6711 DSK Flash Programming Utility, Version 2.04, May 2001 Copyright (c) 2001 by Texas Instruments Incorporated. All rights reserved. ERROR: Please specify a valid board configuration file via the -f option. What is this configuration file ? Thanks in advance : Hamid
Urgent: Flash.exe problem
Started by ●November 20, 2003
Reply by ●November 20, 20032003-11-20
Hamid Not sure about the -f option but here's what I use and it works just fine... I think its asking for a target address in flash memory. flash -pa -s0x90000000 post.hex Regards Mark Hamid <hsepehr@yahoo.com> wrote in message news:aa01b0cc.0311200442.51fc8b90@posting.google.com...> Hello everybody > > I am using DSK c6711 and I'm trying to program the flash memory. > I started with the examples of TI. > > I am using flash.exe from : > > C:\ti\examples\dsk6711\board_util\flash\Host\Debug>flash post.hex > > and it gives me following message: > > TMS320C6211/6711 DSK Flash Programming Utility, Version 2.04, May 2001 > Copyright (c) 2001 by Texas Instruments Incorporated. All rights reserved. > > ERROR: Please specify a valid board configuration file via the -f option. > > What is this configuration file ? > > Thanks in advance : Hamid
"MarkyMark" <MarkyMark@noaddress.com> wrote in message news:<tu5vb.19272$aT.8282@news-server.bigpond.net.au>...> Hamid > Not sure about the -f option but here's what I use and it works just fine... > I think its asking for a target address in flash memory. > > flash -pa -s0x90000000 post.hex > > Regards Mark > > > Hamid <hsepehr@yahoo.com> wrote in message > news:aa01b0cc.0311200442.51fc8b90@posting.google.com... > > Hello everybody > > > > I am using DSK c6711 and I'm trying to program the flash memory. > > I started with the examples of TI. > > > > I am using flash.exe from : > > > > C:\ti\examples\dsk6711\board_util\flash\Host\Debug>flash post.hex > > > > and it gives me following message: > > > > TMS320C6211/6711 DSK Flash Programming Utility, Version 2.04, May 2001 > > Copyright (c) 2001 by Texas Instruments Incorporated. All rights reserved. > > > > ERROR: Please specify a valid board configuration file via the -f option. > > > > What is this configuration file ? > > > > Thanks in advance : HamidAs I found the configuration board file which is c:\\ti\\cc\\bin\\BrdDat\\dsk6x11.cfg and I recompile the Flash.dsw , it works but now it gives me another error which is FAILED: dsk6x_open() and as I had a look , this function is in dsk6x11hpi.dll but I'm not sure if this dll works in Win2000 environment. Thanks : Hamid
Reply by ●November 21, 20032003-11-21
> As I found the configuration board file which is > c:\\ti\\cc\\bin\\BrdDat\\dsk6x11.cfg > > and I recompile the Flash.dsw , it works but now it gives me another > error which is > FAILED: dsk6x_open() > > and as I had a look , this function is in dsk6x11hpi.dll but I'm not > sure if this dll works in Win2000 environment. > > Thanks : HamidFAILED: dsk6x_open() usually means bad parallel port setup, there is a utility to do this supplied with the DSK, OR like as you say it could be a Win 2000 thing. Unfortunately I am using Win98. Look in your C:\....\c6000\dsk\bin directory, run the Dsk6xtst.exe to verify all is well with your DSk and Win2000 Good luck Mark
There apparently were problems with flash. The configuration file is usually included in the DSK CCS files......somewhere. Flasjh was replaced with flashburn. Works muchhhhh better. Maurice Givens hsepehr@yahoo.com (Hamid) wrote in message news:<aa01b0cc.0311200442.51fc8b90@posting.google.com>...> Hello everybody > > I am using DSK c6711 and I'm trying to program the flash memory. > I started with the examples of TI. > > I am using flash.exe from : > > C:\ti\examples\dsk6711\board_util\flash\Host\Debug>flash post.hex > > and it gives me following message: > > TMS320C6211/6711 DSK Flash Programming Utility, Version 2.04, May 2001 > Copyright (c) 2001 by Texas Instruments Incorporated. All rights reserved. > > ERROR: Please specify a valid board configuration file via the -f option. > > What is this configuration file ? > > Thanks in advance : Hamid
