OK, sorry about the lack on information. What i'm trying to do is get access to the data being sent from a transmission from a 868 burglar alarm for some testing on the security of the system wrt jamming, interference etc. Obviously the first step is to gain access to the actual data. The transmissions are short pulses, persumably containing a short data sequence, maybe a few bytes. My initial thoughts were to 'grab' a sample transmission using a RF signal analyser from national instruments that can downconvert and demodulate the signal for me. However, the hardware for this is just shy of �20k, but allows the flexibility of demodulating virtually any signal, from mobile phones, bluetooth etc. If I knew more about the signal, then it may be possible buy a less flexible solution, but cheaper. Anyone got any experience of this? Thanks sam
Modulation, RF and security
Started by ●November 19, 2003
Reply by ●November 19, 20032003-11-19
samsspam@btinternet.com (sam) wrote in message news:<ba2c2b89.0311190306.67019b4a@posting.google.com>...> OK, sorry about the lack on information. What i'm trying to do is get > access to the data being sent from a transmission from a 868 burglar > alarm for some testing on the security of the system wrt jamming, > interference etc. Obviously the first step is to gain access to the > actual data. > > The transmissions are short pulses, persumably containing a short data > sequence, maybe a few bytes. > > My initial thoughts were to 'grab' a sample transmission using a RF > signal analyser from national instruments that can downconvert and > demodulate the signal for me. However, the hardware for this is just > shy of �20k, but allows the flexibility of demodulating virtually any > signal, from mobile phones, bluetooth etc. > > If I knew more about the signal, then it may be possible buy a less > flexible solution, but cheaper. > > Anyone got any experience of this? > > > Thanks > > samQuick-and-dirty? Use an AM radio to capture and demodulate some harmonic of the signal. Interfering station? Use a second AM radio as a BFO. What's a BFO? Never mind... Regards, Ken Asbury
sam wrote:> OK, sorry about the lack on information. What i'm trying to do is get > access to the data being sent from a transmission from a 868 burglar > alarm for some testing on the security of the system wrt jamming, > interference etc. Obviously the first step is to gain access to the > actual data.Well, you should always assume that the enemy has all the information about how the system works, so you should have that, too. You mean the KD-868? (results of a quick Google search.)> The transmissions are short pulses, persumably containing a short data > sequence, maybe a few bytes.If it is what I think it is, the transmitters have to be pretty cheap. There are transmitter ICs commonly used for garage door openers. I believe they are digital on/off modulated, with a carrier somewhere in the 900 MHz range.> My initial thoughts were to 'grab' a sample transmission using a RF > signal analyser from national instruments that can downconvert and > demodulate the signal for me. However, the hardware for this is just > shy of �20k, but allows the flexibility of demodulating virtually any > signal, from mobile phones, bluetooth etc.> If I knew more about the signal, then it may be possible buy a less > flexible solution, but cheaper.> Anyone got any experience of this?Buy one of the transmitters and take it apart. It won't take long to figure out the modulation or the carrier frequency. (Unless it isn't what I think it is.) http://www.itm.com.tw/5kendu/wireless-burglar-alarm-manufacturers.html -- glen
