Hello all, I am currently working on analysing a VHDL code of a FM baseband receiver. I have a block in VHDL which accepts 2 inputs 1)one from the AD converter and 2)other a sawtooth wave this block produces 2 outputs 1)complex baseband I 2)complex baseband Q There is a lookuptable within this module.I hope he has used CORDIC in his design.But iam not sure what this does to the input(does it multiply the input with sine or cos or arctan,what is the significance of having a sawtooth wave then ?) when i plot the abs(fft(complex(i,q))).i find 3 spectral lines ?what is the significance of this ? kindly reply jack
complex baseband
Started by ●November 18, 2003
Reply by ●November 18, 20032003-11-18
"jack kilby" <jackilby@yahoo.com> wrote in message news:18668c6c.0311180130.4b1f3d6b@posting.google.com...> Hello all, > I am currently working on analysing a VHDL code of a FM baseband > receiver. > > I have a block in VHDL which accepts 2 inputs > 1)one from the AD converter and > 2)other a sawtooth wave > > this block produces 2 outputs > 1)complex baseband I > 2)complex baseband Q > > There is a lookuptable within this module.I hope he has used CORDIC in > his design.But iam not sure what this does to the input(does it > multiply the input with sine or cos or arctan,what is the significance > of having a sawtooth wave then ?) > > when i plot the abs(fft(complex(i,q))).i find 3 spectral lines ?what > is the significance of this ?Jack, The first thing that occurs to me is that the sawtooth is akin to an oscillator/address generator - equivalent to a clock input with a counter inside. But, that doesn't make sense entirely either. What is done with the sawtooth (analog) inside the VHDL (binary?)? What is the frequency of the sawtooth relative to the center frequency of the FM? What do you mean by "baseband receiver"? Do you mean the output is complex baseband? If so, what is your assumed input? "more input!". Fred
Reply by ●December 31, 20032003-12-31
The block is simply a phase rotator. The sawtooth is the phase angle that the ADC input gets rotated by. This is equivalent to doing e^jwt. The phase rotator could be done as a look-up table provided the phase angle resolution is relatively limited. The size of a lookup will grow exponentially with the precision of the phase angle input, so it quickly becomes impractical. That function can also be accomplished with a CORDIC rotator, in which case the rotator is taking a complex input and rotating it by the phase angle specified by the phase input. See the CORDIC paper on my website for more details on the algorithm. There is also an article there I wrote for the Xilinx XCell Journal describing the CORDIC mixer, and you can see an example in the shortwave receiver demo block diagram on the main page. In your case, it sounds like the input is real-only, in which case the Q input to the rotator is just held at 0. jack kilby wrote:> Hello all, > I am currently working on analysing a VHDL code of a FM baseband > receiver. > > I have a block in VHDL which accepts 2 inputs > 1)one from the AD converter and > 2)other a sawtooth wave > > this block produces 2 outputs > 1)complex baseband I > 2)complex baseband Q > > There is a lookuptable within this module.I hope he has used CORDIC in > his design.But iam not sure what this does to the input(does it > multiply the input with sine or cos or arctan,what is the significance > of having a sawtooth wave then ?) > > when i plot the abs(fft(complex(i,q))).i find 3 spectral lines ?what > is the significance of this ? > kindly reply > jack-- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 email ray@andraka.com http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759
