>> If you're concerned about delay in conversion, why not consider flash >> converters? > >Find a flash converter with more then 12 bits of resolution. > >> I don't know of a lot of successive-approximation converters >> still in use. > >Most of MHz class sampling A/Ds are charge redistribution SARs. > >> And if you're using it for audio processing, why do you care so much >> about delay? > >There are applications like adaptive noise canceling where processingdelay>is crucial. > >> Randy Yates > >Lamer.Thanks Vladimir "Lamer" Vassilevsky. That are the points. And that's why I expected that there should be such a device somewhere. Some audio processing algorithms need low delay and high resolution. The algorithm that I would like to implement could be implemented in such a way, that it processes sample by sample. T.
Eval Board with SAR ADC
Started by ●September 3, 2012
Reply by ●October 6, 20122012-10-06
Reply by ●October 7, 20122012-10-07
> >"Randy Yates" <yates@digitalsignallabs.com> wrote in message >news:874nmor0n3.fsf@randy.site... >> "Thomas6666" <61878@dsprelated> writes: >> >>> it's been a while ago since someone asked here for an DSP eval board(for>>> audio processing) that's got a SAR analog-digital converter. >>> Theoretical it should be possible to reach very low delay between an >>> audio >>> input and the output after processing by a DSP. >>> Does anyone know a device with a fast SAR ADC (that could be used for >>> audio >>> processing)? A board with suiting anti-aliasing filters, floating point>>> DSP >>> and fast DAC would be perfect. >>> Have you got an idea, what the minimum expected delay could be? > >> If you're concerned about delay in conversion, why not consider flash >> converters? > >Find a flash converter with more then 12 bits of resolution.Flash converters have mostly given way to several flavours of pipelined converters, which break the high resolution problem down into a number of coarser resolution steps.>> I don't know of a lot of successive-approximation converters >> still in use. > >Most of MHz class sampling A/Ds are charge redistribution SARs.Yep, SAR is still *the* mainstream technique for conversion, and most shuffle charge in one way or another.>> And if you're using it for audio processing, why do you care so much >> about delay? > >There are applications like adaptive noise canceling where processingdelay>is crucial.True, but is the delay through most modern sigma-delta converters intolerable? Two or three sample delay converters are widely available.>> -- >> Randy Yates > >Lamer.Steve
Reply by ●November 27, 20122012-11-27
Hi Steve, Thank you for your opinion on this.>>>> Does anyone know a device with a fast SAR ADC (that could be used for>>>> audio >>>> processing)? A board with suiting anti-aliasing filters, floatingpoint> >>>> DSP >>>> and fast DAC would be perfect. >>>> Have you got an idea, what the minimum expected delay could be? >> >>> And if you're using it for audio processing, why do you care so much >>> about delay? >> >>There are applications like adaptive noise canceling where processing >delay >>is crucial. > >True, but is the delay through most modern sigma-delta converters >intolerable? Two or three sample delay converters are widely available. > >>> Randy Yates >>Lamer. >SteveUnfortunately every extra sample hurts and reduces the performance of the algorithm. Which eval board would you suggest, that has a low overall delay (from analog in to analog out) with Sigma-Delta converters? Easiest would probably be a common one that is well supported (I made some bad experience with boards with really bad documentation). Thank you in advance! T.
Reply by ●November 28, 20122012-11-28
Remember that when you are comparing SAR versus sigma-delta converters you need to add the delay of external analog anti-alias filters required for the SAR converter to the calculation, unless the signal itself is naturally band-limited to the point where you can convince yourself you don't need any more filtering. Bob
Reply by ●December 3, 20122012-12-03
>Remember that when you are comparing SAR versus sigma-delta converters you=>need to add the delay of external analog anti-alias filters required forth=>e SAR converter to the calculation, unless the signal itself is naturallyb=>and-limited to the point where you can convince yourself you don't needany=> more filtering.=20 > >Bob >Good point, Bob. Thanks for that! Can anyone recommend a well supported development board with really low delay? More than two channels in and out would be good as well... Thanks! T.
