Question of TI Code Composer Studio
Started by Tswen-chung Yang November 16, 2003
I'm a starter of CCS, and trying to write some
simple programs. In following samples:
kdebug.c
void printdebug()
printf("Test debug!");
main.c
#include "kdebug.h"
main()
printdebug();
After building and run, when main() call printdebug()
in kdebug.c, the error
Can't Run Target CPU: Error number -2164 Error address 0
occurs. But if I wrote the printf in main(), it can
print out the message. Can anyone tell me what's the
problem?
(Use ARM7TDMI-TMS470RXX Simulator in CCS)
Hi,
i think in  "kdebug.h" is 'include stdio.h' for printf.
Cheers
hello ...
Your kdebug is a .c (kdebug.c) file.
You are going to include it as a .h ("#include "kdebug.h") ???
I think the cross reference is wrong.
I think the complier cannot find it also (in normal situation) ...
If the complier did not give error, I think there might be some other
libraries using the same name.
Regards
Hang Sun
Tswen-chung Yang <tcyang@csie.nctu.edu.tw> wrote in message news:<bp9gl9$1b2e$1@netnews2.csie.nctu.edu.tw>...
> I'm a starter of CCS, and trying to write some > simple programs. In following samples: > > kdebug.c > > void printdebug() > { > printf("Test debug!"); > } > > > > main.c > > #include "kdebug.h" > > main() > { > printdebug(); > } > > > After building and run, when main() call printdebug() > in kdebug.c, the error > > Can't Run Target CPU: Error number -2164 Error address 0 > > occurs. But if I wrote the printf in main(), it can > print out the message. Can anyone tell me what's the > problem? > > (Use ARM7TDMI-TMS470RXX Simulator in CCS)
Make sure you write your linker command file properly. You can find a sample
for arm in your CCS installation.
Avoid using printf... instead, use a global variable and set its value to
something. You can check the value in the watch window.
"Tswen-chung Yang" <tcyang@csie.nctu.edu.tw> wrote in message
news:bp9gl9$1b2e$1@netnews2.csie.nctu.edu.tw...
> I'm a starter of CCS, and trying to write some > simple programs. In following samples: > > kdebug.c > > void printdebug() > { > printf("Test debug!"); > } > > > > main.c > > #include "kdebug.h" > > main() > { > printdebug(); > } > > > After building and run, when main() call printdebug() > in kdebug.c, the error > > Can't Run Target CPU: Error number -2164 Error address 0 > > occurs. But if I wrote the printf in main(), it can > print out the message. Can anyone tell me what's the > problem? > > (Use ARM7TDMI-TMS470RXX Simulator in CCS) > >
