walala wrote:> > Anybody give me some pointers? Thanks a lot in advance!The best way to reduce blocking artifacts in low bit rate JPEG is scaling down the image when compressing and scaling up when decompressing with the new cjpeg/djpeg scaling options: http://jpegclub.org/cjpeg/ http://jpegclub.org/djpeg/ For example, I did a test with a highly compressed (cjpeg -q 8...20) JPEG image which looked quite blocky. If you use cjpeg -scale 1/2, you can go up to q=60 for the same compressed filesize, nearly removing the blocking artifacts. You can use djpeg -scale 2/1 to decode that image back to the source resolution. Regards Guido
which one is the most successful scheme to reduce blocky artifacts in low bit rate JPEG image?
Started by ●November 16, 2003
Reply by ●November 19, 20032003-11-19
