where can I find more information about V.27ter other than ITU standard. And what are the main phases for decoding V.27ter faxes???(i.e: demodulation descrambling....?) and what else.
V.27ter information needed and what are the main phases for decoding v.27 faxes
Started by ●November 11, 2003
Reply by ●November 13, 20032003-11-13
amoor_netx@yahoo.com (amoorS) wrote in message news:<8903a9c7.0311110547.2a22b032@posting.google.com>...> where can I find more information about V.27ter other than ITU > standard.Modem Books, articles, papers, TI Application notes. And not necessarily on V.27.> And what are the main phases for decoding V.27ter faxes???(i.e: > demodulation descrambling....?) and what else.- Demodulation - Equalizer ! - Timing and Carrier Recovery - Demapping/Symbol Decoding - Descrambling Thats basically it. Hope this answers your other question as well. Sachin
Reply by ●November 15, 20032003-11-15
scngupta@yahoo.com (Sachin Gupta) wrote in message news:<d2308724.0311122127.7e8a44a7@posting.google.com>...> amoor_netx@yahoo.com (amoorS) wrote in message news:<8903a9c7.0311110547.2a22b032@posting.google.com>... > > where can I find more information about V.27ter other than ITU > > standard. > > Modem Books, articles, papers, TI Application notes. And not necessarily on V.27. > > > And what are the main phases for decoding V.27ter faxes???(i.e: > > demodulation descrambling....?) and what else. > > - Demodulation > - Equalizer ! > - Timing and Carrier Recovery > - Demapping/Symbol Decoding > - Descrambling > > Thats basically it. Hope this answers your other question as well. > > SachinThank You Sachin for your help. And I have questions about your answer: 1- Is it ordered correctly or not (i.e. Demodulation then Equalizer then Timing and Carrier Recovery then Demapping/Symbol Decoding then Descrambling) . 2- what is Timing and Carrier Recovery (If you have web site to my answer please write it) 3-does all these phases can be implemented by software? 4- IS AGC(autmatic Gain Control) necessary or not? 5- I have Descrambler and demodulator for V.27ter, Can You trace it to see it is correct or not because I have some Problems in fax decoding. Thank You Sachin Gupta
> > > And what are the main phases for decoding V.27ter faxes???(i.e: > > > demodulation descrambling....?) and what else. > > > > - Demodulation > > - Equalizer ! > > - Timing and Carrier Recovery > > - Demapping/Symbol Decoding > > - Descrambling > > > > Thats basically it. Hope this answers your other question as well. > > > > Sachin > > Thank You Sachin for your help. > And I have questions about your answer: > > 1- Is it ordered correctly or not (i.e. Demodulation then Equalizer > then Timing and Carrier Recovery then Demapping/Symbol Decoding then > Descrambling) .Depends on your design. Carrier Recovery usually follows Equalizer. Demapping / Symbol Decoding is in the end.> 2- what is Timing and Carrier Recovery (If you have web site to my > answer please write it)Don't remember any site offhand - but lots of modem papers/books/tutorials out there.> 3-does all these phases can be implemented by software?Absolutely.> 4- IS AGC(autmatic Gain Control) necessary or not?Yes.> 5- I have Descrambler and demodulator for V.27ter, Can You trace it to > see it is correct or not because I have some Problems in fax decoding.What kind of problems ? Sachin
scngupta@yahoo.com (Sachin Gupta) wrote in message news:<d2308724.0311150726.642223f@posting.google.com>...> > > > And what are the main phases for decoding V.27ter faxes???(i.e: > > > > demodulation descrambling....?) and what else. > > > > > > - Demodulation > > > - Equalizer ! > > > - Timing and Carrier Recovery > > > - Demapping/Symbol Decoding > > > - Descrambling > > > > > > Thats basically it. Hope this answers your other question as well. > > > > > > Sachin > > > > Thank You Sachin for your help. > > And I have questions about your answer: > > > > 1- Is it ordered correctly or not (i.e. Demodulation then Equalizer > > then Timing and Carrier Recovery then Demapping/Symbol Decoding then > > Descrambling) . > > Depends on your design. Carrier Recovery usually follows Equalizer. > Demapping / Symbol Decoding is in the end. > > > 2- what is Timing and Carrier Recovery (If you have web site to my > > answer please write it) > > Don't remember any site offhand - but lots of modem > papers/books/tutorials out there. > > > 3-does all these phases can be implemented by software? > Absolutely. > > > 4- IS AGC(autmatic Gain Control) necessary or not? > Yes. > > > 5- I have Descrambler and demodulator for V.27ter, Can You trace it to > > see it is correct or not because I have some Problems in fax decoding. > > What kind of problems ? > > SachinThank you Sachin The problem is : I have implement a demodulator (DQPSK for 2400 b/s) and a descrambler (1+x6+x7)and decoder (MH) only. And then I sent a fax using MH for encoding to test the demodulator, the descrambler and the decoder but when I display the fax only (30% of the fax is ok) but the remaining parts are garbage. So, what is the problem? is it necessary to implement the equalizer or there is some bugs in the demodulator or descrambler??? And if you have to see the code to check I'll post it here And If is the equalizer necessary, How can I program It (Links to web site about equalizer implementation because the V.27ter is not clear) Thank You Sachin
Reply by ●November 16, 20032003-11-16
amoor_netx@yahoo.com (amoorS) wrote in message > > Sachin> Thank you Sachin > > The problem is : > > I have implement a demodulator (DQPSK for 2400 b/s) and a > descrambler (1+x6+x7)and decoder (MH) only. > And then I sent a fax using MH for encoding to test the demodulator, > the descrambler and the decoder but when I display the fax only (30% > of the fax is ok) but the remaining parts are garbage. So, what is the > problem? is it necessary to implement the equalizer or there is some > bugs in the demodulator or descrambler??? > > And if you have to see the code to check I'll post it here > And If is the equalizer necessary, How can I program It (Links to web > site about equalizer implementation because the V.27ter is not clear) > > > Thank You SachinYour descrambler is wrong. It should not be just 1 + x^6 + x^7. There are some fiddle factors you need to deal with for long repeating sequences. This is specified by a rather confusing logic diagram in the V.27ter spec. I went round in circles a few times recently until I got it right. Just using 1 + x^6 + x^7 will give about the error rate you described. Regards, Steve
Reply by ●November 17, 20032003-11-17
steveu@coppice.org (Steve Underwood) wrote in message news:<80bddbd7.0311160437.6c3e1c8e@posting.google.com>...> amoor_netx@yahoo.com (amoorS) wrote in message > > Sachin > > Thank you Sachin > > > > The problem is : > > > > I have implement a demodulator (DQPSK for 2400 b/s) and a > > descrambler (1+x6+x7)and decoder (MH) only. > > And then I sent a fax using MH for encoding to test the demodulator, > > the descrambler and the decoder but when I display the fax only (30% > > of the fax is ok) but the remaining parts are garbage. So, what is the > > problem? is it necessary to implement the equalizer or there is some > > bugs in the demodulator or descrambler???What's MH ? I have a couple of questions to ask: - Have you plotted your constellation diagram at the receiver side, does it look something like the ones for DPSK ? - Equalizer is usually necessary, but depending on what your channel conditions are - you might not need it. Are you sending data on telephone line ? - Remember V.27ter mapping and demapping/symbol detection is differential PSK. The information is modulated in phase changes and not absolute phases.> > And if you have to see the code to check I'll post it here > > And If is the equalizer necessary, How can I program It (Links to web > > site about equalizer implementation because the V.27ter is not clear)Take a look at TI's application note on channel equalization. Equalizer implementation is something which will take some time to study. Have you studied Least Mean Squares (LMS) Equalization. If not you can study a standard Digital Communications text book to understand it or any advanced text on Signal Processing.> Your descrambler is wrong. It should not be just 1 + x^6 + x^7. There > are some fiddle factors you need to deal with for long repeating > sequences. This is specified by a rather confusing logic diagram in > the V.27ter spec. I went round in circles a few times recently until I > got it right. Just using 1 + x^6 + x^7 will give about the error rate > you described.Ah ! The infamous V.27ter scrambler - I struggled to understand it for quite some time till a comp.dsp veteran helped me. Figure I-I/V.27ter is especially helpful (you can try to implement whats happening inside it), the text on the other hand is very unhelpful. I hardly remember how I implemented it. But you should definitely study it for some time and try and implement it on your own. It is definitely worth the effort. Sachin
Reply by ●November 18, 20032003-11-18
scngupta@yahoo.com (Sachin Gupta) wrote in message [...]> What's MH ?Modified Huffman coding. Its the simplest 1-D compression scheme specified for FAXes in the T.6 spec. [...]> Ah ! The infamous V.27ter scrambler - I struggled to understand it for > quite some time till a comp.dsp veteran helped me. > > Figure I-I/V.27ter is especially helpful (you can try to implement > whats happening inside it), the text on the other hand is very > unhelpful. I hardly remember how I implemented it. But you should > definitely study it for some time and try and implement it on your > own. It is definitely worth the effort.Isn't it sad when the only ways to figure out what the spec means are so round about. My solution was to sent FAXes, and play around with the scrambler until they came out right :-( Decrypting the scrambler requirement took me longer than implementing the rest of the modem. The text doesn't even try to be helpful. It just refers you to the rather woolly diagram. The diagram doesn't show the whole timing generation, and relies on some flaky design. That is why I ended up groping in the dark for the intended solution. Once you get something that works, its functionality doesn't seem entirely meaningful. Regards, Steve
Reply by ●November 19, 20032003-11-19
steveu@coppice.org (Steve Underwood) wrote in message news:<80bddbd7.0311181715.20986950@posting.google.com>...> scngupta@yahoo.com (Sachin Gupta) wrote in message [...] > > What's MH ? > > Modified Huffman coding. Its the simplest 1-D compression scheme > specified for FAXes in the T.6 spec.Thanks. Never worked on that part. <snip>> Isn't it sad when the only ways to figure out what the spec means are > so round about. My solution was to sent FAXes, and play around with > the scrambler until they came out right :-( Decrypting the scrambler > requirement took me longer than implementing the rest of the modem.Remember the spec is dated 1970's. I was born in late 1970's. May be that was the best that they could do at that time, but could have modified it later on. Later specs (V.29 and V.17) didn't repeat that same mistake. Probably nobody thought that the effort was worth it - I mean ITU-T resolution etc. Also, if you think what will you change to that specification. I won't dare to propose to change the Text - I understand the figure (with flip-flops, gates) and counters and implemented that, I still don't understand the text and how to change it. Even if we did - which company will fund the effort for an ITU resolution ? Mine won't.> The text doesn't even try to be helpful. It just refers you to the > rather woolly diagram. The diagram doesn't show the whole timing > generation, and relies on some flaky design. That is why I ended up > groping in the dark for the intended solution. Once you get something > that works, its functionality doesn't seem entirely meaningful.It is what that guy called "Character Building Exercise". I did it at his suggestion and prodding and am glad that I did it. Undertsanding it is so round-about that you end up building a lot of character instead. Helps a lot in your career :-) Sachin
scngupta@yahoo.com (Sachin Gupta) wrote in message> > Remember the spec is dated 1970's. I was born in late 1970's. May be > that was the best that they could do at that time, but could have > modified it later on. Later specs (V.29 and V.17) didn't repeat that > same mistake. Probably nobody thought that the effort was worth it - I > mean ITU-T resolution etc. Also, if you think what will you change to > that specification. I won't dare to propose to change the Text - I > understand the figure (with flip-flops, gates) and counters and > implemented that, I still don't understand the text and how to change > it. Even if we did - which company will fund the effort for an ITU > resolution ? Mine won't.Of what relevance is the date? I was working in the late 1970s, and if I had written a spec like that it would have rightly been thrown back in my face, with vociferous complaints. Actually the V.27ter spec. appears to be newer than the V.29 spec (V.27ter is somewhat later than V.27). V.29 is of late 70s vintage, and appears to have had no updates since first publication. The grotty point in the V.29 spec. is it doesn't fully define the transmit side filter. V.27ter says RRC, but V.29 is open ended. Regards, Steve
