Hello, If someone could just point me in the right direction I would appreciate it. I have built a real-time signal modulation simulator. I extract data from the sound card buffer, modulate it, then display it freq components on a GUI (spec an). Here is my dilema. I am trying to do ssb - I have the formula. Now what is the easiest way to convert the real samples into complex numbers? Currently I have to do a fft and an ifft. Isn't there an easier way? I want to build a look-up table. I believe it would have to have two dims. My problem is I am not getting the math to convert from a sequence of real samples to complex. I have read, and even gone back to my textbooks. I know it must be simple. But I am sufferring from a real bad case of brain block! Just for an exercise I tried to convert from real to polar and then to complex. Without much luck. Thanks, Bill
Help - brain block!
Started by ●November 10, 2003
Reply by ●November 10, 20032003-11-10
But how do I do SSB modulation the matlab formula is x.*cos(2*pi*Fc*t) + imag(hilbert(x)).*sin(2*pi*Fc*t); If I use the imaginary value of 0 1 will basically have an AM signal "Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:D9Nrb.2804$fB3.256722@news20.bellglobal.com...> The real samples are already complex numbers -- they just have theimaginary> part equal to zero. > >
Hello Rufus, The old standard way was to amplitude modulate (balanced mix)[1] a carrier with the audio and then run through a filter to either pick just the upper or the lower sideband. In a DSP type of situation, you can create a quadrature carrier and mix it with an analytic form of the audio[2]. Thus you only create either the upper of lower sideband as needed. The analytic signal can be created with a delay and a Hilbert transformer, but more commonly done is to pass the audio through a phase orthonal pair of filters[3]. The filters have the same magnitude response but their phase shifts differ by 90 degrees. IHTH, Clay [1] A balanced mix means that when you multiply one signal with the other you are capable of multipling by negative numbers. In standard AM, the audio is given a DC offset so that the resulting signal is always nonnegative and therefore when you multiply the carrier with it, you only multiply by positive numbers. This is why standard AM yields unmodulated carrier in addition to both the upper and lower sidebands. To understand just use so trigonometry to expand: (sin(wt)+1)*cos(ft) unbalanced mix sin(wt)*cos(ft) balanced mix. Now seeing that your source signal can be expanded into sines and cosines via Fourier's thoerem, you can see how the mixing still works. [2] Look up the Heaviside thoerem for frequency shifting with Fourier transforms. It basically says multiplication by a complex exponential in one domain is shifting in the other domain. [3] An analytic signal while commonly described as having its imaginary portion equal to the Hilbert transform of its real part, has the neat property of having a one sided Fourier transform. So taking an analytic signal version of the voice and shifting via Heaviside's theorem, you can see how this directly produces SSB signals. "rufus" <r111ufus@hotmail.com> wrote in message news:vqv2s1mspjqjb8@corp.supernews.com...> Hello, > If someone could just point me in the right direction I would appreciateit.> I have built a real-time signal modulation simulator. I extract data from > the sound card buffer, modulate it, then display it freq components on aGUI> (spec an). Here is my dilema. > > I am trying to do ssb - I have the formula. Now what is the easiest way to > convert the real samples into complex numbers? Currently I have to do afft> and an ifft. Isn't there an easier way? I want to build a look-up table. I > believe it would have to have two dims. > > My problem is I am not getting the math to convert from a sequence of real > samples to complex. I have read, and even gone back to my textbooks. Iknow> it must be simple. But I am sufferring from a real bad case of brainblock!> > Just for an exercise I tried to convert from real to polar and then to > complex. Without much luck. > > > Thanks, > Bill > >
Thanks - found some great links to "analytical signal" "Clay S. Turner" <physics@bellsouth.net> wrote in message news:2lSrb.82890$un.51136@bignews6.bellsouth.net...> Hello Rufus, > The old standard way was to amplitude modulate (balanced mix)[1] a carrier > with the audio and then run through a filter to either pick just the upper > or the lower sideband. In a DSP type of situation, you can create a > quadrature carrier and mix it with an analytic form of the audio[2]. Thus > you only create either the upper of lower sideband as needed. The analytic > signal can be created with a delay and a Hilbert transformer, but more > commonly done is to pass the audio through a phase orthonal pair of > filters[3]. The filters have the same magnitude response but their phase > shifts differ by 90 degrees. > > IHTH, > > Clay > > [1] A balanced mix means that when you multiply one signal with the other > you are capable of multipling by negative numbers. In standard AM, theaudio> is given a DC offset so that the resulting signal is always nonnegativeand> therefore when you multiply the carrier with it, you only multiply by > positive numbers. This is why standard AM yields unmodulated carrier in > addition to both the upper and lower sidebands. To understand just use so > trigonometry to expand: > > (sin(wt)+1)*cos(ft) unbalanced mix > > sin(wt)*cos(ft) balanced mix. > > Now seeing that your source signal can be expanded into sines and cosines > via Fourier's thoerem, you can see how the mixing still works. > > [2] Look up the Heaviside thoerem for frequency shifting with Fourier > transforms. It basically says multiplication by a complex exponential inone> domain is shifting in the other domain. > > [3] An analytic signal while commonly described as having its imaginary > portion equal to the Hilbert transform of its real part, has the neat > property of having a one sided Fourier transform. So taking an analytic > signal version of the voice and shifting via Heaviside's theorem, you can > see how this directly produces SSB signals. > > > > > > > > "rufus" <r111ufus@hotmail.com> wrote in message > news:vqv2s1mspjqjb8@corp.supernews.com... > > Hello, > > If someone could just point me in the right direction I would appreciate > it. > > I have built a real-time signal modulation simulator. I extract datafrom> > the sound card buffer, modulate it, then display it freq components on a > GUI > > (spec an). Here is my dilema. > > > > I am trying to do ssb - I have the formula. Now what is the easiest wayto> > convert the real samples into complex numbers? Currently I have to do a > fft > > and an ifft. Isn't there an easier way? I want to build a look-up table.I> > believe it would have to have two dims. > > > > My problem is I am not getting the math to convert from a sequence ofreal> > samples to complex. I have read, and even gone back to my textbooks. I > know > > it must be simple. But I am sufferring from a real bad case of brain > block! > > > > Just for an exercise I tried to convert from real to polar and then to > > complex. Without much luck. > > > > > > Thanks, > > Bill > > > > > >
"rufus" <r111ufus@hotmail.com> wrote in message news:vqvota93cd1030@corp.supernews.com...> But how do I do SSB modulation the matlab formula is > > x.*cos(2*pi*Fc*t) + imag(hilbert(x)).*sin(2*pi*Fc*t); > > If I use the imaginary value of 0 1 will basically have an AM signal >That formula is incorrect. You should remove the call to imag() and have just: x.*cos(2*pi*Fc*t) + hilbert(x).*sin(2*pi*Fc*t)
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message news:jOWrb.3873$fB3.357881@news20.bellglobal.com...> > x.*cos(2*pi*Fc*t) + imag(hilbert(x)).*sin(2*pi*Fc*t); > > > > If I use the imaginary value of 0 1 will basically have an AM signal > > > > That formula is incorrect. You should remove the call to imag() and have > just:Oh, actually, I see in the docs that your formula is correct, but the hilbert(x) function doesn't calculate the Hilbert transform -- it makes the analytic signal, so imag(hilbert(x)) is the hilbert transform of x, and will not be all zeros for real-valued input.
Reply by ●November 11, 20032003-11-11
On Mon, 10 Nov 2003 05:58:34 -0700, "rufus" <r111ufus@hotmail.com> wrote:>Hello, >If someone could just point me in the right direction I would appreciate it. >I have built a real-time signal modulation simulator. I extract data from >the sound card buffer, modulate it, then display it freq components on a GUI >(spec an). Here is my dilema. > >I am trying to do ssb - I have the formula. Now what is the easiest way to >convert the real samples into complex numbers? Currently I have to do a fft >and an ifft. Isn't there an easier way? I want to build a look-up table. I >believe it would have to have two dims. > >My problem is I am not getting the math to convert from a sequence of real >samples to complex. I have read, and even gone back to my textbooks. I know >it must be simple. But I am sufferring from a real bad case of brain block! > >Just for an exercise I tried to convert from real to polar and then to >complex. Without much luck. > > > Thanks, >Bill >Hi Bill, I tried to E-mail you a Hilbert transform paper that might help ya', but both of the following E-mail addresses "failed to deliver". r111ufus@hotmail.com rufus@hotmail.com [-Rick-]
