Hi, I know this might take a while to answer,but can someone please explain the basic differences between OFDM vs OFDMA, TDM vs TDMA, FDD vs TDD? Also, what is the difference between a symbol and a subcarrier? Any help would be appreciated! Thank you, Clay
Questions on different multiplexing schemes used in Digital Communications
Started by ●January 17, 2013
Reply by ●January 18, 20132013-01-18
On 1/17/13 10:07 PM, Clay wrote:> > I know this might take a while to answer,but can someone please explain the > basic differences between OFDM vs OFDMA, TDM vs TDMA, FDD vs TDD?alfabet soup.> Also, what is the difference between a symbol and a subcarrier?Vlad might pick on you for that question. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Re: OFDM v OFDMA - In OFDMA the bandwidth is split up into different frequency bands and each user can transmit/receive their data in a particular band. Re: FDD v TDD - FDD requires paired spectrum where the user transmits on one frequency bandwidth and receives, perhaps simultaneously, on a different bandwidth. In TDD, the user transmits and receives within the same frequency bandwidth but at different times. A symbol is a duration in the time domain and a subcarrier is a frequency domain parameter. In OFDM, the bandwidth contains a certain number of subcarriers each modulated with its own data during a symbol period.
On Thursday, January 17, 2013 9:07:06 PM UTC-6, Clay wrote:> Hi, I know this might take a while to answer,but can someone please explain the basic differences between OFDM vs OFDMA, TDM vs TDMA, FDD vs TDD? Also, what is the difference between a symbol and a subcarrier? Any help would be appreciated! Thank you, ClayClay, Here is my "shot" at it. Think about CDM and CDMA - code division multiplex and code division multiple access. so.......... OFDM - orthogonal frequency division multiplex OFDMA - orthogonal frequency division multiple access Same for TDM and TDMA Maurice
>Hi, > >I know this might take a while to answer,but can someone please explainthe>basic differences between OFDM vs OFDMA, TDM vs TDMA, FDD vs TDD? Also, >what is the difference between a symbol and a subcarrier? > >Any help would be appreciated! > >Thank you, >Clay >Communication can be multiple ones to many(broadcast) or many to many(mobile phone). To achieve this multiple approach, systems can separate users through any one or more of the following methods: multiple wires (space division), same frequency,same time. same wire (or space),same frequency, but multiple time slots(TDM) same wire(or space),same time, multiple frequencies(FDM) same wire(or space), same time, one frequency but different code used like keys(CDM) You can view ofdm as a special case of frequency division e.g. carriers are chosen according to certain rules while FDM is free to choose any affordable band. "M" stands for multiplexing (implying multiple information sources) and when additional features are added to enhance multiple users then ...MA is used meaning Multiple Access. for example. TDM implies fixed slots to given users while TDMA allows using same slots for different users. FDD and TDD are similar but applies to the case of duplex(tx,rx) as two users that need be separated. Kadhiem
>Hi, > >I know this might take a while to answer,but can someone please explainthe>basic differences between OFDM vs OFDMA, TDM vs TDMA, FDD vs TDD? Also, >what is the difference between a symbol and a subcarrier? > >Any help would be appreciated! > >Thank you, >Clay >regarding last question, the difference between symbol and subcarrier is similar to that between and apple and a homeless person. However, there is some connection that possibly you have come across in ofdm. A subcarrier is used to modulate one symbol. In ofdm bits are mapped to symbols according to any of QAM methods. An ofdm frame is then constructed from a set of symbols. This frame is assumed in frequency domain and in order to generate multiple subcarriers, ifft is applied. Anytime the symbol is +1 it generates a carrier at its location within ifft bin and when -1 it generates same carrier at opposite phase. The amplitude of carrier depends on symbol level e.g. for qpsk it will be only one level(+/-1) but for 16QAM it will be +/-1,+/-1/3 and so on. Kadhiem
