C6711 hardware question
Started by Tom November 7, 2003
I have the C6711 DSK but was wondering if there were any more suitable
boards available once you have done your evaluation. By this I mean
something (small) with flash memory, two A/D and two D/A for instance
and all battery powered.It should also have a USB or download port for
the program.Or do I have to design my own!
regards
Tom
Hi Tom,
micro-line embedded DSP boards offer a good follow on step after using
C6000 based DSKs.
They are small (down to 98x67mm), support a TMS320C6711/12/13 or
TMS320C6211 DSP, have up to 64MBytes or RAM, and incorporate FLASH ROM
for embedded and stand-alone use. A serial port is available for
updating the FLASH stored application program, and there are options
for A/D/A, FireWire and Ethernet. You can also integrate your own
peripheral hardware to the DSPs EMIF.
Without knowing your battery capacity, it is hard to tell if
micro-line would be suitable. If it is, the C6711CPU is probably the
nearest micro-line option to what you are looking for:
http://www.traquair.com/products/microline/c6x11cpu.html
Regards,
Steve.
On Sat, 08 Nov 2003 07:48:05 +1300, Tom <somebody@nOpam.com> wrote:
>I have the C6711 DSK but was wondering if there were any more suitable >boards available once you have done your evaluation. By this I mean >something (small) with flash memory, two A/D and two D/A for instance >and all battery powered.It should also have a USB or download port for >the program.Or do I have to design my own! > > >regards > >Tom >
http://www.dspvillage.com/dskaccessories
Is that what you are looking for?
Wendelin
"Tom" <somebody@nOpam.com> wrote in message
news:3FABE8E5.B5665C3@nOpam.com...
> I have the C6711 DSK but was wondering if there were any more suitable > boards available once you have done your evaluation. By this I mean > something (small) with flash memory, two A/D and two D/A for instance > and all battery powered.It should also have a USB or download port for > the program.Or do I have to design my own! > > > regards > > Tom > >
http://www.dsignt.de/products/dmodule/d6711.htm
 => C6711 in 2.3" x 3.3" format, 2M flash, 16M SDRAM etc.
 We are using the D.SignT VC33 board and like it a lot. Purchases are through
Spectrum Digital in America, however email support from Germany has been
excellent, always getting replies the same day.
  Declan Hughes
In article <zrvrb.6699$hB5.728@nwrdny02.gnilink.net>, "Wendelin Weingartner"
<wweingar@verizon.net> wrote:
>http://www.dspvillage.com/dskaccessories > >Is that what you are looking for? > >Wendelin > >"Tom" <somebody@nOpam.com> wrote in message >news:3FABE8E5.B5665C3@nOpam.com... >> I have the C6711 DSK but was wondering if there were any more suitable >> boards available once you have done your evaluation. By this I mean >> something (small) with flash memory, two A/D and two D/A for instance >> and all battery powered.It should also have a USB or download port for >> the program.Or do I have to design my own! >> >> >> regards >> >> Tom >> >> > >
Wendelin Weingartner wrote:
> http://www.dspvillage.com/dskaccessories > > Is that what you are looking for? > > Wendelin > > "Tom" <somebody@nOpam.com> wrote in message > news:3FABE8E5.B5665C3@nOpam.com... > > I have the C6711 DSK but was wondering if there were any more suitable > > boards available once you have done your evaluation. By this I mean > > something (small) with flash memory, two A/D and two D/A for instance > > and all battery powered.It should also have a USB or download port for > > the program.Or do I have to design my own! > > > > > > regards > > > > Tom > > > >
This looks good! Tom
My company has used the TI 6713 DSK and we find it to be an excellent
platform. It has all of the 6711 functionality with the addition of dual
channel A/D and D/A using a AIC 23 audio grade part. You might want to look
at this DSK. You can buy this direct from Spectrum Digital.
Ed Stroup
www.appliedsignalprocessing.com
news:3FBE7C38.A3A43C26@nOpam.com...
> > > Wendelin Weingartner wrote: > > > http://www.dspvillage.com/dskaccessories > > > > Is that what you are looking for? > > > > Wendelin > > > > "Tom" <somebody@nOpam.com> wrote in message > > news:3FABE8E5.B5665C3@nOpam.com... > > > I have the C6711 DSK but was wondering if there were any more suitable > > > boards available once you have done your evaluation. By this I mean > > > something (small) with flash memory, two A/D and two D/A for instance > > > and all battery powered.It should also have a USB or download port for > > > the program.Or do I have to design my own! > > > > > > > > > regards > > > > > > Tom > > > > > > > > This looks good! > > Tom > > >
