Hi, I know this question is not 100% relevant to this newsgroup, as I'm talking about continuous-time signals, and not DSP... But I couldn't find a more appropriate place to discuss this. Anyway, there was a big discussion in one of my classes about some characteristics of white noise, and the disagreement seemed to be driven by a discrepancy between our concepts of what the Power-spectral density of a random signal is. So, I'm looking for a *rigurous* definition of what the values of the PSD really represent. (notice that I don't want the PSD defined as the Fourier transform of the auto-correlation of the signal -- what I need is a definition of what the value of the PSD at a specific frequency means/represents) When I say a "rigurous definition", I mean is that the discussion will not be solved with an informal "it represents the spectral contents at the given frequency", or the typical notion that "white noise has a flat spectral density, which means that it was equal contents at all frequencies". No, I'm looking for the *actual* meaning (in a rigurous mathematical sense) of the value of the PSD at a certain frequency. For instance, if we are talking about the definition of what the values of a probability density function mean, this would be examples of what I want, and what I don't want: What I woud NOT want: "The value of the PDF tells you if it is very likely for the variable to take a value of x, relatively to other values" (this definition -- besides incorrect -- is purely intuitive, and thus may lead to ambiguity and multiple (mis)interpretations) What I would want: "The value of the PDF at x is the limit as dx approaches to zero of the probability that the variable takes values in (x, x+dx), divided by dx" Or: "The pdf function is such that the probability that the variable takes values within a region R is given by the integral of the pdf over the region R" These are both valid examples of what I would call an actual/rigurous definition of what the meaning of the value of the PDF is. (I don't know if that is *the* right way of defining what a PDF is, but the statements are true and unambiguous, and they describe what a value of the PDF really tells us) So, can someone help me with finding a rigurous definition of what the value at a given frequency of the PSD of a random signal means? Thanks! Carlos --
Rigorous definition of the Spectral Density of a random signal?
Started by ●October 25, 2003
Reply by ●October 25, 20032003-10-25
Reply by ●October 26, 20032003-10-26
Carlos Moreno wrote:> Actually, I (doubly) disagree on this point -- there is non-zero > energy component *in a frequency band of non-zero length*. Notice > that the term I used, "energy density", refers to (informally > speaking) the "amount of energy per unit of frequency (i.e., > density in the above definition would be defined as the limit as > delta-omega approaches 0 of the energy contained in the band > (omega, omega + delta-omega) divided by delta-omega). > > Notice that with this definition, the energy of a particular > frequency component is zero.Why is that? If I sweep with a delta function for my filter, then delta-omega is always zero, but the energy of a particular frequency component is not. I think you are confusing band*width* with *height*. The PSD of noise will change with time, it should be noisy after all! The actual time and frequency resolution you have in the real world is a harder problem than just defining something mathematically. That could be another point of confusion - time and frequency are both being used. If you plot a 3D surface of amplitude with time on one axis and frequency on another, you can convert that to a PSD surface plot. You can look at this integrated along the time axis to get the average PSD of the whole history, or you can integrate it along the frequency axis to see total power as a function of time. If you pick out one point of frequency and time, it tells you something useful. All these things come from the raw data tho. The real world makes getting the raw data harder, but you can still interpret it as a mathematical object. Patience, persistence, truth, Dr. mike -- Mike Rosing www.beastrider.com BeastRider, LLC SHARC debug tools
Reply by ●October 27, 20032003-10-27
Mike Rosing wrote:> Carlos Moreno wrote: > >> So, can someone help me with finding a rigurous definition >> of what the value at a given frequency of the PSD of a >> random signal means? > > howdy Carlos, > > What's a rigorous definition of PSD to begin with? What you > apply the definition to should not matter. If interpretation > of the application seems to change with the function being > measured, then it would seem that the original interpretation > is wrong. Not the definition.I'm not claiming or suggesting that the definition is wrong. I just need/want to know what is the definition. I think I understand it, but since some of the fellow students were drawing conclusions different from mine, I am sure that either I or them have a wrong idea of what the PSD of a random signal is. I'm trying to find a strict definition of what the value of the PSD at a given frequency represents. For instance, if you give me the PSD of a random signal, and I see that the value at f = 60Hz is 2.5, what I want to know is: what exactly does that 2.5 represent? Is it the power of the 60Hz component? (obviously not -- if it is a random signal, we can not get a measure of power from the PSD). Is it the probability that the signal has energy at that frequency? (obviously not -- the PSD values are not restricted to the interval 0 to 1) Is it the average of the total engergy of the 60Hz component over different realizations of the random signal? Is it the average of energy density at 60Hz over different realizations of the random signal? Is it the average of the power of the 60Hz component over different realizations of the random signal? (I'm not sure if one of the above is the correct definition; but that's what I'm trying to know -- that's what I meant when I said that I'm looking for a "rigurous" definition of what the PSD values represent) Cheers, Carlos --
Carlos Moreno <moreno_at_mochima_dot_com@x.xxx> wrote in message news:<ZGenb.23423$He4.751856@wagner.videotron.net>...> Mike Rosing wrote: > > Carlos Moreno wrote: > > > >> So, can someone help me with finding a rigurous definition > >> of what the value at a given frequency of the PSD of a > >> random signal means? > > > > howdy Carlos, > > > > What's a rigorous definition of PSD to begin with? What you > > apply the definition to should not matter. If interpretation > > of the application seems to change with the function being > > measured, then it would seem that the original interpretation > > is wrong. Not the definition. > > I'm not claiming or suggesting that the definition is wrong. > I just need/want to know what is the definition. > > I think I understand it, but since some of the fellow students > were drawing conclusions different from mine, I am sure that > either I or them have a wrong idea of what the PSD of a random > signal is.In my humble opinion, the terms "rigorous" and "statistics" are almost contradictions in terms. While the formalities of maths also applies when used in statistsics, I think the interpretations may not be as strict as with other mathemathical diciplines. Actually, from the statement of the question I think the interpretation, not the definition, may be the problem.> I'm trying to find a strict definition of what the value of > the PSD at a given frequency represents. For instance, if you > give me the PSD of a random signal, and I see that the value > at f = 60Hz is 2.5, what I want to know is: what exactly > does that 2.5 represent? > > Is it the power of the 60Hz component? (obviously not -- if > it is a random signal, we can not get a measure of power from > the PSD).If you mean "the power at 60 Hz in one particular realization", I agree.> Is it the probability that the signal has energy at that > frequency? (obviously not -- the PSD values are not > restricted to the interval 0 to 1)Agreed.> Is it the average of the total engergy of the 60Hz component > over different realizations of the random signal?Nope. It's the "Power Spectral Density" we are talking about. If there was a nonzero *energy* component in random noise, electrical energy would be available for free: Just mount a reciever and drain energy out of the blue.> Is it the average of energy density at 60Hz over different > realizations of the random signal?Nope, due to the energy/density thing commented in the previous point.> Is it the average of the power of the 60Hz component over > different realizations of the random signal?Almost: It's the average power density of all realizations.> (I'm not sure if one of the above is the correct definition; > but that's what I'm trying to know -- that's what I meant > when I said that I'm looking for a "rigurous" definition of > what the PSD values represent)That's the kind of questions you learn the most from. Test as many interpretations you can, discuss them with others, and make up your own mind about what works for you. Rune
Reply by ●October 28, 20032003-10-28
Rune Allnor wrote:> Carlos Moreno <moreno_at_mochima_dot_com@x.xxx> wrote in message > news:<ZGenb.23423$He4.751856@wagner.videotron.net>... >> ... >> (I'm not sure if one of the above is the correct definition; >> but that's what I'm trying to know -- that's what I meant >> when I said that I'm looking for a "rigurous" definition of >> what the PSD values represent) > > That's the kind of questions you learn the most from. Test as many > interpretations you can, discuss them with others, and make up > your own mind about what works for you. > > RuneHi Rune, that's a sort of brilliant philosophical answer. It remembers me to a piece of German literature: Lessing's "Nathan the Wise" or the famous words of Zarathoustra... SCNR, Bernhard
Bernhard Holzmayer <holzmayer.bernhard@deadspam.com> wrote in message news:<3305646.PMFrtvB4JK@holzmayer.ifr.rt>...> Rune Allnor wrote: > > > Carlos Moreno <moreno_at_mochima_dot_com@x.xxx> wrote in message > > news:<ZGenb.23423$He4.751856@wagner.videotron.net>... > >> ... > >> (I'm not sure if one of the above is the correct definition; > >> but that's what I'm trying to know -- that's what I meant > >> when I said that I'm looking for a "rigurous" definition of > >> what the PSD values represent) > > > > That's the kind of questions you learn the most from. Test as many > > interpretations you can, discuss them with others, and make up > > your own mind about what works for you. > > > > Rune > > Hi Rune, > that's a sort of brilliant philosophical answer. > It remembers me to a piece of German literature: Lessing's "Nathan > the Wise" or the famous words of Zarathoustra...I don't know any of those (except for that intro music by one of the Strauss'es in "2001 - a Space Oddyssey")... but thanks for the warning. We don't want any "Oracle of Delphi"-type answers, do we... ;)> SCNR,??? Rune
Rune Allnor wrote:> Bernhard Holzmayer <holzmayer.bernhard@deadspam.com> wrote in > message news:<3305646.PMFrtvB4JK@holzmayer.ifr.rt>... >> Rune Allnor wrote: >> >> > Carlos Moreno <moreno_at_mochima_dot_com@x.xxx> wrote in >> > message news:<ZGenb.23423$He4.751856@wagner.videotron.net>... >> >> ... >> >> (I'm not sure if one of the above is the correct definition; >> >> but that's what I'm trying to know -- that's what I meant >> >> when I said that I'm looking for a "rigurous" definition of >> >> what the PSD values represent) >> > >> > That's the kind of questions you learn the most from. Test as >> > many interpretations you can, discuss them with others, and >> > make up your own mind about what works for you. >> > >> > Rune >> >> Hi Rune, >> that's a sort of brilliant philosophical answer. >> It remembers me to a piece of German literature: Lessing's >> "Nathan >> the Wise" or the famous words of Zarathoustra... > > I don't know any of those (except for that intro music by one of > the Strauss'es in "2001 - a Space Oddyssey")... but thanks for the > warning. We don't want any "Oracle of Delphi"-type answers, do > we... ;)You're right. However, sometimes, it's close together...> >> SCNR, > > ???= _S_orry, _C_ould _N_ot _R_esist> > RuneBernhard
Carlos Moreno wrote:> Is it the power of the 60Hz component? (obviously not -- if > it is a random signal, we can not get a measure of power from > the PSD).Why not? I mean, that's _statistical_ power, not power as in physics... Sometimes they're not the same... bye, -- piergiorgio
