can this be done in real time???
Started by Andrew N Rimell October 9, 2003
I am thinking of programming a dsp development board (no particular model
chosen yet) to implement an RLS adaptive filter but with a Volterra Series
front end to provide an adaptive non-linear equaliser. If this doesn't mean
anything to you, take a look at IEEE Trans on Sig Proc Vol 41 No 3 March
1993.
If I use a second order Volterra Series would this be computationally too
great to achieve in real time (my application only needs a sampling rate of
1kHz as I am dealing with low frequency information).
Any ideas... Any recommendations for a DSP development board with a C
compiler...
In article bm36cl$rqe$1@sun-cc204.lut.ac.uk, Andrew N Rimell at
A.N.Rimell_no_spam_@lboro.ac.uk wrote on 10/09/2003 04:31:
> I am thinking of programming a dsp development board (no particular model > chosen yet) to implement an RLS adaptive filter but with a Volterra Series > front end to provide an adaptive non-linear equaliser. If this doesn't mean > anything to you, take a look at IEEE Trans on Sig Proc Vol 41 No 3 March > 1993.
trying to use Volterra to model a valve guitar amp?
> If I use a second order Volterra Series would this be computationally too > great to achieve in real time (my application only needs a sampling rate of > 1kHz as I am dealing with low frequency information).
how much memory (in ms or samples) does your Volterra Series have. that's just as important (in terms of computational cost) as order.
> Any ideas... Any recommendations for a DSP development board with a C > compiler...
they don't seem to do cheap ($200 or $300) DSP boards anymore. maybe some kinda SHArC board. ADI sells a C compiler to go with the SHArC. i gave up being a Motorola partisan since the millenium. r b-j
Answers embedded into questions as appropriate...
"robert bristow-johnson" <rbj@surfglobal.net> wrote in message
news:BBAAA0A0.45EE%rbj@surfglobal.net...
> In article bm36cl$rqe$1@sun-cc204.lut.ac.uk, Andrew N Rimell at > A.N.Rimell_no_spam_@lboro.ac.uk wrote on 10/09/2003 04:31: > > > I am thinking of programming a dsp development board (no particular
model
Series
mean
> > anything to you, take a look at IEEE Trans on Sig Proc Vol 41 No 3 March > > 1993. > > trying to use Volterra to model a valve guitar amp?
No, I'm trying to model the vibration on a mechanical system
too
of
> > 1kHz as I am dealing with low frequency information). > > how much memory (in ms or samples) does your Volterra Series have. that's > just as important (in terms of computational cost) as order.
In my simulations I have used N = 10, which for a second order series gives a length of 110 samples
> > > Any ideas... Any recommendations for a DSP development board with a C > > compiler... > > they don't seem to do cheap ($200 or $300) DSP boards anymore. maybe some > kinda SHArC board. ADI sells a C compiler to go with the SHArC. i gave
up
> being a Motorola partisan since the millenium. > > r b-j >
