sharc adsp21061 ez-kit and memory mapped I/O?
Started by Theron Hicks September 25, 2003
Hello,
    I have a sharc adsp-21061 ez-kit board and I would like to make two
changes to it.
    The first change is to use the second serial port to talk to a different
A/D.  The problem with the A/D on the card is that it wants to be AC
coupled.  I need DC data.  So I plan on hooking up an AD974 or AD977 to the
second serial port.  Does anyone see a problem here?
    The second problem is that I need some digital signals to control a few
relays.  I suspect that I need to do some memory mapped I/O using an FPGA,
etc. to decode the address, etc.  Is there an app note or something similar
that shows the memory interface to do this?  I am sure I could figure it out
myself, but if I can find it already done, that will reduce the probability
of screw-ups on my part.  I really would prefer to get it right on the first
trial.
Thanks,
Theron Hicks
Theron Hicks wrote:
> Hello, > I have a sharc adsp-21061 ez-kit board and I would like to make two > changes to it. > The first change is to use the second serial port to talk to a different > A/D. The problem with the A/D on the card is that it wants to be AC > coupled. I need DC data. So I plan on hooking up an AD974 or AD977 to the > second serial port. Does anyone see a problem here?
I don't see a problem, but I'm not intimate with the '061 ezkit either.
> The second problem is that I need some digital signals to control a few > relays. I suspect that I need to do some memory mapped I/O using an FPGA, > etc. to decode the address, etc. Is there an app note or something similar > that shows the memory interface to do this? I am sure I could figure it out > myself, but if I can find it already done, that will reduce the probability > of screw-ups on my part. I really would prefer to get it right on the first > trial.
Have you considered using the flag pins instead? -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 There are 10 kinds of people: the ones who understand binary code, and the ones who don't.
But Jim, Bittware designed the ADSP-21061 EZ-Kit Lite. Don't you remember? :)
Right. 21061 has 4 flag pins and they are all on connector J3. Luiz Carlos
Luiz Carlos wrote:
> > I don't see a problem, but I'm not intimate with the '061 ezkit either. > > But Jim, Bittware designed the ADSP-21061 EZ-Kit Lite. Don't you remember? :) > > > Have you considered using the flag pins instead? > > Right. 21061 has 4 flag pins and they are all on connector J3. > > Luiz Carlos
Unfortunately, I have a lot more than 4 relays to control (Actual number is >16). Although it is not fully designed, I expect that the total number of digital outputs is about 20. Not all these are relays but all are digital on-off type signals. The only reason for the DSP is the analog data collection and processing. The DSP is gross overkill except that it offers simple serial analog I/O and also I happen to have one unused and sitting on my desk. Thanks, Theron
Theron Hicks wrote:
> Hello, > I have a sharc adsp-21061 ez-kit board and I would like to > make two > changes to it. > The first change is to use the second serial port to talk to a > different > A/D. The problem with the A/D on the card is that it wants to be > AC > coupled. I need DC data.
I own another EZ-KIT board (21161) with another ADC. However, my approach might work for you,too. I just removed the serial capacitors next to the connectors, which did the decoupling. Then I had to change a few resistors, so that the gain/offset values were correct. With these tiny changes, the built-in Sigma-Delta-Converter does a good job dealing with DC coupled signals. The same works for the outputs. However, be aware that the board might suffer from spurious currents creeping across your interface - check the complete design. Bernhard
hi,
Theron Hicks wrote:
> Hello, > I have a sharc adsp-21061 ez-kit board and I would like to make two > changes to it. > The first change is to use the second serial port to talk to a different > A/D. The problem with the A/D on the card is that it wants to be AC > coupled. I need DC data. So I plan on hooking up an AD974 or AD977 to the > second serial port. Does anyone see a problem here? > The second problem is that I need some digital signals to control a few > relays. I suspect that I need to do some memory mapped I/O using an FPGA, > etc. to decode the address, etc. Is there an app note or something similar > that shows the memory interface to do this? I am sure I could figure it out > myself, but if I can find it already done, that will reduce the probability > of screw-ups on my part. I really would prefer to get it right on the first > trial.
look at the SHARC doc : there are several /MS lines, or "memory select" lines, which predecode several memory banks. you can use them for enabling a couple of 74LVC138 for example. hope this helps, YG
> Thanks, > Theron Hicks > >
Luiz Carlos wrote:
>>I don't see a problem, but I'm not intimate with the '061 ezkit either. > > > But Jim, Bittware designed the ADSP-21061 EZ-Kit Lite. Don't you remember? :)
Heh heh. No, I don't. I knew BittWare had done one of the ezkits, but it was before I started working here. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 Getting an inch of snow is like winning ten cents in the lottery - Calvin
