BlackFin and SDRAM On EZ-Lite Problems
Started by Kevin Harvey ●September 17, 2003
Actually, Bernhard is talking about something completely different.  He is
talking about having an emulator pod connected to a development board and
the emulator pod supplying just enough power through the TDI/TDO/TMS signals
to keep the dsp in somewhat of a powered state.
As for the support line not knowing about the patch, well, I found out about
it from them, so at least someone there knows about it.
"Kevin Harvey" <kevin.harvey@fluke.com> wrote in message
news:bkrohk$jth$1@potlatch.tc.fluke.com...
> Yes Bernhard, there is some strange behaviour with the ADI development > boards. > > In my case the patch suggested by KG7HF solved the problem. There was
indeed
> a problem with the way that ADI had implemented the SDRAM. It is a great > shame that ADI's support team did not know about this and I had to get the > answer from the newsgroup. > > I have always had first class (if sometimes slow) support from them.
Perhaps
> the heavy advertising on BlackFin has caused them to get a new bunch of > support people and they have not trained them yet. > > Kevin > > "Bernhard Holzmayer" <holzmayer.bernhard@deadspam.com> wrote in message > news:3621509.SLu6kcEnAo@holzmayer.ifr.rt... > > > > Sorry for the delayed answer... > > What you describe, is obvious. Yes, I know, that it's necessary to > > unplug the device, not only power cable, but USB cable, too. > > I'm rather sure that I did so. Not only for a couple of seconds. > > Let's say for at least 30seconds (maybe even 10minutes). > > > > Nothing changed - looked as if SPORT or DMA were partially dead. > > > > After the weekend, when I was about to debug the problem, it had > > vanished. This happened a few times. > > But, as you said: this sounds like voodoo/magic. > > However, I don't believe in such occult things nor do I practice > > them. therefore I told myself, that something must have been gone > > wrong. > > But now, when I read Kevin's note, I remembered this. > > Gave me hope that I was not this stupid... > > > > Bernhard > >
KG7HF wrote:
> Actually, Bernhard is talking about something completely > different. He is talking about having an emulator pod connected > to a development board and the emulator pod supplying just enough > power through the TDI/TDO/TMS signals to keep the dsp in somewhat > of a powered state. >
That's not the case. I __did__ remove all cables. At least, I thought I did. I'd agree with what you say, especially because I own another board which is fully powered through USB, thus knowing of this issue. I always remove the USB cable at first, then the power cable, then insert the power cable and after that the USB cable. It's such a boring process, that I'd certainly have noticed the difference. But I don't mind if you doubt this - so do I... Bernhard
