Hi all, I am having trouble reading data into CCS 4.0, from a .pcm file which has data stored as 32-bit float. If someone has a link for this please send. thanks and regards, AAV. Here is my C code: //globals float in_data[FFT_LENGTH]; // data read from the .pcm file. Int16 inter[1024*4]; Int16 out_vals[512]; // buffer which holds the output data in Q15 format to write to .pcm file // in main( ) // Formatting the byte read done by CCS { Int32 val; Int32 val0, val1, val2, val3; n = fread(inter,sizeof(float), 2 * 256, fp_in); if(n < (2 * 256)) { puts("EOF reached\n"); break; } for (i=0; i<256; i++) { val3 = (Int32)(inter[(4*i)+3]); val2 = (Int32)(inter[(4*i)+2]); val1 = (Int32)(inter[(4*i)+1]); val0 = (Int32)(inter[(4*i)+0]); val = (val3<<24) + (val2<<16) + (val1<<8) + (val0<<0); in_data[i]e = (val*1.0) / 2113929216.0; } } // end of Formatting the byte read done by CCS
Started by ●February 18, 2013
