i have an impluse response that is designed to remove periodicities from a signal as follows: h(t) = x(t) - x(t - p) where p is a period, and for this case p is an integer. i then use convolution to get a remainder signal with the periodicity removed as so: z(t) = conv( x(t), h(t) ) i proceed then to get a final filtered signal by extracting the parts of z from z( p ) to z( max - p ). This is fine for a single period, but suppose i want to remove two or more periodicities with one transfer function and one convolution operation? i have tried a straight operation of adding the impulse responses without luck. the reason i want to try multiple impulses for one convolution is because if i do one period concolution at a time, the remaining signal i can use gets smaller and smaller. anyone know how to do this?
combining impluse responses
Started by ●September 8, 2003
Reply by ●September 8, 20032003-09-08
Reply by ●September 9, 20032003-09-09
actually the impluse response is h(t) = q(t) - q(t - p) where q(t) is the unit impluse "Jeremiah Smith" <parlous@hotmail.com> wrote in message news:vlqf7o20qp4pc3@corp.supernews.com...> > i have an impluse response that is designed to remove periodicities from a > signal as follows: > > h(t) = x(t) - x(t - p) > > where p is a period, and for this case p is an integer. i then use > convolution to get a remainder signal with the periodicity removed as so: > > z(t) = conv( x(t), h(t) ) > > i proceed then to get a final filtered signal by extracting the parts of z > from z( p ) to z( max - p ). > > This is fine for a single period, but suppose i want to remove two or more > periodicities with one transfer function and one convolution operation? > > i have tried a straight operation of adding the impulse responses without > luck. the reason i want to try multiple impulses for one convolution is > because if i do one period concolution at a time, the remaining signal ican> use gets smaller and smaller. anyone know how to do this? > > >
"Jeremiah Smith" <parlous@hotmail.com> wrote in message news:<vlqf7o20qp4pc3@corp.supernews.com>...> i have tried a straight operation of adding the impulse responses without > luck. the reason i want to try multiple impulses for one convolution is1. You should concolve, not add impulse responses.> because if i do one period concolution at a time, the remaining signal i can > use gets smaller and smaller. anyone know how to do this?2. Probably this simple filter is not good enough for narrow notch filtering: it removes many other frequencies too. You can consider using narrower notches, e.g. IIR filters. Alex
"Jeremiah Smith" <parlous@hotmail.com> wrote in message news:vlqh9fcskoci67@corp.supernews.com...> > actually the impluse response is > > h(t) = q(t) - q(t - p) > > where q(t) is the unit impluse > > "Jeremiah Smith" <parlous@hotmail.com> wrote in message > news:vlqf7o20qp4pc3@corp.supernews.com... > > > > i have an impluse response that is designed to remove periodicities froma> > signal as follows: > > > > h(t) = x(t) - x(t - p) > > > > where p is a period, and for this case p is an integer. i then use > > convolution to get a remainder signal with the periodicity removed asso:> > > > z(t) = conv( x(t), h(t) ) > > > > i proceed then to get a final filtered signal by extracting the parts ofz> > from z( p ) to z( max - p ). > > > > This is fine for a single period, but suppose i want to remove two ormore> > periodicities with one transfer function and one convolution operation? > > > > i have tried a straight operation of adding the impulse responseswithout> > luck. the reason i want to try multiple impulses for one convolution is > > because if i do one period concolution at a time, the remaining signal i > can > > use gets smaller and smaller. anyone know how to do this? >The impulse response that you offer is defined as the difference between a function x(t) and itself delayed or advanced in time. But, you didn't define x(t). So that's a problem. It almost appears that x(t) is a signal. If x(t) is a signal then the formulation doesn't take into account time variations of amplitude of the periodic components (and by extension, phase). Otherwise, it's not clear what sort of a "system" h(t) represents. I suppose "x(t-p)" could be the output of an adapted filter but then it wouldn't be x(t-p) any more. The only thing that will generate x(t-p) is a pure delay. As suggested, an adapted filter might be a better bet than a pure delay .... if that's what you meant, it's not at all clear. Fred
my main goal is to 'filter out' periodicities in a signal mixture. i know the signal is composed of periodic waveforms, whose waveforms are the same from period to period. I currently am only concerned with exact integer periods for simplification. I can detect one of the present periods reliably, but need to filter the detected one out to detect the others. You mentioned the use of an IIR filter - how exactly would it's impluse response look like in formula form? "Alexey Lukin" <lukin@ixbt.com> wrote in message news:b225ff4d.0309082159.180f93bd@posting.google.com...> "Jeremiah Smith" <parlous@hotmail.com> wrote in messagenews:<vlqf7o20qp4pc3@corp.supernews.com>...> > i have tried a straight operation of adding the impulse responseswithout> > luck. the reason i want to try multiple impulses for one convolution is > > 1. You should concolve, not add impulse responses. > > > because if i do one period concolution at a time, the remaining signal ican> > use gets smaller and smaller. anyone know how to do this? > > 2. Probably this simple filter is not good enough for narrow notch > filtering: it removes many other frequencies too. You can consider > using narrower notches, e.g. IIR filters. > > Alex
