Does anyone have FFT implementation for Matlab? I'm not interested in the built in Matlab function.
Matlab FFT Code
Started by ●March 15, 2013
Reply by ●March 15, 20132013-03-15
On 3/15/13 11:15 AM, clutchfft wrote:> Does anyone have FFT implementation for Matlab? I'm not interested in the > built in Matlab function.since your e-dress looks like crap, i guess i'll just append it below. it short enough. (i wrote this for a demonstration about 5 years ago of what happens to the FFT when the quantization word gets short. the files that put in the quantization are other files.) this code was not meant to be fast, but just to be able to show what happens in each butterfly, group, and pass. you will have to worry about unwrapping long lines, since i cannot turn off the word wrap in my email client. as far as i know, it worked the last time i used it. lemme know if it doesn't. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge." FILE: COEF_TABLE.M function coefs = coef_table(x) half_N = length(x)/2; if round(log2(half_N)) == log2(half_N) coefs = exp(i*linspace(0, (half_N-1)/half_N*pi, half_N)); else error('length of argument must be power of two'); end FILE: FORWARD_FFT.M function y = forward_fft(x, coefs) % % length(x) must be an integer power of 2. % coefs = coef_table(x) must be called first. % input x is in normal order, output y is in bit-reversed order. % call y = bit_reverse(y) afterward to swap output back to normal order. % y = x; N = length(x); p = log2(N); if round(p) == p bfly_length = N/2; n_group = 1; for pp = 1:p group_top = 1; for g = 1:n_group top = group_top; bottom = top + bfly_length; coef_ptr = 1; for b = 1:bfly_length % num bflys = bfly_length A = y(top) + y(bottom); B = coefs(coef_ptr)*(y(top) - y(bottom)); y(top) = A; y(bottom) = B; top = top + 1; bottom = bottom + 1; coef_ptr = coef_ptr + n_group; end group_top = group_top + 2*bfly_length; end bfly_length = 0.5*bfly_length; n_group = 2*n_group; end else error('length of argument must be power of two'); end FILE: BIT_REVERSE.M function y = bit_reverse(x) y = x; N = length(x); p = log2(N); if round(p) == p for n = 0:(N-1) r = 0; m = n; for pp = 1:p r = bitshift(r, 1); r = bitor(r, bitand(m,1)); % reverse the bits m = bitshift(m, -1); end y(r+1) = x(n+1); end else error('length of argument must be power of two'); end FILE: INVERSE_FFT.M function y = inverse_fft(x, coefs) % % length(x) must be an integer power of 2. % coefs = coef_table(x) must be called first. % input x is in bit-reversed order, output y is in normal order. % call x = bit_reverse(x) first to swap input to bit-reversed order. % y = x; N = length(x); p = log2(N); if round(p) == p coefs = conj(coefs); bfly_length = 1; n_group = N/2; for pp = 1:p group_top = 1; for g = 1:n_group top = group_top; bottom = top + bfly_length; coef_ptr = 1; for b = 1:bfly_length % num bflys = bfly_length A = 0.5*y(top); B = 0.5*y(bottom)*coefs(coef_ptr); A = A + B; B = A - 2*B; y(top) = A; y(bottom) = B; top = top + 1; bottom = bottom + 1; coef_ptr = coef_ptr + n_group; end group_top = group_top + 2*bfly_length; end bfly_length = 2*bfly_length; n_group = 0.5*n_group; end coefs = conj(coefs); else error('length of argument must be power of two'); end
