"Bernhard Holzmayer" <holzmayer.bernhard@deadspam.com> wrote in message news:4768755.qu4maFuHSs@holzmayer.ifr.rt...> > I have seen one PCI card that connect to 40 ADC/DAC box. It > > follows ASIO2 and has a top latency of 2ms. It sales with a 10 > > ADC/DAC box, and cost about 400$. > > http://www.zzounds.com/item--STODSP2000 > Fine, if the specs work for you. > If 40 is your number, why not. > If you think of pluggin 10 such PCI boards in your PC, this will > certainly fail!Hi, I just wanted to say that it is one PCI card, that has this cable in its end, and this cable connects to a box that has 10 channels (full duplex stereo 24bit 196Khz) and this ONE PCI can connect to 3 more boxes, that sums up to 40 channels with only one PCI card (not 10 cards).
Question
Started by ●September 5, 2003
Reply by ●September 9, 20032003-09-09
Reply by ●September 10, 20032003-09-10
johny wrote:> > "Bernhard Holzmayer" <holzmayer.bernhard@deadspam.com> wrote in message > news:4768755.qu4maFuHSs@holzmayer.ifr.rt... > > > I have seen one PCI card that connect to 40 ADC/DAC box. It > > > follows ASIO2 and has a top latency of 2ms. It sales with a 10 > > > ADC/DAC box, and cost about 400$. > > > http://www.zzounds.com/item--STODSP2000 > > Fine, if the specs work for you. > > If 40 is your number, why not. > > If you think of pluggin 10 such PCI boards in your PC, this will > > certainly fail! > > Hi, I just wanted to say that it is one PCI card, that has this cable in its > end, and this cable connects to a box that has 10 channels (full duplex > stereo 24bit 196Khz) and this ONE PCI can connect to 3 more boxes, > that sums up to 40 channels with only one PCI card (not 10 cards).Your 24-bit data might as well be 32-bit as far as transfer speed goes. allowing for (probably not enough) overhead, call the data rate 200 Khz per channel times 40 channels = 8 MHz through the PCI interface. IF everything is done right and IF no other transfers get in the way, you ought to be able to sustain that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
