Hi Mark, Transmitter: DTU-215 from Dektec Transmits 16QAM modulated data at the rate of 4.5Msymbols/s at a carrier frequency of 578MHz. Receiver: DTA-2131 from Dektec Receives 100,000 IQ-samples (16 bit signed integer I + 16 bit signed integer Q) at the rate of 9Msamples/s (2 samples/symbol) at a carrier frequency of 578MHz. IQ-bandwidth = 8Mhz. This should give me 100,000 IQ-samples of 16QAM modulated data at 2 samples/symbol with carrier offset and timing offset + channel distortion to work with for demodulation. That is also what I am synthesizing. Regards, Viktor
SDR - Demodulation of DVB-C
Started by ●March 27, 2013
Reply by ●March 28, 20132013-03-28
Reply by ●April 2, 20132013-04-02
If your solution is working on the synthesized data, then the problem might be somewhere else. Maybe you can recalculate your filter gains and loop constants by analyzing your real data again. Or since you have to use an equalizer, your channel is frequency selective (and not frequency flat). That means there might not be one optimum pulse for timing phase adjustment. In that case, your NDA timing recovery module will lock onto the symbol frequency only (that's what I think is required) and the equalizer will do the rest.
