radams2000@gmail.com writes:> The now-discontinued coastal marine navigation system (the name > escapes me) used a carrier down below 100khz if I remember correctly.Are you talking about GMDSS? -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Modulation methods
Started by ●June 11, 2013
Reply by ●June 12, 20132013-06-12
On Wed, 12 Jun 2013 16:57:23 -0700 (PDT), radams2000@gmail.com wrote:>If the speed of light were about a million times slower, then you could jus= >t connect a microphone directly to an antenna and you would have your own r= >adio station! Unfortunately, given that we can't change the speed of light,= > your antenna would need to be about 1000 miles long. Hence the need for mo= >dulation.=20 > >The now-discontinued coastal marine navigation system (the name escapes me)= > used a carrier down below 100khz if I remember correctly. That's a pretty = >big antenna. > >BobELF? Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
