Sirs, For some of the cellular communications standards, multiple modulations schemes are adopted (16QAM, 64QAM etc.). I have feq questions on this, - are these modulation used for modulation of carrier signals or this is baseband related modulation -- assuming this is for carrier modulation, how does the receiver know what modulation has been done used while transmission -- if 16QAM, 64QAM is not for carrier modulation, what modulation is used for the carriers Thanks, manish _____________________________ Posted through www.DSPRelated.com
modulation schemes
Started by ●June 18, 2013
Reply by ●June 18, 20132013-06-18
On Tue, 18 Jun 2013 05:46:25 -0500, "manishp" <58525@dsprelated> wrote:>Sirs, > >For some of the cellular communications standards, multiple modulations >schemes are adopted (16QAM, 64QAM etc.). I have feq questions on this, > >- are these modulation used for modulation of carrier signals or this is >baseband related modulationI'm not sure what you mean by this. QAM is a "suppressed carrier" modulation, like PSK. The signal can be generated at baseband and then just translated up to the IF/RF frequency with a mixer.>-- assuming this is for carrier modulation, how does the receiver know what >modulation has been done used while transmissionIt either has to know ahead of time or there has to be signalling in a framing structure (or otherwise available) to tell the demodulator what is being transmitted. Cellular systems usually have a control channel, either a separate channel or a sub-channel within a transmitted stream, that tells the configuration for the receiver. Many systems have multiple modulation schemes, with some being adaptive to automatically adjust to channel conditions. Signalling tells the receiver what to expect. e.g., in 802.11 there is a header that is always transmitted in BPSK that tells how the next part of the transmission is modulated and coded.>-- if 16QAM, 64QAM is not for carrier modulation, what modulation is used >for the carriersI think you have some misconceptions about "carriers" and modulation. Often the "carrier" is just the center frequency of the signal (like it is for QAM).>Thanks, manish > >_____________________________ >Posted through www.DSPRelated.comEric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Tue, 18 Jun 2013 05:46:25 -0500, manishp wrote:> Sirs, > > For some of the cellular communications standards, multiple modulations > schemes are adopted (16QAM, 64QAM etc.). I have feq questions on this, > > - are these modulation used for modulation of carrier signals or this > is baseband related modulationIf you can tell me how to get a quadrature signal out of a baseband channel, I will tell you that 16QAM is used in baseband. Otherwise you need a carrier.> -- assuming this is for carrier modulation, how does the receiver know > what modulation has been done used while transmissionPresumably there's a protocol that dictates how the receiver will know. Find the applicable standard, and read.> -- if 16QAM, 64QAM is not for carrier modulation, what modulation is > used for the carriersOnce again, this information is in the applicable standard. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
