Bandpass subsampling?
Started by Vladimir Vassilevsky June 19, 2013
There is a need to estimate power which falls into given wide (~30% of
Nyquist) bandwidth. Power spectrum doesn't matter; just overall number.
The power estimate is not needed often; so a decimation factor of ~1000
is preferred.
Straightforward way would be make FIR filter to cut out the bandwidth,
run this filter at every 1000th sample, then measure power.
But if the input is periodic or near periodic to decimated sample rate,
then the power output would oscillate with difference frequency. This
corresponds to comb response in spectral domain; ideally there should be
flat response.
Is there an efficient way to deal with this problem?
I am thinking of dithering decimation factor.
DSP and Mixed Signal Designs
www.abvolt.com
On Wed, 19 Jun 2013 10:53:44 -0500, Vladimir Vassilevsky wrote:
> There is a need to estimate power which falls into given wide (~30% of > Nyquist) bandwidth. Power spectrum doesn't matter; just overall number. > The power estimate is not needed often; so a decimation factor of ~1000 > is preferred. > > Straightforward way would be make FIR filter to cut out the bandwidth, > run this filter at every 1000th sample, then measure power. But if the > input is periodic or near periodic to decimated sample rate, then the > power output would oscillate with difference frequency. This corresponds > to comb response in spectral domain; ideally there should be flat > response. > > Is there an efficient way to deal with this problem? I am thinking of > dithering decimation factor.
Your description is not clear. Is the signal that you wish to measure the power of the only signal present? Do you mean to decimate by 1000 and run your FIR filter on that, or do you mean that every 1000th sample you're going to run the entire FIR filter on as many samples as it has taps? And when you say "but if the input is periodic..." do you mean that the input is affecting the power, and thus the _power_ may be periodic? If the power is not steady and you dither the rate at which you sample it, then the best that you'll do is randomize the unsteadyness. Then you'll be dealing with trying to estimate the power of a random signal. That's always a pain and a half, and often gets you highly varying and thus confusing results. I dislike trying to measure power on anything but a nice steady signal -- when the signal isn't steady one quickly finds that "power" means different things to different people, that these "different things" often devolve down to the interval over which they are willing to average (which often depends on the thermal time constants of the things that they don't want to see burnt up, but may depend on the batteries and/or power supplies that they're using). It can be difficult to satisfy all of one's customers in these cases. My inclination would be to just measure the @#$% power continuously, unless I'm really backed into the wall for processing power. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
<nospam@nowhere.com> wrote:
>But if the input is periodic or near periodic to decimated sample rate, >then the power output would oscillate with difference frequency. This >corresponds to comb response in spectral domain; ideally there should be >flat response.
This is a sampling problem like any other. By analogy, if you sample a sine wave that is very near half the sampling frequency, you will get this same kind of "beat" behavior. The solution is to observe a sufficiently long time series to cover a full period of the "beat", so that the true signal can be reconstructed. You can subsample to reduce the number of samples in the observation, but the amount of TIME over which you must observe the signal will not change. Greg
Sounds like a good idea to me. I'd sell it as a spread-spectrum method but the result is the same. _____________________________ Posted through www.DSPRelated.com
