Octave or Scilab
Started by Ro_ny ●June 22, 2013
Hi Rony,
Am 23.06.13 23:08, schrieb Ro_ny:
>> I think you're misunderstanding the utility of these packages. They're >> MATH packages. You're doing DSP. > > I think this forum is destined first of all for DSP?:) > > Secondly, Matlab seems to have a command of gaussfir(bt,n,o) - what’s the > equivalent of Scilab (and also Octave if should be similar) for it?
When talking about Matlab, there are two things: A) Matlab, the language - a programming language specialized on vector/matrix math B) Matlab, the system - an IDE and a huge library of canned solutions for common problems Octave faithfully copies only A) - it has no IDE and lacks many of the advanced functions you can find in "Matlab". OTOH, Matlab, the system, only works if you buy a number of so called "toolboxes" with it. The basic price for "naked" Matlab is around 2000&euro;, every single Toolbox costs you another ~1000&euro;. The function "gaussfir" that you mentioned belongs to the "Signal processing toolbox". If you would buy only "Matlab", you would still not have it! For doing DSP work, you might also need the "Optimization Toolbox", otherwise you have no function for nonlinear least squares fitting, and the "Image processing toolbox" if you need standard image operations like 2D-covolution, morphology operators and so on. In octave, the very standard stuff IS there, like "leasqr" for non-linear least squares and "bwmorph" for morphological operators, but the complete set of canned solutions is not available. If you need only A), you are probably better off with Octave - it's free, and it gives you the standard stuff, too. If you need B), then you have to bite the bullet and buy Matlab. Be prepared to spend 5-10k&euro; depending on your needs. Now, Gaussian filtering does not seem to be a problem using only A) - that's what Tim has shown you. If there is no black magic behind gaussfir (I no nothing about GMSK), you don't need the fancy DSP toolbox. Repeating Tim's lines in Octave looks like this: Apfelkiste:~ chris$ octave GNU Octave, version 3.0.3 Copyright (C) 2008 John W. Eaton and others. This is free software; see the source code for copying conditions. There is ABSOLUTELY NO WARRANTY; not even for MERCHANTIBILITY or FITNESS FOR A PARTICULAR PURPOSE. For details, type `warranty'. Octave was configured for "i386-apple-darwin8.9.1". Additional information about Octave is available at http://www.octave.org. Please contribute if you find this software useful. For more information, visit http://www.octave.org/help-wanted.html Report bugs to <bug@octave.org> (but first, please read http://www.octave.org/bugs.html to learn how to write a helpful report). For information about changes from previous versions, type `news'. octave-3.0.3:1> sigma=1.0 sigma = 1 octave-3.0.3:2> x=linspace(-3*sigma, 3*sigma, 15) x = -3.00000 -2.57143 -2.14286 -1.71429 -1.28571 -0.85714 -0.42857 0.00000 0.42857 0.85714 1.28571 1.71429 2.14286 2.57143 3.00000 octave-3.0.3:3> g=exp(-x.^2/(2*sigma^2)) g = 0.011109 0.036658 0.100669 0.230066 0.437565 0.692569 0.912254 1.000000 0.912254 0.692569 0.437565 0.230066 0.100669 0.036658 0.011109 octave-3.0.3:4> g=g/sum(g) g = Columns 1 through 13: 0.0019016 0.0062751 0.0172326 0.0393829 0.0749026 0.1185545 0.1561603 0.1711807 0.1561603 0.1185545 0.0749026 0.0393829 0.0172326 Columns 14 and 15: 0.0062751 0.0019016 octave-3.0.3:5> plot(x,g,'*') All those commands should run unaltered in Matlab. Christian
Hi Christian, Thank you for the explanation. I also thank Tim for the
example.
A GSM modulation is for some indirect assessment and practically I&rsquo;m
going for another thing (sorry for not sharing here a commercial secret in
front of 5 digit people&#61514;).
If we get back to the simple 1D Gaussian filter, is anyone here able to
revise Tim&rsquo;s example (in Octave/Scilab) to include the 3 parameters? (As
changeable constants)
Rony J.
_____________________________
Am 24.06.13 17:15, schrieb Ro_ny:
> Hi Christian, Thank you for the explanation. I also thank Tim for the > example.
> If we get back to the simple 1D Gaussian filter, is anyone here able to > revise Tim&rsquo;s example (in Octave/Scilab) to include the 3 parameters? (As > changeable constants)
For Gaussian filtering, there are not so many parameters one can change. It's basically the width( sigma, stddev) and number of samples. If you look at my example, the second line probably contains all parameters you need to change: x=linspace(-3*sigma, 3*sigma, 15) The "3" indicates, how far the Gaussian extends, the 15 is the nuber of samples, and the sigma is the bandwidth. There might be another parameter involved, namely a non-integer shift. Simply look up the math - somebody must have already computed sigma for you from your parameters, and then it's trivial. Why do you insist on us doing your homework? If you look up the formulae, I will convert it to octave for (probably trivial). Christian
Hi Christian,
Is it possible that the said function appears in Octave?
http://wiki.octave.org/Signal_package
Also, what&rsquo;s the recommended download link for Octave for Windows 7
64bit? (I may have seen more than one) and have you experienced any issue
on Windows?
   Questions for people regarding both the Octave and Scilab programs:
Can both be installed and work on PC (Windows) without internet
connection?
Can both be called from a C compiler? (Like the free MS Visual C++
Express)
Can both allow real-time processing of the PC&rsquo;s external analog
input-output? (i.e. without using any input/output file)
PS: About the Prokais book, is there a free online link for reading?
Thanks,
Rony J.
On Tue, 25 Jun 2013 09:26:27 -0500, "Ro_ny" <95309@dsprelated> wrote:
>Hi Christian, > >Is it possible that the said function appears in Octave? >http://wiki.octave.org/Signal_package
linspace is in Octave, if that's what you're asking about. You didn't specify and didn't quote what you're responding to, so it's hard to know what you're inquiring about.
>Also, what&rsquo;s the recommended download link for Octave for Windows 7 >64bit? (I may have seen more than one) and have you experienced any issue >on Windows?
http://octave.sourceforge.net/
> Questions for people regarding both the Octave and Scilab programs: > >Can both be installed and work on PC (Windows) without internet >connection?
Octave will run fine without an internet connection.
>Can both be called from a C compiler? (Like the free MS Visual C++ >Express)
That's difficult in Octave.
>Can both allow real-time processing of the PC&rsquo;s external analog >input-output? (i.e. without using any input/output file)
That's difficult in Octave. I've done real-time stuff with Octave using a home-grown file transfer handshake. There may be better ways, but at the time the schedule did not permit finding them.
Unlikely. http://www.amazon.com/John-G.-Proakis/e/B001I9TU3K/ref=sr_ntt_srch_lnk_1?qid=1372175944&sr=1-1
>Thanks, > >Rony J. > > >_____________________________ >Posted through www.DSPRelated.com
Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Tue, 25 Jun 2013 09:26:27 -0500, Ro_ny wrote:
> Hi Christian, > > Is it possible that the said function appears in Octave? > http://wiki.octave.org/Signal_package > > Also, what&rsquo;s the recommended download link for Octave for Windows 7 > 64bit? (I may have seen more than one) and have you experienced any > issue on Windows? > > Questions for people regarding both the Octave and Scilab programs: > > Can both be installed and work on PC (Windows) without internet > connection?
A PC without Internet? What's that? Seriously -- Scilab installs from an exe; you'd need to burn it onto a CD or put it on a thumb drive, but from there you could install it wherever. I can't speak directly for Octave, but I think the answer is yes.
Scilab is reputed to have that capability. I've gone the other way (under Linux) and called routines written in C from Scilab.
> (Like the free MS Visual C++ Express)
The last time I looked Scilab for Windows was compiled under Visual C++, so of the free alternatives that would be your best bet.
> > Can both allow real-time processing of the PC&rsquo;s external analog > input-output? (i.e. without using any input/output file)
Theoretically Scilab can, but I've never tried it. Given that you can call C functions there's a chance that you could make this happen yourself, if you were savvy enough. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
>>Is it possible that the said function appears in Octave? >>http://wiki.octave.org/Signal_package > >linspace is in Octave, if that's what you're asking about. You didn't >specify and didn't quote what you're responding to, so it's hard to >know what you're inquiring about.
This question refers to the gaussfir(bt,n,o) as the word gaussfir seems to appear in the above link. Thank you both. _____________________________ Posted through www.DSPRelated.com
On Tue, 25 Jun 2013 12:43:25 -0500, "Ro_ny" <95309@dsprelated> wrote:
> >>>Is it possible that the said function appears in Octave? >>>http://wiki.octave.org/Signal_package >> >>linspace is in Octave, if that's what you're asking about. You didn't >>specify and didn't quote what you're responding to, so it's hard to >>know what you're inquiring about. > >This question refers to the gaussfir(bt,n,o) as the word gaussfir seems to >appear in the above link.
Yes, gaussfir appears in the link which you provided, which is a link clearly identified as a listing of functions which ARE NOT part of Octave. I'm incredulous that you posted the link to the answer of the question that you were asking as part of the question while you were asking it.
>Thank you both. > >_____________________________ >Posted through www.DSPRelated.com
Hi Rony,
Am 25.06.13 16:26, schrieb Ro_ny:
Apparently you haven't read the headline, it says "missing functions"! Therefore, there is currently no gaussfir in the signal package, but it's on the wishlist. That doesn't mean anyone will implement it in the near future. You could be the one, if you look up the math somewhere.
> Also, what&rsquo;s the recommended download link for Octave for Windows 7 > 64bit? (I may have seen more than one) and have you experienced any issue > on Windows?
I haven't used Windows for some time now. A few years ago the best way to get octave was by installing cygwin. That may have changed now.
> Can both be called from a C compiler? (Like the free MS Visual C++ > Express)
It is relatively easy to write functions in C which are called by octave. There is a script, mkoctfile, which calls the compiler on your C++ file and transforms it into a loadable function. I have never done the other way round, however it's possible by using feval() to call out to the interpreter.
Never tried. I know that Matlab can do it, but typically, it is used as a prototyping system and for hands-on calculation, rarely for production work. I would only consider this if there is a complicated algorithm too heavy to be reimplemented in a compiled language. A compiled language gives a performance boost in many cases. Christian
