On Friday, July 19, 2013 9:11:30 PM UTC-4, robert bristow-johnson wrote:> On 7/19/13 5:51 PM, glen herrmannsfeldt wrote: > > > robert bristow-johnson<rbj@audioimagination.com> wrote: > > > > > > (snip, I wrote) > > > > > >>> I don't think you can build an on-chip (no external capacitor) > > >>> oscillator down to 400Hz, but for low power reasons you want it > > >>> as low as possible. LCM(380,400) is 7600Hz if that helps. > > > > > >> does it count if you have an on-chip oscillator (with an on-chip cap) > > >> running at some high frequency (perhaps some multiple of 7600 Hz) and > > >> you divide the output frequency down with the old standard logic? > > > > > > No, completely different. > > > > > > In this case, that is a reason why it might have a higher frequency > > > divided down. Also, often the power used is related to the frequency, > > > and so low power requires low frequency. > > > > power is also related to the number of transistors or gates hooked up to > > it. so you could have a small portion of the chip driven by a > > high-frequency oscillator, divide the sucker down, and have the rest of > > the chip driven by the low-frequency clock derived from the original > > high-frequency clock. > > > > > > > > Watches usually use a 32768Hz crystal, as the power needed is much > > > lower than for higher frequencies. > > > > how did they arrive at that value? :-) > > > > also 32 kHz sounds like a pretty big xtal. i woulda thunked that the > > electronics in a watch might be running at a higher clock, but i surely > > don't know first hand. > > > > i remember in the olden daze that 3.579545 MHz were the cheap xtals to > > run your microprocessors (like the venerable MC6809) on. can't imagine > > how they came up with that frequency. > > > > > Maybe some trick with an op-amp and small capacitor to make it > > > look larger. > > > > still can't see why they can't just divide a high frequency down with a > > very few gates and let all the other gates run on the slow clock. > > > > but then i hadn't done anything with hardware since 1991. > > > > -- > > > > r b-j rbj@audioimagination.com > > > > "Imagination is more important than knowledge."Robert, the 3.57945MHz xtal is a color burst crystal (NTSC). They were very cheap due to every color tv (US) having one. The freq was 455 * (horizontal scan rate)/2. The original scan rates for NTSC were 60Hz and 15750HZ. When color was added the rates were changed to 59.94Hz and 15734Hz. The luminance and chroma info were interleaved among each other via the use of comb filters (made with a physical delay line using coax cable in the early tvs). Locking the horizontal scan rate to the color burst, kept the color phase from dancing all over the place. Clay
Resampling one signal to match another
Started by ●July 19, 2013
Reply by ●July 20, 20132013-07-20
robert bristow-johnson <rbj@audioimagination.com> wrote:> On 7/19/13 5:51 PM, glen herrmannsfeldt wrote: >> robert bristow-johnson<rbj@audioimagination.com> wrote:(snip)>>> does it count if you have an on-chip oscillator (with an on-chip cap) >>> running at some high frequency (perhaps some multiple of 7600 Hz) and >>> you divide the output frequency down with the old standard logic?>> No, completely different.>> In this case, that is a reason why it might have a higher frequency >> divided down. Also, often the power used is related to the frequency, >> and so low power requires low frequency.> power is also related to the number of transistors or gates hooked up > to it. so you could have a small portion of the chip driven by a > high-frequency oscillator, divide the sucker down, and have the rest > of the chip driven by the low-frequency clock derived from the original > high-frequency clock.You could. Maybe that works. Also, it sounds like they can turn off the sampling clock when it isn't needed. It can then turn on when appropriate motion is detected.>> Watches usually use a 32768Hz crystal, as the power needed is much >> lower than for higher frequencies.> how did they arrive at that value? :-)A nice, but not too big, power of two.> also 32 kHz sounds like a pretty big xtal. i woulda thunked that the > electronics in a watch might be running at a higher clock, but i surely > don't know first hand.It is interesting. The usual crystals, like used for radios and older computer clocks are in a thickness mode, such that the period is proportional to the thickness of the (usually round) crystal. The 32768Hz are called tuning fork mode. I don't know it more than that, but the mode is very different.> i remember in the olden daze that 3.579545 MHz were the cheap xtals t > to run your microprocessors (like the venerable MC6809) on. > can't imagine how they came up with that frequency.The rules were pretty complicated to make sure everthing has the right ratios, but such crystals are in every NTSC color TV.>> Maybe some trick with an op-amp and small capacitor to make it >> look larger.> still can't see why they can't just divide a high frequency down with a > very few gates and let all the other gates run on the slow clock.They might do that. I was considering the ability not to do it. -- geln
claysturner@gmail.com wrote:> On Friday, July 19, 2013 9:11:30 PM UTC-4, robert bristow-johnson wrote:(snip)>> i remember in the olden daze that 3.579545 MHz were the cheap xtals to >> run your microprocessors (like the venerable MC6809) on. can't imagine >> how they came up with that frequency.(snip) (snip)> Robert, the 3.57945MHz xtal is a color burst crystal (NTSC). > They were very cheap due to every color tv (US) having one. > The freq was 455 * (horizontal scan rate)/2. > > The original scan rates for NTSC were 60Hz and 15750HZ. > When color was added the rates were changed to 59.94Hz and > 15734Hz. The luminance and chroma info were interleaved among > each other via the use of comb filters (made with a physical > delay line using coax cable in the early tvs).The reason for the odd half is that the phase alternates between lines and between successive scans of the same line. That makes it much less visible than it might be.> Locking the horizontal scan rate to the color burst, > kept the color phase from dancing all over the place.Yes, that, too. There are three requirments. One is an odd half multiple of the line rate, as you noted. The line rate has to be an odd half multiple of the field rate to make interlaced scanning work. Since there are an odd number of lines per frame (525), the subcarier will naturally also be an odd half multiple of the frame rate. The last requirement is that the line rate be an integer fraction of the audio carrier offset of 4.5MHz. 4.5MHz/15734, rounded to the nearest integer, is 286, so the new line rate is 4.5MHz/286, or about 15734Hz. Also interesting is where the original line and frame rates come from. Early power supply filtering wasn't so good, so running the field (half the frame rate for interlace) at 60Hz (power line synchronous) helps. Instead of dividing down from a higher frequency (with a PLL) like we might do now, they mutliplied up from 60Hz using vacuum tube based multipliers. 525 = 3 * 5 * 5 * 7 -- glen
On 7/19/13 8:31 PM, glen herrmannsfeldt wrote:> robert bristow-johnson<rbj@audioimagination.com> wrote:...> >> i remember in the olden daze that 3.579545 MHz were the cheap xtals t >> to run your microprocessors (like the venerable MC6809) on. >> can't imagine how they came up with that frequency. > > The rules were pretty complicated to make sure everything has the > right ratios, but such crystals are in every NTSC color TV.i knew all of that, Glen. including how (or why) f_H got bumped down to 15734 Hz (which i think was one of the most obscure factoids) which brought some of us audio guys the wonderful sampling frequency of 44.056 kHz. anyway, i need to be careful about Poe's Law (i thought smiley emoticons might protect me from it). this isn't exactly that, but it's similar. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> wrote: (snip, I wrote)>> The rules were pretty complicated to make sure everything has the >> right ratios, but such crystals are in every NTSC color TV.> i knew all of that, Glen. including how (or why) f_H got bumped down to > 15734 Hz (which i think was one of the most obscure factoids) which > brought some of us audio guys the wonderful sampling frequency of 44.056 > kHz.I thought so, but decided to write it anyway. Even more interesting is how the 4.77MHz original IBM PC came to be. They had 5MHz processors, and could have run them at that. The original CGA card generates NTSC signals similar to the way the Apple II did, by switching the output at various phases of 4x the color subcarrier frequency. (That is in addition to the RGB output for the IBM CGA monitor.) Pretty much they run a shift register at 4*3579545Hz, and the different bit combinations will look like different phases of the subcarrier, and so show up at specific colors. The 8088 requires a clock with a 33% duty cycle (to meet the required high and low times at the rated speed) and the 8284 clock generator will divide its input by three. So, with one crystal they could take care of both, with the 14.1818MHz signal on one pin of the (now) ISA bus. Later processors used different clock sources, but the ISA bus still requires the 14.1818MHz signal in case you use a CGA card. When I got my first 286 based AT clone around 1987, I bought a used CGA card and used the composite video output to test the convergence on our TV set. I had a long enough (composite) video cable to reach the TV, and a long keyboard cable (probably violating the standard, but it did work) to reach the next room. -- glen
