i try to make a data transfer via the McBSP0 on the C6713 DSK. first, i have connected as follows: CLKX0 -> CLKR0 FSX0 -> FSR0 DX0 -> DR0 but without success.... what is the meaning of the CLKR-pin on the peripheral connector ? i have the choice of internal and external clock. the internal is the sample rate generator and the external is via the CLKS-pin - but when can i use the CLKR-pin ? thanks, olaf lindner
differents between CLKR and CLKS-pins @ C6713-DSK ?
Started by ●August 20, 2003
Reply by ●August 21, 20032003-08-21
"olaf636" <olaf313@web.de> ha scritto nel messaggio news:bhvd1e$3huu5$1@uni-berlin.de...> what is the meaning of the CLKR-pin on the peripheral > connector ?Look for the "Enhanced Peripherals Reference" for the family C6000 from TI, you will find all of the answers about McBSP (and much more). The difference is that CLKS "feeds" the sample rate generator, so you can use an external clock source even for transmission; anyway you can find the block schematic of McBSP on the peripheral reference. -- Lorenzo
