Hi Clay,> >Partial fraction decomp allows you to write the factored 3rd order sequati=>on as a sum. Plug in your bilinear transform at this point and reduce thea=>lgebra. >I'm not sure you're interested in this at all but I think that your proposal of using partial fraction decomposition is not as 'easy' as your sentence seems to indicate. It does not seem to be easier that just trying to get to the allpass decomposed form directly from the non-decomposed form of the transfer function. The issue is that after the polynomial division there is this constant term (not dependent on z) and there is no 'easy' way, at far as I can tell, to put this term into the first and second order terms such that the allpass form comes out. wolframalpha and the symbolic toolbox in matlab (2004 version) spit out the partial fraction decomposition in milliseconds but so far I have not been able to make them spit out the allpass decomposition. I'm not sure if the reason is due to some assumptions not being made or whether the symbolic engines don't find the allpass form 'interesting' enough to display. Using pencil and paper is soooo last millenium ;) Anyway, getting the expression for the coefficients is indeed very easy as you said as they can be read directly from the factored form of the denominator after doing the bilinear transformation. cheers _____________________________ Posted through www.DSPRelated.com
Small/easy Challenge
Started by ●September 19, 2013
Reply by ●September 27, 20132013-09-27
Hi again Clay,>Hi Clay, > >> >>Partial fraction decomp allows you to write the factored 3rd order s >equati= >>on as a sum. Plug in your bilinear transform at this point and reducethe>a= >>lgebra. >> >Please disregard my last post. The partial fraction decomposition should of course be done before the bilinear transformation. cheers _____________________________ Posted through www.DSPRelated.com
On Friday, September 27, 2013 6:31:46 AM UTC-4, niarn wrote:> Hi again Clay, > > > > >Hi Clay, > > > > > >> > > >>Partial fraction decomp allows you to write the factored 3rd order s > > >equati= > > >>on as a sum. Plug in your bilinear transform at this point and reduce > > the > > >a= > > >>lgebra. > > >> > > > > > > > Please disregard my last post. The partial fraction decomposition should of > > course be done before the bilinear transformation. > > cheers > > > > > > > > _____________________________ > > Posted through www.DSPRelated.comI'm glad you got it working. Clay
Reply by ●September 30, 20132013-09-30
> >I'm glad you got it working. > >Clay >Me 2 :), thanks How would you then rate this question (easy, medium, not fun, not interesting, just lame, etc). Why do both of the below systems of 3 equations give the solution to problem? What do they correspond to? (Note that the two systems of equations are not equivalent but they share the same real solution!) (u1+v1)*(2*K-1) + (v2+v1*u1)*(2*K+1) + v2*u1*(2*K+3) = -2*K+3 (v2+v1*u1)*(1 - K^3) + (u1+v1)*(-K^3-1) + v2*u1*(-1-K^3) = K^3-1 (v2+v1*u1)*(1+2*K^2) + (u1+v1)*(1+2*K^2) + v2*u1*(-3+2*K^2) = -2*K^2+3 u1+v1/v2 = 3*(1-K^3)/(1+K^3) 1/v2+u1*v1/v2 = 3 u1/v2 = (1-K^3)/(1+K^3) _____________________________ Posted through www.DSPRelated.com
