Hi everyone, I'm trying to demodulate the following in order to obtain "signal" - cos(cos(2*PI*11025*i/88200.0) + signal) I'm using a signal of - cos(2*PI*1102.5*i/88200.0) so I'm actually demodulating - intensity[i] = cos( cos(2*PI*11025*i/88200.0) + cos(2*PI*1102.5*i/88200.0)) To demodulate this signal, I consider two bands. The first band is around 11025Hz, and the second is around 2*11025Hz. The first stage of the demodulation scheme involves individually shifting these two bands into the base band, as follows - for( i=0;i<SIZE;i++) { mix1[i] = cos(w(11025)*i/double(SR))*intensity[i]; mix2[i] = cos(2*w(11025)*i/double(SR))*intensity[i]; } // low pass the base band, to remove all other bands filterInit(11025/2.0,filter1,b); for(i=0;i<SIZE;i++) mix1[i] = filterLP(mix1[i], filter1, b); filterInit(11025/2.0,filter2,b); for(i=0;i<SIZE;i++) mix2[i] = filterLP(mix2[i], filter2, b); Mix1 and mix2 above are equal to - J1(1)sin(signal) = J1(1)sin(cos(2*PI*11025*i/88200.0)) J2(1)cos(signal) = J2(1)cos(cos(2*PI*11025*i/88200.0)) Where J is a bessel function. I then diff and cross multiply, add the result, and intergrate that to get "signal" - diff1[0] = 0; for(i=1;i<SIZE;i++) diff1[i] = (mix2[i] - mix2[i-1]) * mix1[i]; diff2[0] = 0; for(i=1;i<SIZE;i++) diff2[i] = (mix1[i] - mix1[i-1]) * mix2[i]; for(i=0;i<SIZE;i++) sum[i] = diff1[i] - diff2[i]; output[0] = 0; for(i=1;i<SIZE;i++) output[i] = sum[i] + /*0.995*/ sum[i-1]; the maths of which is - the integral of J1(C)*J2(C)*diff(signal)*(cos(signal)^2) + J1(C)*J2(C)*diff(signal)*(sin(signal)^2) //cos^2 + sin^2 = 1 This algorithm worked fine when I simulated it, but now I've realized that it doesn't work when my original signal has a phase shift - such as - intensity[i] = cos( cos(2*PI*11025*i/88200.0) + cos(2*PI*11025*i/88200.0)) intensity + 5 = intensity. // shift by 5 samples The problem is that the modulation and the local oscillators, both at 11025Hz, are not in phase. Another way of causing this problem is if I change my code to - for( i=0;i<SIZE;i++) { mix1[i] = cos(w(11025)*(i+7)/double(SR))*intensity[i]; mix2[i] = cos(2*w(11025)*(i+7)/double(SR))*intensity[i]; } What might I do to avoid this problem? This demodulation scheme is refered to as homodyne demodulation using phase generated carrier (avoids signal fading) Regards.
Demodulation Error
Started by ●August 16, 2003
Reply by ●August 18, 20032003-08-18
I imagine the carrier signal is produced by the demodulator to be in-phase with the local oscillators. bg_ie@yahoo.com (Barry) wrote in message news:<731cea69.0308161329.6de57893@posting.google.com>...> Hi everyone, > > I'm trying to demodulate the following in order to obtain "signal" - > > cos(cos(2*PI*11025*i/88200.0) + signal) > > I'm using a signal of - > > cos(2*PI*1102.5*i/88200.0) > > so I'm actually demodulating - > > intensity[i] = cos( cos(2*PI*11025*i/88200.0) + > cos(2*PI*1102.5*i/88200.0)) > > To demodulate this signal, I consider two bands. The first band is > around 11025Hz, and the second is around 2*11025Hz. > > The first stage of the demodulation scheme involves individually > shifting these two bands into the base band, as follows - > > for( i=0;i<SIZE;i++) > { > mix1[i] = cos(w(11025)*i/double(SR))*intensity[i]; > mix2[i] = cos(2*w(11025)*i/double(SR))*intensity[i]; > } > > // low pass the base band, to remove all other bands > filterInit(11025/2.0,filter1,b); > for(i=0;i<SIZE;i++) > mix1[i] = filterLP(mix1[i], filter1, b); > > filterInit(11025/2.0,filter2,b); > for(i=0;i<SIZE;i++) > mix2[i] = filterLP(mix2[i], filter2, b); > > Mix1 and mix2 above are equal to - > > J1(1)sin(signal) = J1(1)sin(cos(2*PI*11025*i/88200.0)) > > J2(1)cos(signal) = J2(1)cos(cos(2*PI*11025*i/88200.0)) > > Where J is a bessel function. > > I then diff and cross multiply, add the result, and intergrate that to > get "signal" - > > diff1[0] = 0; > for(i=1;i<SIZE;i++) > diff1[i] = (mix2[i] - mix2[i-1]) * mix1[i]; > > diff2[0] = 0; > for(i=1;i<SIZE;i++) > diff2[i] = (mix1[i] - mix1[i-1]) * mix2[i]; > > for(i=0;i<SIZE;i++) > sum[i] = diff1[i] - diff2[i]; > > output[0] = 0; > for(i=1;i<SIZE;i++) > output[i] = sum[i] + /*0.995*/ sum[i-1]; > > the maths of which is - > > the integral of > > J1(C)*J2(C)*diff(signal)*(cos(signal)^2) + > J1(C)*J2(C)*diff(signal)*(sin(signal)^2) > > //cos^2 + sin^2 = 1 > > This algorithm worked fine when I simulated it, but now I've realized > that it doesn't work when my original signal has a phase shift - such > as - > > intensity[i] = cos( cos(2*PI*11025*i/88200.0) + > cos(2*PI*11025*i/88200.0)) > intensity + 5 = intensity. // shift by 5 samples > > > The problem is that the modulation and the local oscillators, both at > 11025Hz, are not in phase. > > Another way of causing this problem is if I change my code to - > > for( i=0;i<SIZE;i++) > { > mix1[i] = cos(w(11025)*(i+7)/double(SR))*intensity[i]; > mix2[i] = cos(2*w(11025)*(i+7)/double(SR))*intensity[i]; > } > > > What might I do to avoid this problem? This demodulation scheme is > refered to as homodyne demodulation using phase generated carrier > (avoids signal fading) > > Regards.
