Hi guys, i have a problem with fft2. I must find the autocorrelation matrix of a matrix s = 4x10000. The first and right solution is R = s*s'; <--matrix 4x4 Now i want obtain the same result with fft2,so: o = fft2(s); kl = o*o'; R = ifft2(kl); <- matrix 4x4 But i see that the fourth column is different, while the others yes..Why??
Autocorrelation matrix with FFT2
Started by ●October 20, 2013
Reply by ●October 21, 20132013-10-21
On Sunday, October 20, 2013 9:37:33 PM UTC+13, Ste_ee wrote:> Hi guys, i have a problem with fft2. > > I must find the autocorrelation matrix of a matrix s = 4x10000. > > > > The first and right solution is R = s*s'; <--matrix 4x4 > > > > Now i want obtain the same result with fft2,so: > > > > o = fft2(s); > > kl = o*o'; > > R = ifft2(kl); <- matrix 4x4 > > > > But i see that the fourth column is different, while the others yes..Why??Over to you Vlad. Vlad the inhaler will help you out.
>Hi guys, i have a problem with fft2. >I must find the autocorrelation matrix of a matrix s = 4x10000. > >The first and right solution is R = s*s'; <--matrix 4x4 > >Now i want obtain the same result with fft2,so: > >o = fft2(s); >kl = o*o'; >R = ifft2(kl); <- matrix 4x4 > >But i see that the fourth column is different, while the othersyes..Why??> >Try asking at dsp.stackexchange.com, maybe provide an example with some toy input where the expected output is known.... _____________________________ Posted through www.DSPRelated.com
