Greetings! I am doing a bit of research on current technigues used for speech enhancement / noise suppression and I came across the following papers: N. Virag, "Single channel speech enhancement based on masking properties of the human auditory system," IEEE Trans. Speech and Audio Processing, vol. 7, no. 2, pp. 126-137, Mar. 1999. J. D. Johnston, "Transform coding of audio signal using perceptual noise criteria," IEEE J. Select. Areas Commun., vol. 6, pp. 314�323, Feb. 1988. I would greatly appreciate if anyone could email me a soft copy of any of the above. Thank you for your time! Ntinos P.
Speech Enhancement paper
Started by ●August 14, 2003
Reply by ●August 14, 20032003-08-14
ntinosp@hotmail.com (Dino) wrote in message news:<bd3f6418.0308140134.186c5378@posting.google.com>...> Greetings! > > I am doing a bit of research on current technigues used for > speech enhancement / noise suppression and I came across the following papers: > > N. Virag, "Single channel speech enhancement based > on masking properties of the human auditory system," > IEEE Trans. Speech and Audio Processing, vol. 7, no. > 2, pp. 126-137, Mar. 1999. > > J. D. Johnston, "Transform coding of audio signal using perceptual noise > criteria," IEEE J. Select. Areas Commun., vol. 6, pp. 314?323, Feb. > 1988. > > > I would greatly appreciate if anyone could email me a soft copy of any > of the above. > > Thank you for your time! > > Ntinos P.Your local (university) library should be able to help you out. If you ask the people you work/study with, there may be somebody who are members of IEEE and can download the papers for you through ieeexplore. You may even want to join IEEE yourself. Rune
I tried sending the papers to you, but your email bounced back. Please provide a valid email address. The files are big (> 1.5 MB together) "Dino" <ntinosp@hotmail.com> wrote in message news:bd3f6418.0308140134.186c5378@posting.google.com...> Greetings! > > I am doing a bit of research on current technigues used for > speech enhancement / noise suppression and I came across the followingpapers:> > N. Virag, "Single channel speech enhancement based > on masking properties of the human auditory system," > IEEE Trans. Speech and Audio Processing, vol. 7, no. > 2, pp. 126-137, Mar. 1999. > > J. D. Johnston, "Transform coding of audio signal using perceptual noise > criteria," IEEE J. Select. Areas Commun., vol. 6, pp. 314-323, Feb. > 1988. > > > I would greatly appreciate if anyone could email me a soft copy of any > of the above. > > Thank you for your time! > > Ntinos P.
