On 1/7/14 11:52 AM, radams2000@gmail.com wrote:> Testi can hear you now, Bob. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
FFT: Zero-padding, Windowing - What order?
Started by ●January 5, 2014
Reply by ●January 8, 20142014-01-08
Great, for some reason I was getting errors for several days in a row (thought I was banned due to lame humor). Bob
On 1/8/14 12:00 AM, radams2000@gmail.com wrote:> Great, for some reason I was getting errors for several days in a row (thought I was banned due to lame humor).nobuddy gets band here, Bob. maybe humiliated but there is no mechanism for banning in unmoderated USENET. *maybe* the NNTP servers have a way of filtering out bot or spam posts. i don't see them very much of late, so i imagine the NNTP servers have figured something out. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●January 11, 20142014-01-11
On 2014-01-07 18:20:19 +0000, robert bristow-johnson said:> On 1/7/14 11:06 AM, Marc Jenkins wrote: >> On 2014-01-06 03:06:17 +0000, robert bristow-johnson said: >> >>> also, Marc, you can (and, in my opinion, should) think of this >>> windowing and zero-padding as one single operations. >>> >>> before the operation you have x[n] for -inf < n < +inf >>> >>> after the operation you have x[n] * w[n] for the same n. >>> >>> both the truncation of x[n] to a specific length and the zero padding >>> can be modeled as zeros in the same w[n]. >>> >>> then it doesn't matter what the order is. >> >> But why is there a tremendous difference in the FFT-result when changing >> the order? >> > > make sure it's the same w[n].What do you mean with that. Consider following pseude-matlab code: % Signal is y L = length(y); window = hann(L); NFFT = 2^nextpow2(L); y = [y; zeros(NFFT-L, 1)]; S = fft(y .* window, NFFT); vs. % Signal is y L = length(y); window = hann(L); y = y .* window; NFFT = 2^nextpow2(L); y = [y; zeros(NFFT-L, 1)]; S = fft(y, NFFT); These two variants clearly yield different results. With the first one I get see spectrum peaks which I do not see with the second version - I want to understand what happens here. Marc
Marc Jenkins <marc.jenkins@noreply.com> writes:> [...] > % Signal is y > L = length(y); > window = hann(L); > NFFT = 2^nextpow2(L); > y = [y; zeros(NFFT-L, 1)]; > S = fft(y .* window, NFFT);Unless the length of y is already a power of two, this should not even run. The line S = fft(y .* window, NFFT); should bomb out since you can't take the element-by-element multiplication (.*) of two vectors of different lengths.> vs. > > % Signal is y > L = length(y); > window = hann(L); > y = y .* window; > NFFT = 2^nextpow2(L); > y = [y; zeros(NFFT-L, 1)]; > S = fft(y, NFFT); > > These two variants clearly yield different results.If the length of y is already a power of two, NFFT = L and the results should be identical. This is assuming nextpow2(L) = ceil(log2(L)). -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On 2014-01-11 14:54:24 +0000, Randy Yates said:> Marc Jenkins <marc.jenkins@noreply.com> writes: >> [...] >> % Signal is y >> L = length(y); >> window = hann(L); >> NFFT = 2^nextpow2(L); >> y = [y; zeros(NFFT-L, 1)]; >> S = fft(y .* window, NFFT); > > Unless the length of y is already a power of two, this should not even > run. The line > > S = fft(y .* window, NFFT); > > should bomb out since you can't take the element-by-element > multiplication (.*) of two vectors of different lengths.You're right. But consider this two examples with the following window for the first window = hann(NFFT). That was what I meant. Marc
Marc Jenkins <marc.jenkins@noreply.com> writes:> On 2014-01-11 14:54:24 +0000, Randy Yates said: > >> Marc Jenkins <marc.jenkins@noreply.com> writes: >>> [...] >>> % Signal is y >>> L = length(y); >>> window = hann(L); >>> NFFT = 2^nextpow2(L); >>> y = [y; zeros(NFFT-L, 1)]; >>> S = fft(y .* window, NFFT); >> >> Unless the length of y is already a power of two, this should not even >> run. The line >> >> S = fft(y .* window, NFFT); >> >> should bomb out since you can't take the element-by-element >> multiplication (.*) of two vectors of different lengths. > > > You're right. But consider this two examples with the following window > for the first > window = hann(NFFT). That was what I meant.Well then of course they will be different. If signal vectors x1 != x2, would you expect fft(x1) = fft(x2)?!? It is the data vector you should window, not the input to the FFT. If L = NFFT, then of course they're one and the same. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On 1/11/14 8:14 AM, Marc Jenkins wrote:> On 2014-01-07 18:20:19 +0000, robert bristow-johnson said: > >> On 1/7/14 11:06 AM, Marc Jenkins wrote: >>> On 2014-01-06 03:06:17 +0000, robert bristow-johnson said: >>> >>>> also, Marc, you can (and, in my opinion, should) think of this >>>> windowing and zero-padding as one single operations. >>>> >>>> before the operation you have x[n] for -inf < n < +inf >>>> >>>> after the operation you have x[n] * w[n] for the same n. >>>> >>>> both the truncation of x[n] to a specific length and the zero padding >>>> can be modeled as zeros in the same w[n]. >>>> >>>> then it doesn't matter what the order is. >>> >>> But why is there a tremendous difference in the FFT-result when changing >>> the order? >>> >> >> make sure it's the same w[n]. > > What do you mean with that?only what i said.> Consider following pseude-matlab code: > > % Signal is y > L = length(y); > window = hann(L); > NFFT = 2^nextpow2(L); > y = [y; zeros(NFFT-L, 1)];here, you stretched out y and made it longer.> S = fft(y .* window, NFFT);but you didn't zero-pad window. you have to do this L = length(y); window = hann(L); NFFT = 2^nextpow2(L); y = [y; zeros(NFFT-L, 1)]; window = [window; zeros(NFFT-L, 1)]; S = fft(y .* window, NFFT); and compare to your second case:> > vs. > > % Signal is y > L = length(y); > window = hann(L); > y = y .* window; > NFFT = 2^nextpow2(L); > y = [y; zeros(NFFT-L, 1)]; > S = fft(y, NFFT); >but if you compare to this: L = length(y); NFFT = 2^nextpow2(L); window = hann(NFFT); y = [y; zeros(NFFT-L, 1)]; S = fft(y .* window, NFFT); it's not the same window.> These two variants clearly yield different results.how? you cannot make this test yield different results because you cannot make the multiplication by the window of a different length work. MATLAB should flag that as an error. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 1/11/14 10:06 AM, Randy Yates wrote:> > Well then of course they will be different. If signal vectors x1 != x2, > would you expect fft(x1) = fft(x2)?!? > > It is the data vector you should window, not the input to the FFT. If > > L = NFFT, > > then of course they're one and the same.sorry, Randy. didn't see you nail this until after i responded. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> writes:> On 1/11/14 10:06 AM, Randy Yates wrote: >> >> Well then of course they will be different. If signal vectors x1 != x2, >> would you expect fft(x1) = fft(x2)?!? >> >> It is the data vector you should window, not the input to the FFT. If >> >> L = NFFT, >> >> then of course they're one and the same. > > sorry, Randy. didn't see you nail this until after i responded.No problem, Robert. Sometimes I still answer again even though I see a perfectly good answer because it may help to see a slightly different POV and/or different words. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
