Is this obvious - not sure. Of course I can pass white noise through the impulse response then calculate periodogram in the usual way from the time series. But is there a simpler way?
Impulse response to periodogram
Started by ●January 21, 2014
Reply by ●January 22, 20142014-01-22
On Tue, 21 Jan 2014 17:31:52 -0800 (PST), gyansorova@gmail.com wrote:>Is this obvious - not sure. > >Of course I can pass white noise through the impulse response then calculate >periodogram in the usual way from the time series. But is there a simpler way?Hi, A simpler way to do what? What are you trying to do? [-Rick-]
Am 22.01.2014 02:31, schrieb gyansorova@gmail.com:> Is this obvious - not sure. > > Of course I can pass white noise through the impulse response then calculate periodogram in the usual way from the time series. But is there a simpler way?Sounds like you're interested in the filter's amplitude response. You can get that by simply "FFTing" the impulse response. If you have Gnu Octave or MATLAB at your disposal, enter "help freqz".
On Thursday, January 23, 2014 3:05:07 AM UTC+13, sg wrote:> Am 22.01.2014 02:31, schrieb gyansorova@gmail.com: > > > Is this obvious - not sure. > > > > > > Of course I can pass white noise through the impulse response then calculate periodogram in the usual way from the time series. But is there a simpler way? > > > > Sounds like you're interested in the filter's amplitude response. You > > can get that by simply "FFTing" the impulse response. If you have Gnu > > Octave or MATLAB at your disposal, enter "help freqz".I'm trying to get cepstrum coefficients
