HPI host to target interrupting
Started by Unknown August 10, 2003
Hi all,
I'm writing an app which allows me to load a .out onto my dsp board,
and in turn to communicate with my board (C6711DSK). So far I have
been successful using handshaking, but I would also like to interrupt
the board and I cant seem to get this working. I imagine the problem
isn't major, and that I've probably left out something simple. So
anyway I guess the best idea is for me to include the code I'm using.
Below is my target .out file with I'm loading to the board using my
app. As you can see, I'm enabling GIE and INT13's IE - do I need to do
anything else? The target .out program processes two hand shaking
commands - LEDS_ON and LEDS_OFF, while the interrupt should turn off
the leds.
#include <stdio.h>
#include <c6x.h>
#include "c6211dsk.h"
#include "cnfDSP.h"
#include "dsk6xHSB.h"
#pragma DATA_SECTION(handShakingBuffer, "my_DataSect")
int handShakingBuffer[HS_BUFFER_LEN];
int newFlag;
/* main()
int main()
  unsigned int io_port_values;
  /* dsp and peripheral initialization */
  CSR=0x100;
  IER=0x0002;
  ICR=0xffff;
  newFlag = 0;
  *(unsigned volatile int *)EMIF_CE0 = 0x30;   /* EMIF CE0control
  /* Read DIP switches
  *(unsigned volatile int *)EMIF_CE1 = CE1_32;// EMIF CE1 control,
32bit async
  io_port_values=get_ioport();
  *(unsigned volatile int *)EMIF_CE1 = CE1_8;// EMIF CE1 control, 8bit
async
  /* Perform Hand Shaking
  handShakingBuffer[0] = ID_0;
  handShakingBuffer[1] = ID_1;
  handShakingBuffer[2] = ID_2;
  handShakingBuffer[3] = 0;
  handShakingBuffer[4] = 0;
  handShakingBuffer[5] = io_port_values;
  /* Wait for Host ACK
  while(handShakingBuffer[4] != HOST_RECEIVE_HAND_SHAKING_INFO);
  /* Reset handShakingBuffer
  handShakingBuffer[0] = 0;
  handShakingBuffer[1] = 0;
  handShakingBuffer[2] = 0;
#if PRINT
  printf("Hand Shake Complete.\n");
#endif
  CSR=0x1;              //set GIE
  IER=0x2002;           //set HPI
  /* Run DSP forever
  while(1)
  /* Test for HOST ready
#if PRINT
    printf("\nDSP Ready for HOST Command.\n");
#endif
    /* Wait until HOST has a command and parameters ready
  while(handShakingBuffer[4] != HOST_STATUS_INPUT_READY
		  && handShakingBuffer[4] != HOST_STATUS_END_PROCESSING);
    /* Quit if HOST requests it or Process a HOST command
    if(handShakingBuffer[4] == HOST_STATUS_END_PROCESSING)
#if PRINT
      printf("\nHOST Requested End of Processing.\n");
#endif
      break;
    else
      handShakingBuffer[4] = DSP_PROCESSING_COMMAND;
#if PRINT
    printf("\nNew HOST Command Read: ");
#endif
    /* Process a HOST command
  switch(handShakingBuffer[3])
     case LEDS_OFF:
32bit async
       ledOff();
       handShakingBuffer[5]=0;//TIMER_OK;
8bit async
       break;
      /* Run the QDMA test and return information if(error)
      case LEDS_ON:
control, 32bit async
        ledOn();
        handShakingBuffer[5]=0;//LEDS_OK;
control, 8bit async
        break;
    /* Tell the HOST that DSP processing is done for this command
		handShakingBuffer[4] = DSP_STATUS_OUTPUT_READY;
  while(1);
  return(0);
void ledOn()
  *(unsigned volatile int *)IO_PORT = 0x0000000;/* turn on user leds
void ledOff()
  *(unsigned volatile int *)IO_PORT = 0x7000000;/* turn off user leds
/* get_ioport() - used to read state of ioport
unsigned int get_ioport(void)
  return(*(unsigned volatile int *)IO_PORT);
interrupt void hpi_isr()
32bit async
  ledOff();
async
OK, this is my vector table -
*	TI Proprietary Information
*		Internal Data
    .ref    _hpi_isr
    .ref    _c_int00
	.sect "vectors"
RESET_RST:
    mvkl .S2 _c_int00, B0
    mvkh .S2 _c_int00, B0
    B    .S2 B0
	NOP
	NOP
	NOP
	NOP
    NOP
NMI_RST:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
RESV1:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
RESV2:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT4:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT5:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT6: NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT7:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT8:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT9:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT10:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT11:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT12:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT13:   b _hpi_isr
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT14:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT15:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
Finally the app, which allows the user to turn off or on the leds -
/* FILENAME: dsk6xtst.c -- DSK Confidence    Test - HOST Code
/*  Rev 2.01   11   May 2001  T.J.Dillon					          */
/*  HISTORY
/*  Rev 1.00   Created
/*  Rev 1.10   Mods a) LEDS and CODEC parameter passing
/*                  b) Removed FLASH checksum
/*                  c) Changes for new Win32 DLL API for generic API
/*  Rev 1.20   Mods -- Added -pport options
/*  Rev 1.21   Mods -- Reorganize to be consistent with Manufacturing
Test */
/*  Rev 1.25   Mods -- Update with latest Win32 DLL API
/*  Rev 1.26   Mods -- Added -pd option
/*  Rev 1.30   Mods -- Added board revision info
/*  Rev 2.00   Mods -- Update for C6711 DSK
/*  Rev 2.01   Mods -- Update for CCS2.0 Support
#include <stdio.h>
#include <windows.h>
#include "dsk6x11hpi.h"
#include "dsk6xtst.h"
const ULONG DSPHS_BUFFER_ADDRESS = 0x200; /* Start Int Mem */
static FILE     *pBoardFile = NULL;
#define STRING_BUFFER_SIZE  (80)
#define ULONG unsigned long
static void PrintMenu( void );
/* main()
void main(int argc1, char *argv1[])
  int finished = 0;
  dskHANDLE hBd;        /* Board device handle
  short  iBd    = 0;    /* Board index
  BOOL   bExcl  = 1;    /* Exclusive open = TRUE
  short  iMp    = 1;    /* Map selector = MAP1
  char coffNam[20]= "CnfDSP.out";
                        /* COFF file name
   char *sBoardFile;
  BOOL bVerbose = 0;    /* COFF load verbose mode = FALSE
  BOOL bClr     = 0;    /* Clear bss mode = FALSE
  BOOL bDump    = 0;    /* Dump mode = FALSE
  ULONG handShakingBuffer[HS_BUFFER_LEN], readLength, writeLength;
  int handShakingFlag, dspProcFlag;
  int choice;
  ULONG command;         /* Command variable to run each test on DSP
  /* Parse Command Line
  sBoardFile = "F:\\ti\\c6000\\dsk6x11\\doc\\ti_ppdsk.cfg";
  pBoardFile = fopen( sBoardFile, "r" );
  if ( pBoardFile == NULL )
	 printf( "ERROR: Please specify a valid board configuration file via
the -f option.\n" );
	 exit(1);
  else
	 fclose(pBoardFile);
  /* Open a driver connection to a dsk6x board.
  if ( !dsk6x_open(sBoardFile,&hBd) )
    exit(1);
  /* Cause a DSP reset.
  if ( !dsk6x_reset_dsp(hBd,0,1) )
     exit(2);
  /* Establish a connection to the HPI of a target board.
  if ( !dsk6x_hpi_open(hBd))
     exit(3);
  /* Read a COFF file and write the data to DSP memory.
  if (dsk6x_coff_load(hBd,coffNam,bVerbose,bClr,bDump))
      exit(4);
  /* Generate a DSPINT to start program
  if (!dsk6x_hpi_generate_int(hBd))
    exit(5);
    /* Handshaking. Keep reading until hand shake is done.
    do
	    readLength = HS_BUFFER_LEN*4; /* 4 bytes for 1 word */
      /* Test if handShakingBuffer actually read (completely)
	  if (!dsk6x_hpi_read(hBd, handShakingBuffer, &readLength,
        DSPHS_BUFFER_ADDRESS) || readLength != HS_BUFFER_LEN*4)
      { /* evm6x_hpi_read() failed */
		    continue; // try again
      /* Test if handShakingBuffer contains correct ID
	    handShakingFlag = 0;  // reset hand shaking flag
	    if(handShakingBuffer[0] != ID_0)
		    handShakingFlag = 1;
	    if(handShakingBuffer[1] != ID_1)
	    if(handShakingBuffer[2] != ID_2)
    } while (handShakingFlag == 1);
    /* Send hand shaking ACK to Target(DSP)
    writeLength = 4;
    handShakingBuffer[4] = HOST_RECEIVE_HAND_SHAKING_INFO;
    dsk6x_hpi_write(hBd, &handShakingBuffer[4], &writeLength,
      DSPHS_BUFFER_ADDRESS+4*4);
    /* Display Menu First time
       printf("\nEnter 1 for led off, 2 for leds on, 3 for interupt -
leds off, other to escape\n");
    /* Do while loop for repeat of choices
    do
        printf("\nChoice: ");
        scanf("%d", &choice);
        if(choice == 1)
          command = LEDS_OFF;
        else if(choice == 2)
          command = LEDS_ON;
        else if(choice == 3)
          dsk6x_hpi_generate_int(hBd);
        else
          finished = 1;
      if(choice!=1||choice!=2)
      /* Send command to Target(DSP)
	  writeLength = 4;
      handShakingBuffer[3] = command;
      dsk6x_hpi_write(hBd, &handShakingBuffer[3], &writeLength,
        DSPHS_BUFFER_ADDRESS+3*4);
      /* Tell Target(DSP) that Host is ready
      writeLength = 4;
      handShakingBuffer[4] = HOST_STATUS_INPUT_READY;
      dspProcFlag = 1;
      /* Wait for Target(DSP) to tell you it is done!
      do
	      readLength = 4;
	      dsk6x_hpi_read(hBd, &handShakingBuffer[4], &readLength,
	      if(handShakingBuffer[4] == DSP_STATUS_OUTPUT_READY)
		      dspProcFlag = 0;  // DSP is done processing
      } while(dspProcFlag);
    /* Test for yes answer to repeat processing
	  } while (!finished);
  /* Tell Target(DSP) that HOST is done!
  writeLength = 4;
  handShakingBuffer[4] = HOST_STATUS_END_PROCESSING;
  /* Close the new HPI session started with evm6x_hpi_open()
  if (!dsk6x_hpi_close(hBd))
     exit(6);
  /* Close a previously opened driver connection to a board.
  if (!dsk6x_close(hBd))
     exit(7);
  exit(0);
} /* end of main() */
I'm still having no luck with this one guys,
could someone suggest something I could try out to narrow down the issue here,
Thanks very much,
Aine.
aine_canby@yahoo.com (&#4294967295;ine Canby) wrote in message news:<57ed59a.0308111338.3bc93766@posting.google.com>...
> I'm still having no luck with this one guys, > could someone suggest something I could try out to narrow down the issue here, > Thanks very much, > > Aine.
Hi, It has been a long time since I touch TI DSK so I forgot all the technical detail but you can go to http://mirriwinni.cs.jcu.edu.au/~phillip/dsp/ and download the utilities. http://mirriwinni.cs.jcu.edu.au/~phillip/dsp/dsk_loader_parallel.tar.gz It done similar thing you want to do in Windows but It run under Unix with source code so you can look at it for reference. Good luck
Thanks for the reply Duy. I am now at the stage where I am simply
trying to manually call an interrpt - interrupt 13 from a simple
program, and I cant even get that to work. Here is the code I'm using.
The Interrupt is not being triggered when I write to the ISR register.
Can anyone tell me what I'm doing wrong?
Thanks very much,
Aine.
#include <stdio.h>
#include <c6x.h>
#include "cnfDSP.h"
/* main()
int main()
  CSR=0x100;	        	       /* disable all interrupts            */
  IER=1;                           /* disable all interrupts except
NMI */
  ICR=0xffff;                      /* clear all pending interrupts
  ICR = IFR | 0x2000;
  IER |= 0x2002;             // enable int 13
  CSR |= 1;
  ISR=0x2000;
  return(0);
void ledOn()
void ledOff()
32bit async
  ledOn();
async
  newFlag = 1;
*** Vector.asm -
*		Internal Data
    .ref    _c_int00
    .ref    _hpi_isr
    .ref    _isr4
	.sect "vectors"
RESET_RST:
    B    .S2 B0
	NOP
	NOP
	NOP
	NOP
    NOP
NMI_RST:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
RESV1:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
RESV2:
    NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT4:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT5:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT6: NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT7:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT8:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT9:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT10:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT11:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT12:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT13:   b _hpi_isr
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT14:   NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
INT15:  NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
*** lnk.cmd -
-c
-heap  0x500
-stack 0x500 /* very large stack for DSP programs. */
-lrts6201.lib
MEMORY
    vecs:       o = 00000000h   l = 00000200h
    I_HS_MEM:   o = 00000200h   l = 00000020h
    IRAM:       o = 00000220h   l = 0000FDE0h
    CE0:	o = 80000000h	l = 01000000h
SECTIONS
    "vectors"   >       vecs
    my_DataSect >       I_HS_MEM
    .cinit      >       IRAM
    .text       >       IRAM
    .stack      >       IRAM
    .bss        >       IRAM
    .const      >       IRAM
    .data       >       IRAM
    .far        >       IRAM
    .switch     >       IRAM
    .sysmem     >       IRAM
    .tables     >       IRAM
    .cio        >       IRAM
&#4294967295;ine Canby wrote:
> > Thanks for the reply Duy. I am now at the stage where I am simply > trying to manually call an interrpt - interrupt 13 from a simple > program, and I cant even get that to work. Here is the code I'm using. > The Interrupt is not being triggered when I write to the ISR register. > Can anyone tell me what I'm doing wrong? > > Thanks very much, > > Aine. >
> > INT13: b _hpi_isr > NOP > NOP > NOP > NOP > NOP > NOP > NOP >
... I don't see how interrupt 13 returns. Did I miss something? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Hi,
i work with 54x, without DSP/BIOS, but i don't read about any doing
for interrupt event: call if software interrupt, or setup if CCS
simulation, or pulse on pin.
Cheers
Vic wrote:
> > Hi, > i work with 54x, without DSP/BIOS, but i don't read about any doing > for interrupt event: call if software interrupt, or setup if CCS > simulation, or pulse on pin. > > Cheers
I don't know the language you use for programming, but if you dig into the architecture and perhaps also the assembly commands associated with interrupt operation, the answer to your question (which you didn't actually ask) is likely to come clear. -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
